Aller au contenu principal
Razer Blade 15 Advanced Model (Early 2020) RAM Replacement
Ce dont vous avez besoin
  1. Razer Blade 15 Advanced Model (Early 2020) RAM Replacement, Prepare your laptop for disassembly: étape 1, image 1 de 2 Razer Blade 15 Advanced Model (Early 2020) RAM Replacement, Prepare your laptop for disassembly: étape 1, image 2 de 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Razer Blade 15 Advanced Model (Early 2020) RAM Replacement, Unfasten the back cover: étape 2, image 1 de 2 Razer Blade 15 Advanced Model (Early 2020) RAM Replacement, Unfasten the back cover: étape 2, image 2 de 2
    • Use a T5 Torx driver to remove the ten 3.8 mm‑long screws securing the back cover.
  3. Razer Blade 15 Advanced Model (Early 2020) RAM Replacement, Insert an opening pick: étape 3, image 1 de 3 Razer Blade 15 Advanced Model (Early 2020) RAM Replacement, Insert an opening pick: étape 3, image 2 de 3 Razer Blade 15 Advanced Model (Early 2020) RAM Replacement, Insert an opening pick: étape 3, image 3 de 3
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If it feels loose, remove it at any time.
    • Apply a suction handle to the middle of the back cover's right edge, between the lower rubber foot and the middle screws.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  4. Razer Blade 15 Advanced Model (Early 2020) RAM Replacement, Angle the opening pick: étape 4, image 1 de 3 Razer Blade 15 Advanced Model (Early 2020) RAM Replacement, Angle the opening pick: étape 4, image 2 de 3 Razer Blade 15 Advanced Model (Early 2020) RAM Replacement, Angle the opening pick: étape 4, image 3 de 3
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
  5. Razer Blade 15 Advanced Model (Early 2020) RAM Replacement, Free the bottom right corner: étape 5, image 1 de 3 Razer Blade 15 Advanced Model (Early 2020) RAM Replacement, Free the bottom right corner: étape 5, image 2 de 3 Razer Blade 15 Advanced Model (Early 2020) RAM Replacement, Free the bottom right corner: étape 5, image 3 de 3
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  6. Razer Blade 15 Advanced Model (Early 2020) RAM Replacement, Free the front edge: étape 6, image 1 de 3 Razer Blade 15 Advanced Model (Early 2020) RAM Replacement, Free the front edge: étape 6, image 2 de 3 Razer Blade 15 Advanced Model (Early 2020) RAM Replacement, Free the front edge: étape 6, image 3 de 3
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame completely.
  7. Razer Blade 15 Advanced Model (Early 2020) RAM Replacement, Remove the back cover: étape 7, image 1 de 3 Razer Blade 15 Advanced Model (Early 2020) RAM Replacement, Remove the back cover: étape 7, image 2 de 3 Razer Blade 15 Advanced Model (Early 2020) RAM Replacement, Remove the back cover: étape 7, image 3 de 3
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads.
  8. Razer Blade 15 Advanced Model (Early 2020) RAM Replacement, Disconnect the battery: étape 8, image 1 de 3 Razer Blade 15 Advanced Model (Early 2020) RAM Replacement, Disconnect the battery: étape 8, image 2 de 3 Razer Blade 15 Advanced Model (Early 2020) RAM Replacement, Disconnect the battery: étape 8, image 3 de 3
    • Insert the point of a spudger under the middle of the battery connector's long edge.
    • Lift and disconnect the battery press connector from its socket on the motherboard.
    • This will require some force. Don't pry against any resistors or chips.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  9. Razer Blade 15 Advanced Model (Early 2020) RAM Replacement, Remove the RAM: étape 9, image 1 de 3 Razer Blade 15 Advanced Model (Early 2020) RAM Replacement, Remove the RAM: étape 9, image 2 de 3 Razer Blade 15 Advanced Model (Early 2020) RAM Replacement, Remove the RAM: étape 9, image 3 de 3
    • Two metal arms secure the stick of RAM.
    • Simultaneously push out the arms until they disengage and the stick pops up at a slight angle.
    • Remove the stick of RAM.
    • Repeat the same process to remove the other stick of RAM.
    • To install a stick of RAM, insert it into its socket at a slight downward angle and push down firmly until both metal arms lock the stick in place.
Spencer Day
Membre depuis le 09/14/22
95 361 Réputation
662 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
119 membres
19 481 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 29
Total : 719
