Ce dont vous avez besoin
Remove the plastic hot shoe cover by sliding it towards the rear of the camera.
Turn the camera so the lens is facing down with the rear cover pulled back.
Disconnect the ribbon cable from the camera by pulling up on the black locking tab with an iFixit opening tool.
Pull the ribbon cable from the connector. The rear cover is now completely detached from the camera.
Remove the 4.5mm black Phillips #0 screw under the viewfinder.
Gently pull the viewfinder cover from the camera.
Un commentaire
Is it possible to just remove the viewfinder cover seen on step 8 without anything else? (Provided that I have a screwdriver with a flexible end that can fit in there without messing the screen up). Thanks.
