Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Palm TX Display Replacement
Ce dont vous avez besoin
    1. Palm TX Display Replacement, Back Panel: étape 1, image 1 de 2 Palm TX Display Replacement, Back Panel: étape 1, image 2 de 2
      • Orient the device so that the display faces forward.
      • Remove the stylus from the right side.
      Demander à FixBot
      Ajouter un commentaire
    2. Palm TX Display Replacement: étape 2, image 1 de 1
      • Turn over the device so that the back panel faces forward.
      • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
      Demander à FixBot
    3. Palm TX Display Replacement: étape 3, image 1 de 2 Palm TX Display Replacement: étape 3, image 2 de 2
      • Rotate the device so that the display faces forward.
      • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
      • Pry along the crevice to loosen the back panel.
      • Repeat this process for the right side.
      Demander à FixBot
    4. Palm TX Display Replacement: étape 4, image 1 de 2 Palm TX Display Replacement: étape 4, image 2 de 2
      • Carefully pry the back panel to open the device.
      • Be careful not to break the wire that connects the battery pack to the motherboard.
      • When reassembling, snap the back panel back into place and then insert the top cover.
      Demander à FixBot
    5. Palm TX Display Replacement: étape 5, image 1 de 2 Palm TX Display Replacement: étape 5, image 2 de 2
      • Use a plastic opening tool to peel the battery pack from the back panel.
      • The battery pack is glued to the back panel so removing it may require considerable effort.
      Demander à FixBot
    1. Palm TX Display Replacement, Battery Pack: étape 6, image 1 de 2 Palm TX Display Replacement, Battery Pack: étape 6, image 2 de 2
      • Use a soldering iron to disconnect the battery wires from the motherboard.
      • For soldering instructions, you can view the Soldering Guide.
      Demander à FixBot
    1. Palm TX Display Replacement, Motherboard: étape 7, image 1 de 2 Palm TX Display Replacement, Motherboard: étape 7, image 2 de 2
      • Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
      Demander à FixBot
    2. Palm TX Display Replacement: étape 8, image 1 de 2 Palm TX Display Replacement: étape 8, image 2 de 2
      • Lift the mother board out of the device.
      • A weak adhesive attaches the motherboard to the device.
      • The red wire in the picture will not be attached to your device at this point.
      Demander à FixBot
    1. Palm TX Display Replacement, Display: étape 9, image 1 de 1
      • Orient the device sideways, as shown in the picture.
      • Lightly push the front of the display to separate it from the front panel.
      • The battery in the picture will not be attached to the device at this point.
      Demander à FixBot
3 autres ont terminé cette réparation.
Spencer Lewson
Membre depuis le 01/19/11
793 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 1-15, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 1-15, Amido Winter 2011
CPSU-AMIDO-W11S1G15
4 membres
23 tutoriels rédigés
2 commentaires de tutoriel
It's not necessary to unsolder the battery back for this at all, as long as you're careful not to pull on the battery wires, all you have to do is leave it attached and make sure it doesn't move too far from the board.
Justin Clifford - Réponse Partager
This stops with the display supposedly still firmly attached to the motherboard. How is this a display replacement procedure?
W. Lichtenberger - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 39
Total : 3,950
