Aller au contenu principal
Pour réparer ensemble - Je crée un compte
PlayStation VR LED Light Tracker Replacement
Ce dont vous avez besoin
  1. PlayStation VR LED Light Tracker Replacement, LED Light Tracker: étape 1, image 1 de 3 PlayStation VR LED Light Tracker Replacement, LED Light Tracker: étape 1, image 2 de 3 PlayStation VR LED Light Tracker Replacement, LED Light Tracker: étape 1, image 3 de 3
    • Peel back the rubber covering around the lenses to remove the surrounding plastic eyepieces.
    Demander à FixBot
    Ajouter un commentaire
  2. PlayStation VR LED Light Tracker Replacement: étape 2, image 1 de 2 PlayStation VR LED Light Tracker Replacement: étape 2, image 2 de 2
    • Unscrew four 13 mm screws with a PH #000 screwdriver.
    Demander à FixBot
  3. PlayStation VR LED Light Tracker Replacement: étape 3, image 1 de 2 PlayStation VR LED Light Tracker Replacement: étape 3, image 2 de 2
    • Using the plastic opening tool, carefully pry the white plastic panel free from the side of the headset. Repeat this action for the opposite side.
    Demander à FixBot
  4. PlayStation VR LED Light Tracker Replacement: étape 4, image 1 de 3 PlayStation VR LED Light Tracker Replacement: étape 4, image 2 de 3 PlayStation VR LED Light Tracker Replacement: étape 4, image 3 de 3
    • Use the plastic opening tool to pry the top white plastic panel free from the headset.
    • Do not try to remove the bottom plastic panel. There is a screw attaching it that must be removed first.
    • There may be a small amount of adhesive attaching the top panel to the headset, in which case you may need to use a bit more force to remove the panel.
    Demander à FixBot
  5. PlayStation VR LED Light Tracker Replacement: étape 5, image 1 de 1
    • Flip the headset over.
    • Using a PH #000, unscrew the 7 mm screw found on the bottom of the headset.
    Demander à FixBot
  6. PlayStation VR LED Light Tracker Replacement: étape 6, image 1 de 3 PlayStation VR LED Light Tracker Replacement: étape 6, image 2 de 3 PlayStation VR LED Light Tracker Replacement: étape 6, image 3 de 3
    • Using the plastic opening tool, pry the bottom white plastic panel loose and remove it from the headset.
    • There is adhesive attaching the panel to the headset, in which case it will take more force to remove the panel.
    Demander à FixBot
  7. PlayStation VR LED Light Tracker Replacement: étape 7, image 1 de 3 PlayStation VR LED Light Tracker Replacement: étape 7, image 2 de 3 PlayStation VR LED Light Tracker Replacement: étape 7, image 3 de 3
    • Unscrew the two 7 mm screws from the top of the headset.
    Demander à FixBot
  8. PlayStation VR LED Light Tracker Replacement: étape 8, image 1 de 3 PlayStation VR LED Light Tracker Replacement: étape 8, image 2 de 3 PlayStation VR LED Light Tracker Replacement: étape 8, image 3 de 3
    • Using your fingers, carefully pry the black front panel free from the headset.
    • We recommend that you start the removal from the sides by pulling them forward.
    • There is adhesive holding the front panel in place, which means you will need a bit of extra force to remove it.
    Demander à FixBot
  9. PlayStation VR LED Light Tracker Replacement: étape 9, image 1 de 1
    • Unscrew the four silver 6 mm screws in each corner using a PH #000 screwdriver.
    Demander à FixBot
  10. PlayStation VR LED Light Tracker Replacement: étape 10, image 1 de 3 PlayStation VR LED Light Tracker Replacement: étape 10, image 2 de 3 PlayStation VR LED Light Tracker Replacement: étape 10, image 3 de 3
    • Lift the small silver latch attaching the ZIF (zero insertion force) connector to the circuit board.
    • Carefully pull the end of the white ribbon connector from its slot.
    • Be careful not to damage or dirty the ribbon connector.
    Demander à FixBot
  11. PlayStation VR LED Light Tracker Replacement: étape 11, image 1 de 2 PlayStation VR LED Light Tracker Replacement: étape 11, image 2 de 2
    • Unhitch the yellow led connector ribbon and move it aside.
    Demander à FixBot
  12. PlayStation VR LED Light Tracker Replacement: étape 12, image 1 de 3 PlayStation VR LED Light Tracker Replacement: étape 12, image 2 de 3 PlayStation VR LED Light Tracker Replacement: étape 12, image 3 de 3
    • Carefully pry the black plastic piece attaching the yellow ribbon to the headset away from the green circuit board.
    • Remove the yellow LED ribbons and black plastic connecting piece from the headset.
    Demander à FixBot
Sarah Shand
Membre depuis le 02/20/17
1 996 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team S3-G1, Sullivan Spring 2017 Membre de l'équipe USF Tampa, Team S3-G1, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G1
3 membres
22 tutoriels rédigés
1 commentaire de tutoriel
where can I buy the LED lights for it??
Jordi - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 57
Total : 4,714
