Aller au contenu principal
Pour réparer ensemble - Je crée un compte
RCA 8 Apollo Screen Replacement
Ce dont vous avez besoin
    1. RCA 8 Apollo Screen Replacement, Back Panel: étape 1, image 1 de 1
      • Before you begin, discharge your tablet battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your tablet before beginning to disassemble.
      Demander à FixBot
      Ajouter un commentaire
    2. RCA 8 Apollo Screen Replacement: étape 2, image 1 de 2 RCA 8 Apollo Screen Replacement: étape 2, image 2 de 2
      • Insert an iFixit opening tool into the gap between the tablet and back panel.
      • Using a combination of iFixit opening tools and iFixit opening picks, pry the tablet upward around its perimeter to release it from the plastic rear case.
      • If inserted too far, an opening pick can damage your device. It is helpful to mark the edge with an opening pick, or opening tool at a depth that will not damage the inner contents of the tablet.
      Demander à FixBot
    3. RCA 8 Apollo Screen Replacement: étape 3, image 1 de 2 RCA 8 Apollo Screen Replacement: étape 3, image 2 de 2
      • Disconnect the red and black speaker wires from the tablet.
      • The front and back of the tablet will be disconnected.
      Demander à FixBot
    1. RCA 8 Apollo Screen Replacement, Display Assembly: étape 4, image 1 de 3 RCA 8 Apollo Screen Replacement, Display Assembly: étape 4, image 2 de 3 RCA 8 Apollo Screen Replacement, Display Assembly: étape 4, image 3 de 3
      • Release the gold and black tab from the battery that's attached to a gray wire. The gold tab is held down by an adhesive; pull it until the adhesive releases.
      • Remove the yellow tape that is around the battery.
      • Unlock the ZIF socket and detach the display data interconnect cable from the front panel assembly.
      • If the connector is misaligned, the pins can bend, causing permanent damage.
      Demander à FixBot
    2. RCA 8 Apollo Screen Replacement: étape 5, image 1 de 1
      • Remove the three screws from the motherboard using a Phillips screwdriver.
      Demander à FixBot
    3. RCA 8 Apollo Screen Replacement: étape 6, image 1 de 1
      • Remove the battery and motherboard together from the tablet.
      • If the tablet needs a battery replacement, disconnect the battery and replace it with a new one.
      • The battery might be glued down; you will just need to slowly remove the battery as the adhesive releases.
      Demander à FixBot
    1. RCA 8 Apollo Screen Replacement, Screen: étape 7, image 1 de 3 RCA 8 Apollo Screen Replacement, Screen: étape 7, image 2 de 3 RCA 8 Apollo Screen Replacement, Screen: étape 7, image 3 de 3
      • Remove the screw from the bottom left of the tablet.
      • Place an opening tool under the screen.
      • Pry up the screen and it will unclip from the clips holding the screen down.
      • Avoid using too much force to prevent the glass from breaking.
      Demander à FixBot
McKenna Shipper
Membre depuis le 04/12/24
123 Réputation
1 tutoriel rédigé
Équipe
Casper College, Team 1-1, Lareau Spring 2024 Membre de l'équipe Casper College, Team 1-1, Lareau Spring 2024
CASC-LAREAU-S24S1G1
3 membres
4 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 25
Total : 261
