Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Protocol Dronium III AP Camera Replacement
Ce dont vous avez besoin
    1. Protocol Dronium III AP Camera Replacement, Drone Battery Pack: étape 1, image 1 de 2 Protocol Dronium III AP Camera Replacement, Drone Battery Pack: étape 1, image 2 de 2
      • Ensure the drone is powered off.
      • Press in and lift battery compartment cover.
      • A soft pry tool may be used for easier access.
      Demander à FixBot
      Ajouter un commentaire
    2. Protocol Dronium III AP Camera Replacement: étape 2, image 1 de 1
      • Remove battery pack from body of drone.
      Demander à FixBot
    3. Protocol Dronium III AP Camera Replacement: étape 3, image 1 de 2 Protocol Dronium III AP Camera Replacement: étape 3, image 2 de 2
      • Disconnect white connectors between the battery pack and drone.
      Demander à FixBot
    1. Protocol Dronium III AP Camera Replacement, Camera: étape 4, image 1 de 1
      • Remove the eight (8) 5mm screws attaching the motor arms to the body using a JIS #00 screwdriver.
      Demander à FixBot
    2. Protocol Dronium III AP Camera Replacement: étape 5, image 1 de 2 Protocol Dronium III AP Camera Replacement: étape 5, image 2 de 2
      • Remove the six (6) 5mm screws attaching the Body Cover to the Body of the drone using a JIS #00 screwdriver.
      • Remove the Body Cover.
      Demander à FixBot
    3. Protocol Dronium III AP Camera Replacement: étape 6, image 1 de 2 Protocol Dronium III AP Camera Replacement: étape 6, image 2 de 2
      • Remove the two (2) 5mm screws attaching the Motherboard to the body of the drone using a JIS #00 screwdriver.
      • Lift the Motherboard off the mounting position.
      • Do not pull hard on the Motherboard as solder connections are fragile.
      Demander à FixBot
    4. Protocol Dronium III AP Camera Replacement: étape 7, image 1 de 1
      Outil utilisé dans cette étape :
      • Remove the tape covering the camera with the tweezers.
      Demander à FixBot
    5. Protocol Dronium III AP Camera Replacement: étape 8, image 1 de 2 Protocol Dronium III AP Camera Replacement: étape 8, image 2 de 2
      • Remove the plastic holding the ribbon cable connector with the tweezers.
      • Be careful with the ribbon cable, it is easy to damage.
      Demander à FixBot
    6. Protocol Dronium III AP Camera Replacement: étape 9, image 1 de 1
      • Move the ribbon cable out of the way with the Spuger.
      Demander à FixBot
    7. Protocol Dronium III AP Camera Replacement: étape 10, image 1 de 2 Protocol Dronium III AP Camera Replacement: étape 10, image 2 de 2
      • Remove the camera by gently prying it out of the bracket with the spudger.
      Demander à FixBot
Steven Mooers
Membre depuis le 10/18/17
401 Réputation
4 tutoriels rédigés
Équipe
UW Tacoma, Team S1-G1, Rose Fall 2017 Membre de l'équipe UW Tacoma, Team S1-G1, Rose Fall 2017
UWT-ROSE-F17S1G1
4 membres
4 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 18
Total : 486
