Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Panasonic DVD-RV31 Player Disc Retainer Replacement
Ce dont vous avez besoin
    1. Panasonic DVD-RV31 Player Disc Retainer Replacement, Disk Tray Cover: étape 1, image 1 de 1
      • Eject the disk tray from the DVD player before removing power supply.
      Demander à FixBot
      Ajouter un commentaire
    2. Panasonic DVD-RV31 Player Disc Retainer Replacement: étape 2, image 1 de 1
      • Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier disassembly of the player.
      Demander à FixBot
    1. Panasonic DVD-RV31 Player Disc Retainer Replacement, Outer Case: étape 3, image 1 de 2 Panasonic DVD-RV31 Player Disc Retainer Replacement, Outer Case: étape 3, image 2 de 2
      • Remove the three screws running along the back edge of case cover.
      • Remove the two screws from each side of the case cover.
      Demander à FixBot
    2. Panasonic DVD-RV31 Player Disc Retainer Replacement: étape 4, image 1 de 1
      • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
      Demander à FixBot
    1. Panasonic DVD-RV31 Player Disc Retainer Replacement, Front Panel: étape 5, image 1 de 2 Panasonic DVD-RV31 Player Disc Retainer Replacement, Front Panel: étape 5, image 2 de 2
      • Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
      Demander à FixBot
    1. Panasonic DVD-RV31 Player Disc Retainer Replacement, Disk Drive: étape 6, image 1 de 3 Panasonic DVD-RV31 Player Disc Retainer Replacement, Disk Drive: étape 6, image 2 de 3 Panasonic DVD-RV31 Player Disc Retainer Replacement, Disk Drive: étape 6, image 3 de 3
      • Locate the four screws securing the disk drive assembly. There are two on each side.
      • Use a narrow screwdriver to remove all four screws.
      • Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
      Demander à FixBot
    2. Panasonic DVD-RV31 Player Disc Retainer Replacement: étape 7, image 1 de 1
      • Lift assembly by the front to pull metal bracket from the power board.
      • Pull up back end and lift drive out.
      Demander à FixBot
    3. Panasonic DVD-RV31 Player Disc Retainer Replacement: étape 8, image 1 de 1
      • With the drive assembly separate from the player, hold as shown and pull the bracket edges away from the disk drive.
      • Lift bracket off and reserve for re-assembly.
      Demander à FixBot
    1. Panasonic DVD-RV31 Player Disc Retainer Replacement, Disc Retainer: étape 9, image 1 de 3 Panasonic DVD-RV31 Player Disc Retainer Replacement, Disc Retainer: étape 9, image 2 de 3 Panasonic DVD-RV31 Player Disc Retainer Replacement, Disc Retainer: étape 9, image 3 de 3
      • Grasp the bridge above the wheel and push the tabs on the side as shown.
      • Pull down firmly and away from the laser housing.
      Demander à FixBot
3 autres ont terminé cette réparation.
Kevin
Membre depuis le 04/26/11
375 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 18-20, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
4 membres
36 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 36
Total : 5,915
