Aller au contenu principal
Pour réparer ensemble - Je crée un compte
PowerBook 3400 M3553 RAM Replacement
Ce dont vous avez besoin
    1. PowerBook 3400 M3553 RAM Replacement, Battery: étape 1, image 1 de 1
      • Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
      Demander à FixBot
      Ajouter un commentaire
    2. PowerBook 3400 M3553 RAM Replacement: étape 2, image 1 de 2 PowerBook 3400 M3553 RAM Replacement: étape 2, image 2 de 2
      • Hold the button on the front left side and slide the battery out.
      Demander à FixBot
    1. PowerBook 3400 M3553 RAM Replacement, Keyboard: étape 3, image 1 de 1
      • With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
      Demander à FixBot
    2. PowerBook 3400 M3553 RAM Replacement: étape 4, image 1 de 3 PowerBook 3400 M3553 RAM Replacement: étape 4, image 2 de 3 PowerBook 3400 M3553 RAM Replacement: étape 4, image 3 de 3
      • Turn the computer over and open the display. You should see that the keyboard is loose.
      • Before attempting to remove the keyboard, note that a ribbon cable connects the keyboard to the logic board. Improper removal may damage your keyboard.
      • Slightly lift the front of the keyboard up, and slide the keyboard towards yourself.
      • Carefully lift the top half of the keyboard and pull it towards yourself.
      Demander à FixBot
    3. PowerBook 3400 M3553 RAM Replacement: étape 5, image 1 de 2 PowerBook 3400 M3553 RAM Replacement: étape 5, image 2 de 2
      • Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
      • Gently remove the ribbons from its tabs.
      Demander à FixBot
    1. PowerBook 3400 M3553 RAM Replacement, RAM: étape 6, image 1 de 2 PowerBook 3400 M3553 RAM Replacement, RAM: étape 6, image 2 de 2
      • Gently wiggle the RAM card to loosen the connection until it pulls free.
      Demander à FixBot
To install the new RAM card, follow these steps in reverse order.
2 autres ont terminé cette réparation.
Michael Mondragon
Membre depuis le 04/12/11
397 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 24-59, Amido Spring 2011 Membre de l'équipe Cal Poly, Team 24-59, Amido Spring 2011
CPSU-AMIDO-S11S24G59
4 membres
63 tutoriels rédigés
1 commentaire de tutoriel
To reattach the keyboard I found it necessary to keep the kid open and push the keyboard all the way down; otherwise, the screws didn’t engage.
Scott - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 42
Total : 3,238
