Introduction
Remplacez une batterie morte avec ce tutoriel.
Outils
Pièces
Vidéo d'introduction
Dévissez les dix vis suivantes :
Deux vis Pentalobe 5 points de 8 mm
Huit vis Pentalobe 5 points de 2,5 mm
Saisissez la languette en plastique transparent attachée au connecteur de la batterie et tirez-la vers le bord avant de l'Air pour déconnecter la batterie de la carte mère.
Pour remonter votre appareil, suivez les mêmes instructions dans l'ordre inverse.
Annulation : je n'ai pas terminé ce guide.
143 autre(s) ont terminé cette réparation.
Merci à ces traducteurs :
75%
Claire Rapp nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
9 commentaires
I received the batter for my late 2010 in good order. The instructions were easy to follow and the replacement went well. The two tools mentioned are a must - the P5 pentalobe and T5 torx.
My disappointment is that the battery from iFixit is, in fact, not new. No, it has not been used and shows 6700 mAh design capacity. However, Coconut Battery reports the manufacture date of the battery as 12-14-2011 or 1134 days. Also, I am getting 4-6 hours when I expected 5-7. What is the shelf life of an unused battery?
Perhaps iFixit may wish to change the battery description from "Brand New" to "Never Used" and put the manufacture date.
Thanks
Great post and thanks for this tips.
see more : http://www.geeksonsite.co.nz/
My battery arrived today and I was able to install it in about 30 minutes (I have not done this before). My Mac is up and running and the battery has charged up and is in use.
Thanks for all the help.
SG 03/22/2017
I followed this instructions. Everything is fine except that I cannot fully insert the pull tab back into the battery connector. How hard do you have to push ? Does it have to make a click ?
