Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Philips SBA1060 Capacitor Replacement
Ce dont vous avez besoin
    1. Philips SBA1060 Capacitor Replacement, Battery Casing: étape 1, image 1 de 1
      • Remove the back cover by sliding it off.
      • Remove the 3 AAA batteries.
      Demander à FixBot
      Ajouter un commentaire
    2. Philips SBA1060 Capacitor Replacement: étape 2, image 1 de 3 Philips SBA1060 Capacitor Replacement: étape 2, image 2 de 3 Philips SBA1060 Capacitor Replacement: étape 2, image 3 de 3
      • Unscrew the nine exterior screws on the back panel using a PH0-size Philips-head screwdriver.
      • A larger screwdriver head and more force may be required for damaged screws.
      • Remove the triangular end piece by pulling it straight off.
      Demander à FixBot
    3. Philips SBA1060 Capacitor Replacement: étape 3, image 1 de 2 Philips SBA1060 Capacitor Replacement: étape 3, image 2 de 2
      • Remove the colored grill by sliding it off in the direction of the removed end piece.
      • Pry off the back battery panel with the plastic opening tool.
      • Be careful to avoid tearing any wires.
      Demander à FixBot
    1. Philips SBA1060 Capacitor Replacement, Capacitor: étape 4, image 1 de 1
      • Remove the two screws on opposite ends of the circuit board with the PH0 size philips head screw driver.
      • Slowly pull the circuit board out of the device
      • NOTE: Be careful not to damage any of the wires protruding from the back of the circuit board.
      Demander à FixBot
    2. Philips SBA1060 Capacitor Replacement: étape 5, image 1 de 2 Philips SBA1060 Capacitor Replacement: étape 5, image 2 de 2
      • Flip the device and remove the battery plug from the circuit board by pulling out the plugs to fully remove back panel.
      • Remove the speaker plugs from the circuit board by pulling out the plugs. They are located on opposite sides of the circuit board.
      • NOTE: When reassembling, note that the speaker with the red wire goes to the red plug, and the speaker with the white wire goes to the adjacent white plug.
      • Remove the light plug from the circuit board.
      • NOTE: This plug is twice as wide as the speaker and battery plugs.
      Demander à FixBot
    3. Philips SBA1060 Capacitor Replacement: étape 6, image 1 de 2 Philips SBA1060 Capacitor Replacement: étape 6, image 2 de 2
      • Locate the capacitor and carefully slide it out of the circuit board.
      • NOTE: The capacitor will be a cylindrical object protruding vertically near the center of the circuit board.
      • Slide the prongs of the replacement capacitor into the two holes of the circuit board where the original capacitor was removed from.
      • Reassemble the speaker.
      Demander à FixBot
April Driscoll
Membre depuis le 10/21/13
321 Réputation
3 tutoriels rédigés
Équipe
Clemson, Team 14-4, Benson Fall 2013 Membre de l'équipe Clemson, Team 14-4, Benson Fall 2013
CLEM-BENSON-F13S14G4
3 membres
12 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 26
Total : 1,066
