Aller au contenu principal
Pour réparer ensemble - Je crée un compte
PDP Rematch Faceplate Replacement
Ce dont vous avez besoin
  1. PDP Rematch Faceplate Replacement, Faceplate: étape 1, image 1 de 2 PDP Rematch Faceplate Replacement, Faceplate: étape 1, image 2 de 2
    • Grip one side of the controller firmly.
    • Insert an opening pick into the crease between the faceplate and the body of the controller.
    • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
    • Carefully move the picks along the controller's crease line until you hear a popping sound.
    • Gently lift off the faceplate by hand.
    Demander à FixBot
    Ajouter un commentaire
  2. PDP Rematch Faceplate Replacement: étape 2, image 1 de 2 PDP Rematch Faceplate Replacement: étape 2, image 2 de 2
    • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
    • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
    Demander à FixBot
  3. PDP Rematch Faceplate Replacement: étape 3, image 1 de 2 PDP Rematch Faceplate Replacement: étape 3, image 2 de 2
    • Gently lift off the hard cover with your hand; it should not need much force.
    Demander à FixBot
Amina Begum
Membre depuis le 01/15/24
282 Réputation
2 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 61
Total : 805
