Aller au contenu principal
Pour réparer ensemble - Je crée un compte
P-Tex Repair
Ce dont vous avez besoin
    1. P-Tex Repair, Binding: étape 1, image 1 de 3 P-Tex Repair, Binding: étape 1, image 2 de 3 P-Tex Repair, Binding: étape 1, image 3 de 3
      • Release the binding straps by lifting up on the buckle and pulling towards the direction of the end of the ladder.
      • Not all binding straps will release the same way. If you are having trouble releasing your binding straps, please refer to your owner's manual.
      Demander à FixBot
      Ajouter un commentaire
    2. P-Tex Repair: étape 2, image 1 de 2 P-Tex Repair: étape 2, image 2 de 2
      • Move the straps and the highback plate out of the way in order to have clear access to the foot pad screw.
      • The highback plate is the vertical support plate located on the heel side of the binding.
      Demander à FixBot
    3. P-Tex Repair: étape 3, image 1 de 2 P-Tex Repair: étape 3, image 2 de 2
      • Use a #2 Phillips screwdriver to remove the panhead, 10mm wide, M4 x 12mm screw located in the middle of the foot pad.
      Demander à FixBot
    4. P-Tex Repair: étape 4, image 1 de 3 P-Tex Repair: étape 4, image 2 de 3 P-Tex Repair: étape 4, image 3 de 3
      • Use a #2 Phillips screwdriver to remove the four ovalhead M6 x 12mm screws that attach the base plate of the binding to the board.
      • Lift or slide the binding off the board and set the screws aside.
      Demander à FixBot
    1. P-Tex Repair, P-Tex Repair: étape 5, image 1 de 3 P-Tex Repair, P-Tex Repair: étape 5, image 2 de 3 P-Tex Repair, P-Tex Repair: étape 5, image 3 de 3
      • Turn the snowboard over so the bottom of the board is facing up.
      • Set the snowboard down on a stable work surface so that it does not rock or move.
      • We recommend using a table that is small enough to fit between the curves on either side of the board, or placing blocks of wood to raise the board from the table.
      • Assess the damage. If there are loose strands of material around the hole, slice them off carefully with a razor blade.
      • Remove any extra wax with a metal scraper.
      • Use 150 grit sandpaper to roughen up the inside of the gouge.
      Demander à FixBot
    2. P-Tex Repair: étape 6, image 1 de 2 P-Tex Repair: étape 6, image 2 de 2
      • Clean the gouge with a few drops of citrus based cleaner such as Orange-Sol (rubbing alcohol will also work), and a small wire brush to get rid of any dirt or rocks. Let the cleaner dry completely—about 20 minutes to an hour.
      Demander à FixBot
    3. P-Tex Repair: étape 7, image 1 de 2 P-Tex Repair: étape 7, image 2 de 2
      • Using a propane torch or a butane lighter, heat up one tip of the P-Tex candle over a metal pan.
      • Use caution not to burn yourself - the flame is extremely hot.
      • Wait until the candle is flaming, which may take a couple of seconds.
      • Black carbon flakes will appear in the burning tip. DO NOT let them get into your base or the P-Tex will bond poorly.
      • Let the candle drip onto a metal pan and roll the molton tip around until the candle is carbon free.
      Demander à FixBot
    4. P-Tex Repair: étape 8, image 1 de 2 P-Tex Repair: étape 8, image 2 de 2
      • It is important that the P-Tex is flowing and not dripping. Dripping will allow more impurities to enter the bonding surface and inhibit adhesion.
      • Move the molten P-Tex candle to the gouge. Hold it close to the surface and let it flow continuously into the gouge surface.
      • The P-Tex will shrink as it cools, so overfill the gouge.
      • Let the P-Tex cool for about 15 minutes.
      Demander à FixBot
    5. P-Tex Repair: étape 9, image 1 de 3 P-Tex Repair: étape 9, image 2 de 3 P-Tex Repair: étape 9, image 3 de 3
      • Take a sharpened metal scraper or razor blade and hold it at a 45° angle. Pull the razor using short, overlapping strokes (about a half inch at a time) to remove all material that is protruding above the base of the snowboard. Use whatever direction works best.
      • The razor is sharp and can cut you if you are not careful.
      • You can also wrap sandpaper around a block and rub the area to flatten it completely.
      Demander à FixBot
    6. P-Tex Repair: étape 10, image 1 de 1
      • When the P-Tex is smooth and flush with the base, your repair is finished. Take a couple of seconds to admire your work.
      • Wax your board before use.
      Demander à FixBot
Ligne d'arrivée
2 autres ont terminé cette réparation.
Robert Torres
Membre depuis le 01/14/14
214 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 17-4, Forte Winter 2014 Membre de l'équipe Cal Poly, Team 17-4, Forte Winter 2014
CPSU-FORTE-W14S17G4
5 membres
29 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 11
30 derniers jours : 52
Total : 4,195
