Introduction
The back shell of your PDP Rematch Advanced should be replaced if it's damaged or if you want to swap it out for a different color shell. If you need to replace the back shell, take out the motherboard with this guide.
Ce dont vous avez besoin
Orient the controller so the back side is facing you.
Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
Grab the motor and pull away from the back shell. Repeat for both motors.
