Aller au contenu principal
Pour réparer ensemble - Je crée un compte
PowerBook G3 Lombard RAM Replacement
Ce dont vous avez besoin
  1. PowerBook G3 Lombard RAM Replacement, Keyboard: étape 1, image 1 de 1
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
    Demander à FixBot
    Ajouter un commentaire
  2. PowerBook G3 Lombard RAM Replacement: étape 2, image 1 de 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
    Demander à FixBot
  3. PowerBook G3 Lombard RAM Replacement: étape 3, image 1 de 1
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
    Demander à FixBot
  4. PowerBook G3 Lombard RAM Replacement, Heat Shield: étape 4, image 1 de 1
    • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
    Demander à FixBot
  5. PowerBook G3 Lombard RAM Replacement: étape 5, image 1 de 1
    • Lift the heat shield up and pull it toward you.
    Demander à FixBot
  6. PowerBook G3 Lombard RAM Replacement: étape 6, image 1 de 1
    • Your laptop should look approximately like this.
    Demander à FixBot
  7. PowerBook G3 Lombard RAM Replacement, PRAM Battery: étape 7, image 1 de 1
    • Pull the battery cable directly up from the logic board.
    Demander à FixBot
  8. PowerBook G3 Lombard RAM Replacement: étape 8, image 1 de 1
    • Remove the battery from its holder by pulling up and to the left.
    Demander à FixBot
  9. PowerBook G3 Lombard RAM Replacement, Modem: étape 9, image 1 de 1
    • Remove the two silver Phillips screws from the modem.
    Demander à FixBot
  10. PowerBook G3 Lombard RAM Replacement: étape 10, image 1 de 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
    Demander à FixBot
  11. PowerBook G3 Lombard RAM Replacement: étape 11, image 1 de 1
    • Disconnect the cable from the right side of the modem.
    Demander à FixBot
  12. PowerBook G3 Lombard RAM Replacement: étape 12, image 1 de 1
    Demander à FixBot
  13. PowerBook G3 Lombard RAM Replacement, Processor: étape 13, image 1 de 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
    Demander à FixBot
  14. PowerBook G3 Lombard RAM Replacement: étape 14, image 1 de 1
    • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
    • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
    Demander à FixBot
  15. PowerBook G3 Lombard RAM Replacement: étape 15, image 1 de 1
    Demander à FixBot
  16. PowerBook G3 Lombard RAM Replacement, RAM: étape 16, image 1 de 1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the RAM chip out.
    • There are RAM slots on both sides of the processor. We recommend installing higher capacity chips on the bottom so that if you want to upgrade later, you won't have to remove the processor.
    Demander à FixBot
6 autres ont terminé cette réparation.
Pièces jointes
iRobot
Membre depuis le 09/24/09
1 Réputation
636 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 15
30 derniers jours : 48
Total : 9,255
