Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Parrot Skycontroller 2 Joystick Replacement
Ce dont vous avez besoin
    1. Parrot Skycontroller 2 Joystick Replacement, Battery: étape 1, image 1 de 3 Parrot Skycontroller 2 Joystick Replacement, Battery: étape 1, image 2 de 3 Parrot Skycontroller 2 Joystick Replacement, Battery: étape 1, image 3 de 3
      • Flip your controller face down.
      Demander à FixBot
      Ajouter un commentaire
    2. Parrot Skycontroller 2 Joystick Replacement: étape 2, image 1 de 1
      • Remove one 9mm screw using a #4 flathead screwdriver.
      Demander à FixBot
    3. Parrot Skycontroller 2 Joystick Replacement: étape 3, image 1 de 3 Parrot Skycontroller 2 Joystick Replacement: étape 3, image 2 de 3 Parrot Skycontroller 2 Joystick Replacement: étape 3, image 3 de 3
      • Insert the plastic opening tool into the top of the cover and pry upwards to lift the battery cover.
      • Remove the cover by pulling up and out.
      Demander à FixBot
    4. Parrot Skycontroller 2 Joystick Replacement: étape 4, image 1 de 3 Parrot Skycontroller 2 Joystick Replacement: étape 4, image 2 de 3 Parrot Skycontroller 2 Joystick Replacement: étape 4, image 3 de 3
      • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
      • Disconnect the battery from the remote by pressing the white tab and pulling the connectors apart.
      Demander à FixBot
    5. Parrot Skycontroller 2 Joystick Replacement: étape 5, image 1 de 2 Parrot Skycontroller 2 Joystick Replacement: étape 5, image 2 de 2
      • Remove the battery from its brackets by pulling up on the ends of the battery.
      Demander à FixBot
    1. Parrot Skycontroller 2 Joystick Replacement, Joystick: étape 6, image 1 de 1
      • Remove the seven black 11mm screws using the Torx TR6 screwdriver
      • There is a hidden screw located behind the sticker in the battery compartment.
      • Pull back the sticker with your finger nail and remove the one black 11mm screws using the Torx TR6 screwdriver
      Demander à FixBot
    2. Parrot Skycontroller 2 Joystick Replacement: étape 7, image 1 de 3 Parrot Skycontroller 2 Joystick Replacement: étape 7, image 2 de 3 Parrot Skycontroller 2 Joystick Replacement: étape 7, image 3 de 3
      • Remove the seven silver 4mm screws from around the edge of the top plate with the Torx TR6 Screwdriver.
      • The opposite side to the third picture has a screw located on each side of the USB port.
      Demander à FixBot
    3. Parrot Skycontroller 2 Joystick Replacement: étape 8, image 1 de 1
      • Remove the battery compartment plate by pulling up and out.
      Demander à FixBot
    4. Parrot Skycontroller 2 Joystick Replacement: étape 9, image 1 de 1
      • Remove the top plate by pushing out on the corners with your hand.
      • Be careful to not pull too hard on the cable.
      Demander à FixBot
    5. Parrot Skycontroller 2 Joystick Replacement: étape 10, image 1 de 2 Parrot Skycontroller 2 Joystick Replacement: étape 10, image 2 de 2
      • Remove the face plate by pulling up and out.
      • Buttons will fall out when this plate is removed.
      Demander à FixBot
    6. Parrot Skycontroller 2 Joystick Replacement: étape 11, image 1 de 3 Parrot Skycontroller 2 Joystick Replacement: étape 11, image 2 de 3 Parrot Skycontroller 2 Joystick Replacement: étape 11, image 3 de 3
      • Firmly grasp the end of either joystick.
      • Pull the joystick up and out while grasping the other side of the controller.
      • Once both joysticks have been removed, this is what it should look like.
      • Some force may be needed to remove the joysticks.
      • Repeat this process for the other side as well.
      Demander à FixBot
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 27
Total : 770
