Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Quick Antenna Connection Check for Delphi MyFi XM2GO
Ce dont vous avez besoin
    1. Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery Cover: étape 1, image 1 de 3 Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery Cover: étape 1, image 2 de 3 Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery Cover: étape 1, image 3 de 3
      • Locate the large button on the top of the device.
      • Push down on the button and slide the cover away from the button.
      • The battery removal tab may pop up.
      Demander à FixBot
      Ajouter un commentaire
    1. Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery: étape 2, image 1 de 3 Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery: étape 2, image 2 de 3 Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery: étape 2, image 3 de 3
      • Grab the red pull tab and pull down to unlock the latch.
      • Pull the battery out.
      Demander à FixBot
    1. Quick Antenna Connection Check for Delphi MyFi XM2GO, Quick Antenna Connection Check for Delphi MyFi XM2GO: étape 3, image 1 de 1
      • Under the battery is a magnetic mat, shown in red, that shields battery interference with the reception of the XM Satellite antenna.
      • This mat is stuck to the back of the device like a sticker and can be removed.
      • CAUTION: Do not operate the device without this magnetic shield.
      Demander à FixBot
    2. Quick Antenna Connection Check for Delphi MyFi XM2GO: étape 4, image 1 de 3 Quick Antenna Connection Check for Delphi MyFi XM2GO: étape 4, image 2 de 3 Quick Antenna Connection Check for Delphi MyFi XM2GO: étape 4, image 3 de 3
      • On the bottom left side of the magnetic mat, the corner can be lifted up to reveal the U.FL antenna connector. A spudger or your fingernails can be used to pry up the corners.
      • These U.FL antenna connections are standard for most portable devices and WiFi cards. They may become detached through use and may be checked if no reception is present.
      • Lift up the corner and notice the two connectors going to the PCB.
      Demander à FixBot
    3. Quick Antenna Connection Check for Delphi MyFi XM2GO: étape 5, image 1 de 2 Quick Antenna Connection Check for Delphi MyFi XM2GO: étape 5, image 2 de 2
      • Both of these connectors must be firmly attached to the PCB. Try pressing them firmly to make sure they are making full contact.
      Demander à FixBot
    4. Quick Antenna Connection Check for Delphi MyFi XM2GO: étape 6, image 1 de 3 Quick Antenna Connection Check for Delphi MyFi XM2GO: étape 6, image 2 de 3 Quick Antenna Connection Check for Delphi MyFi XM2GO: étape 6, image 3 de 3
      • On the top right corner, the magnetic mat can be lifted up to check another U.FL connector as with the 3rd step.
      • This mat can be pressed down again to secure after checking the connector.
      Demander à FixBot
    5. Quick Antenna Connection Check for Delphi MyFi XM2GO: étape 7, image 1 de 1
      • Try pressing down on the U.FL connector, as seen in this picture, to ensure a secure connection.
      Demander à FixBot
Scott Byer
Membre depuis le 03/09/12
88 Réputation
5 tutoriels rédigés
Équipe
Clemson, Team 1-2, Benson Spring 2012 Membre de l'équipe Clemson, Team 1-2, Benson Spring 2012
CLEM-BENSON-S12S1G2
3 membres
27 tutoriels rédigés
1 commentaire de tutoriel
la radio sigue sin funcionar
luis - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 33
Total : 3,456
