Aller au contenu principal
Pour réparer ensemble - Je crée un compte
RedOctane X-Plorer Keys Replacement
Ce dont vous avez besoin
  1. RedOctane X-Plorer Keys Replacement, Rear Case: étape 1, image 1 de 2 RedOctane X-Plorer Keys Replacement, Rear Case: étape 1, image 2 de 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
    Demander à FixBot
    Ajouter un commentaire
  2. RedOctane X-Plorer Keys Replacement: étape 2, image 1 de 3 RedOctane X-Plorer Keys Replacement: étape 2, image 2 de 3 RedOctane X-Plorer Keys Replacement: étape 2, image 3 de 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
    Demander à FixBot
  3. RedOctane X-Plorer Keys Replacement: étape 3, image 1 de 3 RedOctane X-Plorer Keys Replacement: étape 3, image 2 de 3 RedOctane X-Plorer Keys Replacement: étape 3, image 3 de 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
    Demander à FixBot
  4. RedOctane X-Plorer Keys Replacement, Keys: étape 4, image 1 de 3 RedOctane X-Plorer Keys Replacement, Keys: étape 4, image 2 de 3 RedOctane X-Plorer Keys Replacement, Keys: étape 4, image 3 de 3
    • Use a screwdriver to remove the 10 mm Phillips #1 screws from the key sensor board.
    • Lift up on the key sensor board to remove it from the guitar neck.
    • When using the screwdriver, make sure to avoid puncturing the wires.
    Demander à FixBot
  5. RedOctane X-Plorer Keys Replacement: étape 5, image 1 de 1
    • Using your fingers, remove the rubber pad to expose the colored keys.
    Demander à FixBot
  6. RedOctane X-Plorer Keys Replacement: étape 6, image 1 de 2 RedOctane X-Plorer Keys Replacement: étape 6, image 2 de 2
    • Reach one finger under the guitar to push the key out of the casing.
    • Repeat this step for the four remaining keys.
    Demander à FixBot
3 autres ont terminé cette réparation.
Ashley Slocum
Membre depuis le 04/18/18
228 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S17-G1, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
3 membres
9 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 19
30 derniers jours : 41
Total : 4,853
