Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Philips PD9000 37 Buttons Replacement
Ce dont vous avez besoin
    1. Philips PD9000 37 Buttons Replacement, Buttons: étape 1, image 1 de 1
      • Lay the player flat so the outside casing is facing upwards. Using the screwdriver, unscrew all the case screws on the bottom of the player.
      Demander à FixBot
      Ajouter un commentaire
    2. Philips PD9000 37 Buttons Replacement: étape 2, image 1 de 3 Philips PD9000 37 Buttons Replacement: étape 2, image 2 de 3 Philips PD9000 37 Buttons Replacement: étape 2, image 3 de 3
      • Open the disc flap and unscrew the screws inside. There will be three screws.
      • Using spudger, pry open the disk casing, and pull upwards removing it from the outer casing.
      Demander à FixBot
    3. Philips PD9000 37 Buttons Replacement: étape 3, image 1 de 3 Philips PD9000 37 Buttons Replacement: étape 3, image 2 de 3 Philips PD9000 37 Buttons Replacement: étape 3, image 3 de 3
      • After casing has been detached, there will be a wire connecting the button panel on the disk flap case to the motherboard.
      • To detach this wire, use your fingers and tightly pinch the plastic connector, and gently pull upwards disconnecting it from the motherboard.
      Demander à FixBot
    4. Philips PD9000 37 Buttons Replacement: étape 4, image 1 de 1
      • On the bottom side of the disk flap case, the back of the button panel will be visible. Using a Philips J0 screwdriver, unscrew all 6 screws.
      Demander à FixBot
    5. Philips PD9000 37 Buttons Replacement: étape 5, image 1 de 3 Philips PD9000 37 Buttons Replacement: étape 5, image 2 de 3 Philips PD9000 37 Buttons Replacement: étape 5, image 3 de 3
      • Once unscrewed. gently pull upwards detaching the button panel from the casing.
      Demander à FixBot
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 42
Total : 2,220
