Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Palm TX Battery Pack Replacement
Ce dont vous avez besoin
    1. Palm TX Battery Pack Replacement, Back Panel: étape 1, image 1 de 2 Palm TX Battery Pack Replacement, Back Panel: étape 1, image 2 de 2
      • Orient the device so that the display faces forward.
      • Remove the stylus from the right side.
      Demander à FixBot
      Ajouter un commentaire
    2. Palm TX Battery Pack Replacement: étape 2, image 1 de 1
      • Turn over the device so that the back panel faces forward.
      • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
      Demander à FixBot
    3. Palm TX Battery Pack Replacement: étape 3, image 1 de 2 Palm TX Battery Pack Replacement: étape 3, image 2 de 2
      • Rotate the device so that the display faces forward.
      • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
      • Pry along the crevice to loosen the back panel.
      • Repeat this process for the right side.
      Demander à FixBot
    4. Palm TX Battery Pack Replacement: étape 4, image 1 de 2 Palm TX Battery Pack Replacement: étape 4, image 2 de 2
      • Carefully pry the back panel to open the device.
      • Be careful not to break the wire that connects the battery pack to the motherboard.
      • When reassembling, snap the back panel back into place and then insert the top cover.
      Demander à FixBot
    5. Palm TX Battery Pack Replacement: étape 5, image 1 de 2 Palm TX Battery Pack Replacement: étape 5, image 2 de 2
      • Use a plastic opening tool to peel the battery pack from the back panel.
      • The battery pack is glued to the back panel so removing it may require considerable effort.
      Demander à FixBot
    1. Palm TX Battery Pack Replacement, Battery Pack: étape 6, image 1 de 2 Palm TX Battery Pack Replacement, Battery Pack: étape 6, image 2 de 2
      • Use a soldering iron to disconnect the battery wires from the motherboard.
      • For soldering instructions, you can view the Soldering Guide.
      Demander à FixBot
5 autres ont terminé cette réparation.
Spencer Lewson
Membre depuis le 01/19/11
793 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 1-15, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 1-15, Amido Winter 2011
CPSU-AMIDO-W11S1G15
4 membres
28 tutoriels rédigés
1 commentaire de tutoriel
In step 1 - Also remove the cover hinge by sliding downwards
In step 3 - there are actually 2 crevices on the left side of the device. Use the larger, which originally held the cover hinge (the smaller crevice seems to remove the facia)
Jack - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 80
Total : 8,579
