Aller au contenu principal
Pour réparer ensemble - Je crée un compte
PDP Afterglow Fener LED Replacement
Ce dont vous avez besoin
    1. PDP Afterglow Fener LED Replacement, LED: étape 1, image 1 de 3 PDP Afterglow Fener LED Replacement, LED: étape 1, image 2 de 3 PDP Afterglow Fener LED Replacement, LED: étape 1, image 3 de 3
      • Gently pull off your left and right ear pad. For further instructions on how to carefully do this please go to this guide here.
      • For each of the red circled screws, take your J000 screwdriver and unscrew the screws.
      • This is a picture of what your headset looks like now that you have done the first two steps and have removed the part that you unscrewed.
      Demander à FixBot
      Ajouter un commentaire
    2. PDP Afterglow Fener LED Replacement: étape 2, image 1 de 2 PDP Afterglow Fener LED Replacement: étape 2, image 2 de 2
      • First remove the battery from the headset, for instructions on how to do this correctly go here
      • Now take your J000 screwdriver and unscrew the screws that have a red circle around them.
      • Now remove the circuit board from the headset and flip it to the other side to be able to see the light/LED.
      Demander à FixBot
    3. PDP Afterglow Fener LED Replacement: étape 3, image 1 de 3 PDP Afterglow Fener LED Replacement: étape 3, image 2 de 3 PDP Afterglow Fener LED Replacement: étape 3, image 3 de 3
      • Take your helping hand with alligator clips and put the printed circuit board on it.
      • This picture is a close up of the LED with the highlighted areas you need to unsoldered.
      • Now take your soldering iron and unsolder those four highlighted areas.
      • Your LED should come loose and you can now put on your new LED.
      Demander à FixBot
Thomas Williams
Membre depuis le 10/22/15
512 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 Membre de l'équipe UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G3
3 membres
15 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 16
Total : 1,095
