Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Palm IIIc Button Pad Replacement
Ce dont vous avez besoin
    1. Palm IIIc Button Pad Replacement, Removing broken LCD screen: étape 1, image 1 de 1
      • Keep track of all pieces removed from the device.
      • Gently pull off the device cover. The cover snaps on and off easily where the cover attaches to the Palm IIIc device
      Demander à FixBot
      Ajouter un commentaire
    2. Palm IIIc Button Pad Replacement: étape 2, image 1 de 1
      • Using a Phillips head screwdriver, take out the four screws on the back of the device. You may have to pull them out with your hands once they are unscrewed.
      • There will be two long screws and two short screws. The long screws come from the top of the device, and the short screws come from the bottom of the device.
      Demander à FixBot
    1. Palm IIIc Button Pad Replacement, Remove the Front Cover: étape 3, image 1 de 1
      • Lay Palm IIIc face-up and remove the front cover.
      • Do this firmly but not with too much force so as to not break or disturb anything you're not supposed to.
      Demander à FixBot
    1. Palm IIIc Button Pad Replacement, Button Pad: étape 4, image 1 de 2 Palm IIIc Button Pad Replacement, Button Pad: étape 4, image 2 de 2
      • Using a prying tool, carefully pop button pad out of the cover.
      Demander à FixBot
    2. Palm IIIc Button Pad Replacement: étape 5, image 1 de 1
      • Insert the new button pad where the old one used to be.
      Demander à FixBot
Paulina Trujillo
Membre depuis le 04/07/11
286 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 20-69, Walters Spring 2011 Membre de l'équipe Cal Poly, Team 20-69, Walters Spring 2011
CPSU-WALTERS-S11S20G69
5 membres
40 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 36
Total : 1,748
