Aller au contenu principal
Pour réparer ensemble - Je crée un compte
PowerBook G4 Titanium DVI DC-In Board Replacement
Ce dont vous avez besoin
    1. PowerBook G4 Titanium DVI DC-In Board Replacement, Battery: étape 1, image 1 de 2 PowerBook G4 Titanium DVI DC-In Board Replacement, Battery: étape 1, image 2 de 2
      • Locate the battery release tab on the underside of the G4.
      • Slide the battery release tab to the left and lift the battery out of the computer.
      Demander à FixBot
      Ajouter un commentaire
    1. PowerBook G4 Titanium DVI DC-In Board Replacement, Lower Case: étape 2, image 1 de 2 PowerBook G4 Titanium DVI DC-In Board Replacement, Lower Case: étape 2, image 2 de 2
      • Remove the seven T8 Torx screws from the lower case.
      • Using your thumbs, slide the lower case toward the front of the computer.
      • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
      • Lift the lower case off.
      Demander à FixBot
    1. PowerBook G4 Titanium DVI DC-In Board Replacement, DC-In Board: étape 3, image 1 de 1
      • Disconnect the large DC-In connector from the right side of the logic board.
      Demander à FixBot
    2. PowerBook G4 Titanium DVI DC-In Board Replacement: étape 4, image 1 de 1
      • Remove the two T6 Torx screws from the DC-In board.
      Demander à FixBot
    3. PowerBook G4 Titanium DVI DC-In Board Replacement: étape 5, image 1 de 1
      • Lift the DC-In board out of the computer by pulling up and away from you.
      • If you don't have a 667 MHz computer, there is a fan in this location which makes it a bit difficult to remove the DC-In board.
      • If there is a fan present, rotate the DC-In board slightly clockwise before easing it out at a slight angle in order to clear the fan clamp on top of it.
      Demander à FixBot
4 autres ont terminé cette réparation.
Pièces jointes
iRobot
Membre depuis le 09/24/09
1 Réputation
635 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 40
Total : 16,114
