Aller au contenu principal
Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013
Ce dont vous avez besoin
  1. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013, Boîtier inférieur: étape 1, image 1 de 1
    • Ôtez les dix vis suivantes, qui fixent le boîtier inférieur au boîtier supérieur :
    • Deux vis Pentalobe P5 de 2,3 mm
    • Huit vis Pentalobe P5 de 3,0 mm
    • Tout au long de cette réparation, prenez note de l'emplacement de chaque vis, et assurez-vous qu'elle retrouvera sa place initiale pour éviter d'endommager votre appareil.
    For all the screws you use the P5 pentalobe screwdriver?
    Carlos - Réponse
    Pentalobe is only for the screws on the bottom cover. The Torx screw driver is for the remainder.
    Fredrik -
    I never, ever, ever considered using anything but the correct tool on the Pentalobe screws. Too easy to strip and void your warranty (if still in effect), as well as make it almost impossible to get inside later for another upgrade or repair. The Wiha P5 Pentalobe screwdriver fits like a glove and costs only about $11 (a fraction of your drive's price)at Amazon.com. Get it!
    marketing - Réponse
    I followed this exactly and was able to replace my broken trackpad. I did not have to replace the ribbon OR the battery. However I would suggest getting the ribbon since it’s fairly cheap, as for the batteries I was able to do it with a card only. I didn’t use any heat or the liquid but it takes some time. You really have to work the card in there to release the glue. Also you must be very careful not to bend the batteries or damage them, if you do you must replace with new. This took me about 1.5hrs and my computer works like new. Apple cost for this job was around $450, I did it for $120. Big ups to ifixit for this awesome tutorial, tool set and parts!
    On a side note, only use quality tools, the cheap ones will break or strip the screws.
    Dustin Steward - Réponse
    Note that the eight 3mm screws have a shoulder under the head, while the two 2.3mm screws are “full thread”, i.e., there is no shoulder under their heads. It’s important to put the two screws with no shoulder at the hinge of the cover.
    All ten screws require a P5 Pentalobe screwdriver, preferably with a magnetized tip to help hold and position the screw.
    All of the screws have blue “Loctite” thread locker compound on their threads. This is to help prevent the screws from working loose and falling out. Don’t attempt to clean the Loctite from the screws — leave it in place, and it will continue to help prevent the re-inserted screws from working loose.
    When replacing the bottom cover, it is a good technique to insert and BEGIN tightening all ten screws BEFORE fully tightening any one screw. After all the screws have been started, then go around and finish tightening all of them. By doing this, you make it easier to feel that each screw has been started properly, and is not “cross-threaded”.
    doubleclutch - Réponse
    This is what I found on my MBP mid-2014 13” Retina. All 10 used the same screwdriver. I didn’t see the blue “loctite” but I also got my computer refurbished.
    Evan Shulman -
    A good technique for starting to thread the screws when replacing them is to position and align the screw, and with the driver, gently turn the screw in the REMOVAL direction until you feel and hear a slight click. This click happens when the leading thread of the screw drops off of the leading edge of the thread in the hole — this is the point at which the threads are properly positioned for engagement. You can now turn the driver and screw in the TIGHTENING direction. This technique will help prevent accidental “cross-threading” of the screw, which will damage the threads permanently.
    Note that this is a useful technique when installing ANY threaded fastener.
    Hi peeps,
    I have a wifi problem on this MBP 13” early 2015 and was pleasently surprised to find your guide to changing the airport card.
    However upon closer inspection it seems that on my MBP (purchased new or so I thought) the 3 antennae seem so have been soldered together at the point where they are clamped to the chassis. I have photos but cannot post here. Can anyone conform that where the 3 antennae wires are held to the chssis by the 2 scew metal support (just before disappearing into the screen hinge), the support is not meant to short the 3 wires together. This makes no sense for 3 seperate antennae wires.
    Any advice /close up photos is welcome here.
    dom
    colonel mustard - Réponse
    Tip: Use post-it notes to keep track of screws
    1. Pack of post it notes
    2. Stick screws to the sticky part of the post it note
    3. Write on the post it note which step and what kind of screw it is
    ibash - Réponse
    Hi, in order to drain the battery I am running:
    yes > /dev/null
    in 4 terminals, so the CPU maxes out at almost 99%.
    I hope this speeds up the battery draining process.
    And the backlight is at maximum brightness :-)
    You can see the cpu load in Activity Monitor.
    Its draining at 20% per 15 minutes.
    Any concerns about draining the battery in this way?
    Andre van der Ham - Réponse
    Something I’ve been curious about, is it possible to upgrade a late 2013 Retina model MacBook Pro, with the improved 16gb ram and i7 processor logic board from the 2015 retina model? I’d be interested to try but not ready to shell out the $500+ to be the first lol
    Chat Dawgie - Réponse
    Without rehashing what others have said, I would highly recommend reading through the steps *and* the comments for each before tackling your replacement for tips. Highlights for me were: only disconnecting what actually needed to be disconnected, rotating the spudger to release the track pad cable, a hair dryer worked perfectly fine, and the pencil outline of the battery before you remove. You got this!
    N DesRochers - Réponse
    Installation of replacement AirPort card was easier than I had expected thanks to this guide. Thank you.
    chaslaw - Réponse
    I use replaced SSD and it was super easy and working great. I can finally upgrade Mac OS with plenty of room to spare and no more low memory alerts. Well worth investment and didn’t have to buy new laptop
    Pete James - Réponse
    It's interesting that this tutorial is rated Moderate even though you need to remove the battery. The battery removal tutorial which is basically the same but with fewer steps is rated Difficult.
    Marv Ruona - Réponse
    when i pulled the screws out i arranged them in the same way they were in. the top 2 middle screws appeared to be shorter than the rest. in order to keep them in place i got a square of packing tape sticky side up, taped both sides down with 2 other pieces of tape. and then put the screws head down in the order i pulled them.
    Jason Wade - Réponse
    Excellent instructions although checking battery and speakers aligned before fixing batteries into place is essential. MacBook good as new!
    John Foreman - Réponse
    I find it helpful to spread a soft, slightly fuzzy cloth (like flannel) over my workspace before doing something with small parts. It keeps screws and things from rolling or bouncing away. A towel might be too plush, though, as a screw might get lost in it.
    Richard KeslerWest - Réponse
    I cannot get the two screws (that are different than the other ones) out and now they’re stripped. Any idea what to do without using a drill?
    Honeybee94 - Réponse
    DO NOT REMOVE SPEAKER CABLES!! The connectors are fragile. Just remove speakers and bend attached cable away from battery. Same for trackpad cable connector at front side. This cable crosses the middle of the battery. Just remove the one connector on the back side - leave front side connector attached and fold cable toward front of computer out of way of battery.
    Paul Lebow - Réponse
  2. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 2, image 1 de 1
    • Glissez vos doigts entre le boîtier inférieur et le boîtier supérieur.
    • Séparez avec précaution les deux boîtiers, soulevez et retirez le boîtier inférieur.
    This takes a bit more effort than you might expect. Put your fingers where shown and lift about 3inches. With enough upwards pressure the plastic holders will “pop free” and the bottom will come off easily.
    hamiltont - Réponse
    To reattach bottom case I found it helpful to line fingers up with clips under case should snap easily
    Peter Stoll - Réponse
    If your old battery has swollen, the lower case may “pop” open. Don’t lose your screws!
    Maxine Loveman - Réponse
  3. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 3, image 1 de 2 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 3, image 2 de 2
    • Le boîtier inférieur est attaché au boîtier supérieur par deux attaches en plastique au milieu.
    • Lors du remontage, appuyez doucement sur le milieu du boîtier inférieur pour que les deux attaches s'enclenchent à nouveau.
    This wording I found quite confusing. They just mean when putting the lid back on that you just removed in the previous step, push here.
    Mmm ttt - Réponse
    I took my pointer and thumb (which are luckily long enough) to feel where the studs are on the back panel, and then as I put the back panel back on, I pushed in the spot I had marked with my fingers to ensure I was applying pressure only on this part.
    Evan Shulman - Réponse
    If you’re doing an iFixIt battery replacement, the replacement battery has two rubber nubs which are right where the clips are that receive these studs. Folks have been saying it’s hard to get the studs to clip back in after replacement, and I had the same issue. I trimmed the top of these rubber nubs, which are a bit bigger than those on the original battery, with some side cutters. That made the fit much better.
    Rob Gorbet - Réponse
  4. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013, Connecteur de batterie: étape 4, image 1 de 1
    • Si nécessaire, retirez le cache en plastique couvrant la carte de contact de la batterie.
    A plastic foam cover also covers plug and socket and the whole battery. It is easy to remove it from the right side to the trackpad wire that the battery plug is free like shown in the picture. I kept it to use it again later.
    Daniel Brehm - Réponse
    I have done tons of these battery replacements.
    You don’t need to do anything on the list after you disconnect the battery, apart from carefully moving the speakers out of the way, and then prise up the battery modules. I just very carefully, and with little even motions, use a large slot screwdriver. Being careful to keep it flat, to not puncture the battery.
    Easy peasy. I have never had an issue after dozens of the tasks…
    davelarose - Réponse
    Dear Sir,
    as you seem to be very much experienced with battery replacements you might perhaps give me a hint why after having removed the battery pack successfilly, the keyboard doesn't work anymore after booting the system. The Touchpad works, the keyboard backlight works but typing does not function at all.
    I only disconnected the battery connector and touched nothing else. I am quite desperate …
    Gerd Uyan -
    I agree with Dave la Rose, provided you use heat rather than solvent to remove the old battery (or possibly floss, haven’t done that). Please see my comment further down this thread on how to use an iOpener for correctly heating the glue joint
    I. Margaronis - Réponse
    After removing battery contact board plastic. My screwdriver accidentally fell and touched the battery board. And it short circuited. Now my battery doesn't charge. My laptop doesn't work without charger now. shuts after a few minutes of use. Can i fix it without sending it for repairs?
    Phillip Ngwenya - Réponse
    Is replacing the battery necessary?
    Ralph Louis - Réponse
    How do we know if it's necessary to replace the plastic cover adhered to the battery contact board?
    What are the factors that would require that?
    Lux - Réponse
  5. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 5, image 1 de 2 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 5, image 2 de 2
    • Avec l'extrémité plate d'une spatule (spudger), tirez le connecteur de la batterie tout droit hors de sa prise sur la carte mère.
    • Assurez-vous de faire levier uniquement sur le connecteur et non pas sur sa prise, sinon vous risquez d'endommager irréversiblement la carte mère.
    I have a friends MacBook Pro that has some water damage that caused the MacBook not to be able to use battery power, but still work when plugged into A/C. Upon further inspection I can see visible corrosion on a few of the 9 cables going from the battery connector to that small circuit board. Is it possible to just replace that circuit board?
    jramsey21 - Réponse
    Sometimes it can be enough to just clean the contacts without having to replace the entire board. Dosent work for complicated IC's like plcc type, where corrosion is underneath the chip. Here you will have to reheat and reapply the IC.
    andrehedegaard -
    When placing the battery connector back into the socket on the logic board, check that every part of connector is pressed down. You should hear a soft click when it's back in place.
    Ethan Tarquin - Réponse
    +1
    I thought I made sure it was connected but when running the computer it only detected the battery but couldn’t power it. I had to run with power adapter. Also it didn’t charge. I guess some pins were connected but not all. To verify that all were connected I removed the plastic cover, placed it carefully completely flat, and then reattached the plastic cover. After that it worked!
    Jonas Ehrs -
    Removing the battery connector took a bit of finagling. It wasn’t as easy as one would think. Be very careful when doing this as they warn to not damage it. Otherwise great instructions!!!!
    Peppon - Réponse
    Lift from the long, flat side, not the shorter side. In this picture, you should lift from the NORTH part of the connector, not the WEST side like they are doing. This is because you can spread the pressure from lifting the connector across more area, as compared to the side. I accidentally broke off part of my battery connector lifting it up the way shown, but was able to do it the way I described without problem. Make sure to lift from the wide part so you don’t have my same trouble!
    Jaden Salama - Réponse
    The connector is no more than 1mm thick… the socket is 3-to-4mm deep so make sure you’re trying to remove the connector itself, and not pulling at the socket.
    Richie Egg - Réponse
    Thank you Richie I was trying to lift the socket.
    be careful the little square block is actually made of 2 parts and you only have to lift the upper part as Richie said
    ilyes - Réponse
    You can do it from the side like the picture, but i would recommend twisting almost like a screw driver once you have leverage under the overhanging part of the left side like in the picture. Twist the tool so that it starts to put pressure on the top, until you’ll hear it click out. You can be somewhat forceful but it shouldn’t require a lot of strength. Guiding the tool with one hand and twisting with the other is a good way to attempt this.
    Colin Nowers - Réponse
    After I put the battery back I found out at this step that the new battery connector was off by 2 mm (because I installed my battery slightly off). Since the connector is rigid, I removed it’s plastic cover (just like we all did in Step 4) to free the cable, which allowed me to bent it enough to properly plug the connector.
    Marc - Réponse
    Simple question: why we need to do this, I mean, disconnect battery from main board?
    Bin Zhu - Réponse
    Well, I’m reading this step in the battery replacement repair guide, so it’s pretty critical to disconnect the battery from the main board. I’m guessing these steps are reused in other guides where disconnecting the battery might not be such an obvious need.
    surf -
    Also wondering the same. I came here from a link to replace the fan. Is it necessary to disconnect the battery inorder to replace the fan?
    Chris Andrews -
    The connector wires from the battery to the connector are long
    You'll have to bend them downward and into the small cove that exists so the connector can fit in place.
    So use the a plastic card or flat end of the spudger to bend them downward and folded a bit back so the connector will fit in place.
    Use your old battery as a guide for how they should be bent.
    RON BUENO - Réponse
    Hi All ,
    I followed the instructions step by step and changed the board successfully and reconnected everything back. When I powered it back on I can see it is charging again however it just displays a black screen and no display. Keyboard light comes on as well and the apple logo light on the back lid also turns on. Not sure what is wrong ? It has been charging for more than 15 minutes and still no joy. Anyone able to help solve or identify the issue .
    Thanks
    Kaleem - Réponse
    The connector cover is slightly wider and longer than the socket (<1mm) so there is a small "lip" around the top that can be used to lift it.
    If your are not familiar with those repairs, and as with most of those connections, I recommend to take the time to observe your computer and the pictures from the tutorial, reading instructions and comments before starting each step. This battery connector needs both a bit of force and of precision. For a battery repair the connection of the new battery is a bit more tricky, you need to have your battery in the right position and to force it a bit the connector
    David Obis - Réponse
    Hi, I only want to remove/examine/possibly replace the left speaker as it's crackling..........I don't think I need to remove the battery connector to the logic board?
    Mickeytix - Réponse
  6. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 6, image 1 de 1
    • Pliez le connecteur de la batterie vers le haut afin d'éviter tout contact accidentel avec la prise pendant la réparation.
    If you miss or let this step for later like I did, the power left in the battery even though the computer is completely shut down, will screw up the I/O board cable like I did. I noticed this after I put all the pieces back, turn the computer on and surprise, no wifi hardware is detected. -.-
    sebasgaes - Réponse
    I put a small piece of blue painters tape on the battery connector contacts to prevent it from accidentally making a connection and shorting. This helped keep things a bit more protected.
    LaymanLab - Réponse
    @sebasgaes, shoot, I'm only part way through the process, but I skipped this step thinking it wasn't necessary. I'm only through step 12 right now, but is there a fix if my machine doesn't recognize the wifi hardware after I've put it all back together? I don't see reference to the "I/O board cable" anywhere else in the instructions, so I'm confused about your mention of that...
    jiclark - Réponse
    UPDATE: I completed the job, rebooted, and all is well, wifi and all. Thanks anyway; gotta love iFixIt!!
    jiclark -
  7. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013, Dissipateur thermique: étape 7, image 1 de 3 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013, Dissipateur thermique: étape 7, image 2 de 3 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013, Dissipateur thermique: étape 7, image 3 de 3
    • Enlevez doucement la protection en caoutchouc du ventilateur qui se trouve au bord du dissipateur thermique.
    • La protection du dissipateur thermique est enroulée autour du dissipateur et s'ajuste dans des fentes dans le conduit de ventilation. Durant le ré-assemblage, assurez vous de bien ajuster les encoches dans les encoches du conduit de ventilation.
    For reassembly, I found it easier to loosen the lone top left 2.4 mm Phillips #000 before putting the fan bumper back in.
    Boston Hampton - Réponse
    I don’t think you need to remove the heat sink for this
    Mike C - Réponse
    Fran Werttt - Réponse
  8. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 8, image 1 de 2 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 8, image 2 de 2
    • Utilisez la spatule (spudger) pour enlever les patins en mousse des vis fixant le dissipateur thermique.
    How should I reapply those little foam stickers? I guess not with normal glue.
    bboy.sidekick - Réponse
    I found that the adhesive came up with the foam except for one screw. The adhesive just stuck to the head of the screw so I left it intact as much as possible and just pressed the foam back on. It doesn’t take much to keep them in place.
    Ryan Sooley - Réponse
    If the new Logc Board coms with a heat sink attached, It is not necessary to remove the old one. Just unscrew the screw in the left corner of the heat sink and screws of the fan as well.
    Viktor Simeonov - Réponse
    Est-ce grave si on les a perdu ?
    Louis BONIN - Réponse
    The tiny rubber foam stickers help to keep the distance between the aluminium back cover and the black heat sink. I would recommend to install them or look for something similar.
    dvelasquez - Réponse
  9. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 9, image 1 de 1
    • Ôtez ces différentes vis fixant le dissipateur thermique à la carte mère :
    • 4 vis T5 de 2,6 mm
    • 1 vis cruciforme #000 de 2,4 mm
    The cross-head screwdriver bit was not the #000, the #00 was the right one.
    Benjamin Hug - Réponse
    For my mac, the cross-head screwdriver bit was not the #000, was the T5
    maestrorafael - Réponse
  10. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 10, image 1 de 2 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 10, image 2 de 2
    I bought all the tools necessary from iFixit except for the cleaning solutions for this step. You can just use isopropyl alcohol with a microfiber cloth to clean the thermal paste off before re-applying a new coat.
    Totally forgot the thermal paste when I bought the replacement fan. Then I needed to wait 2 days for some arctic silver 5 to arrive. All worked well in the end. I combined it with the batterie replacement, worked well together.
    Daniel - Réponse
  11. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013, Ventilateur: étape 11, image 1 de 2 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013, Ventilateur: étape 11, image 2 de 2
    • Utilisez la pointe d'un spudger pour pousser de chaque côté du connecteur de la nappe de la caméra iSight pour le faire sortir de sa prise sur la carte mère.
    I found this to be the most difficult step. There is a need to get positioned so that you have the leverage to push hard enough at exactly the point shown in the photo without risking slipping and perhaps damaging the CPU nearby
    Tony M - Réponse
    Very helpful tip from Tony.
    Thomas Sturgill - Réponse
    I used two tools simultaneously. A spudger and a pic like spudger to walk it out.
    lucas - Réponse
    Man muss den Stecker aus der Steckverbindung herausschieben, und nicht darauf drücken . In der englischsprachigen Anleitung steht auch push und nicht etwa press…
    Holger - Réponse
    There are 2 black tabs either side - force them towards the back of the back of computer. It seemed to pop out super easily just doing it gently.
    Josh - Réponse
    This step is very difficult. With care it could be omitted. After detach the cable from the glue on the back cover of fan, there is enough clearance to take the fan assembly out with a little pivoting, just be careful and don’t put too much stress on the table where it make a 90 downward turn to the connector. Reinstalling is just reverse and doable as well.
    Xiaokun Xu - Réponse
    After readying all, trying Josh’s tip with no joy, I found that two nice sized fingernails made this easy x 2! Just push on each little indent simultaneously.
    Ross Elkins - Réponse
    Thanks Ross! This was my 2nd time every opening a laptop and using two finger nails to push on the little indents worked amazing!
    Carolyn Wang - Réponse
    I pulled the cable directly and it got off easily.
    When assembling it,just used two fingernail on two sides of the plug and pushing it back。
    After all these,checked iSight working well。
    Junjie2021 - Réponse
    Is there any hope for me? I did this step wrong and the connector came off the motherboard. Can that piece be glued back in place?
    Leslie Nuss - Réponse
    I did this with the help of some sturdy toothpicks :)
    KamFix - Réponse
  12. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 12, image 1 de 2 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 12, image 2 de 2
    • Décollez la nappe de la caméra iSight du boîtier du ventilateur pour la replier de côté.
  13. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 13, image 1 de 3 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 13, image 2 de 3 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 13, image 3 de 3
    • Utilisez la pointe d'un spudger pour retourner la languette sur le connecteur ZIF du ventilateur.
    • Tirez délicatement le nappe du ventilateur tout droit hors de sa prise.
    my cable was glued, had to be pryed up first.
    maccentric - Réponse
    I found it a bit difficult to know exactly when the new one is back in position.
    steffen - Réponse
    Take a close look at the spacing in the 3 photos. You essentially just flip the tab 90 degrees to stay vertical, then you pull the cable carefully out. When putting the new one in, no need to press hard. Just a little bit so you have that 2-3 mm spacing and then flip the tab back down.
    Daniel - Réponse
    During reassembly, before screwing down the fan, it is best to reinsert and lock down this cable.
    LSD - Réponse
  14. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 14, image 1 de 1
    • Retirez les vis suivantes fixant le ventilateur au boîtier supérieur :
    • Une vis Torx T5 de 5,0 mm
    • Deux vis Torx T5 de 3,6 mm
    When reinstalling, do the screw closest to the front of the computer first.
    Steve Wechsler - Réponse
    I second this advice as I screwed the fan in first and then tried to plug the cable in and the angle required to get it in put too much tension and the plug separated from the cable (very fragile). So now I had to order a new one.
    Joe Healy - Réponse
  15. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 15, image 1 de 3 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 15, image 2 de 3 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 15, image 3 de 3
    • Soulevez l'extrémité du ventilateur la plus proche de la charnière de l'écran et retirez le ventilateur du boîtier supérieur.
    Um, this guide should include steps for applying thermal paste, including instructions to clean the mating surfaces, and pictures showing how much thermal paste to use.
    TheIronGiant - Réponse
    Hi @theirongiant, there are generic thermal paste application instructions linked in the introduction “Don't forget to follow our thermal paste application guide before you reinstall your heat sink.”
    Sam Goldheart -
    Make sure to put the end furthest away from the hinge under the ribbon cable first.
    Then place the hinge side. The screw furthest away from the hinge is partially obscured by the ribbon cable.
    If not placed correctly, ribbon cable damage may result.
    toodarkpark - Réponse
    Thanks to toodarkpark, it’s the priority to connect the cable of Fan before place it on position completely.
    If reverse the step, it will become ALMOST IMPOSSIBLE to insert the cable.
  16. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013, Ensemble carte mère: étape 16, image 1 de 2 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013, Ensemble carte mère: étape 16, image 2 de 2
    • Retirez les deux vis Torx T5 de 2,1 mm fixant le cache de la nappe de la carte E/S sur la carte mère.
    • Retirez le cache de la nappe de la carte E/S.
  17. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 17, image 1 de 2 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 17, image 2 de 2
    • Utilisez l'extrémité plate d'un spudger pour faire sortir le connecteur de la carte E/S tout droit hors de sa prise sur la carte mère.
    • Veillez à faire seulement levier sur la nappe de la carte E/S et non sur la prise même, vous risqueriez d'endommager votre carte mère.
  18. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 18, image 1 de 2 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 18, image 2 de 2
    • Soulevez la nappe de la carte E/S du côté de la carte mère et repliez-la de côté.
    • Pour éviter d'endommager la nappe, pliez-la seulement au niveau du coude de la nappe du côté de la carte E/S.
  19. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 19, image 1 de 2 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 19, image 2 de 2
    • Utilisez la pointe d'un spudger pour soulever le connecteur du haut-parleur droit tout droit hors de sa prise sur la carte mère.
  20. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 20, image 1 de 2 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 20, image 2 de 2
    • Avec la pointe d'un spudger, appuyez sur les deux côtés du connecteur de carte E/S pour le faire sortir de sa prise sur la carte mère.
    Having a hard time at this step. Any suggestions? it's just not walking out.
    Moki - Réponse
    Use your fingernails to pinch the sides of the clip inwards to release the connector. I couldn’t walk it out either, both sides needed to be pushed in simultaneously to pull it out of the socket.
    Do not pull from the cables end. you will risk separating thin cables from connector head. Use spudger tip to push it out.
    Macrepair SF - Réponse
  21. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 21, image 1 de 3 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 21, image 2 de 3 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 21, image 3 de 3
    • Utilisez l'extrémité plate d'un spudger pour débrancher la nappe du rétro-éclairage du clavier et l'enlever de la carte mère.
  22. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 22, image 1 de 3 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 22, image 2 de 3 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 22, image 3 de 3
    • Saisissez la languette en plastique noir pour ouvrir le connecteur du câble de l'écran et tirez-le tout droit de sa prise sur la carte mère.
  23. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 23, image 1 de 2 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 23, image 2 de 2
    • Tirez délicatement le connecteur de la carte DC-In tout droit hors de sa prise sur la carte mère.
  24. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 24, image 1 de 3 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 24, image 2 de 3 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 24, image 3 de 3
    • Calez l'extrémité plate d'un spudger sous la nappe du haut-parleur gauche près du connecteur, soulevez-la tout droit hors de sa prise et repliez-la de côté.
  25. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 25, image 1 de 2 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 25, image 2 de 2
    • Si nécessaire, retirez toute bande adhésive qui recouvre le connecteur ZIF de la nappe du microphone.
  26. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 26, image 1 de 3 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 26, image 2 de 3 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 26, image 3 de 3
    • Utilisez la pointe d'un spudger pour retourner le clapet de retenue sur le connecteur ZIF de la nappe du microphone.
    • Tirez la nappe du microphone tout droit hors de sa prise sur la carte mère.
  27. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 27, image 1 de 3 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 27, image 2 de 3 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 27, image 3 de 3
    • Si nécessaire, retirez toute bande adhésive qui recouvre le connecteur de la nappe du clavier.
    • Utilisez la pointe d'un spudger pour retourner le clapet de retenue sur le connecteur ZIF.
  28. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 28, image 1 de 2 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 28, image 2 de 2
    • Tirez la nappe du clavier tout droit de sa prise ZIF sur la carte mère.
  29. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 29, image 1 de 3 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 29, image 2 de 3 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 29, image 3 de 3
    • Si nécessaire, retirer toute bande adhésive qui recouvre le connecteur de la nappe du trackpad.
  30. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 30, image 1 de 2 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 30, image 2 de 2
    • Tirez la nappe du trackpad tout droit hors de sa prise sur la carte mère.
    I didn’t pay enough attention when I pulled the ribbon cable out, so trying to figure out how to reattach it was quite challenging for me. After searching unsuccessfully for videos/instructions on how to reattach, I finally figured out that the ribbon cable goes UNDER the black plastic part of the socket (closest to the ribbon), and then you push the little tab down to hold it in place. Hope this helps others who are struggling with this part. Otherwise, this was an amazing tutorial, and saved my macbook…
    CRI - Réponse
  31. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 31, image 1 de 1
    • Retirez les cinq vis Torx T5 3,5 mm fixant la carte mère au boîtier supérieur.
    • Lors du remontage, installez les cinq vis sans les serrer, positionnez la carte mère, puis serrez-les uniformément.
  32. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 32, image 1 de 3 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 32, image 2 de 3 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 32, image 3 de 3
    • Soulevez légèrement la carte mère du côté du processeur et tirez-le vers l'emplacement du ventilateur pour dégager les ports du rebord du boîtier supérieur.
    • Retirez la carte mère.
    • Lors de la réinstallation, assurez-vous que les nappes du clavier, du rétro-éclairage du clavier, MagSafe et du microphone ne sont pas coincées sous la carte mère.
    • Assurez-vous également de faire glisser les dispositifs EMI métalliques des ports sous le côté du boîtier et non au-dessus.
  33. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013, Carte mère: étape 33, image 1 de 1
    • Retirez la seule vis Torx T9 de 2,9 mm fixant le SSD à la carte mère.
    It looks like this picture is not a 820-4924-A motherboard (A1502 2015 13in. MBPr). It must come from a previous version of Macbook pros. Don’t panic if the RAM chips on the top right corner do not look exactly the same on your board and on this picture.
    AlexFixeurs - Réponse
    The screw on my disk is ruined, i cant remove it, any suggestions?
    dieyoung79 - Réponse
  34. Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 34, image 1 de 3 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 34, image 2 de 3 Remplacement de la carte mère du MacBook Pro 13" Retina fin 2013: étape 34, image 3 de 3
    • Soulevez légèrement l'extrémité libre du SSD et tirez-le tout droit hors de sa prise sur la carte mère.
Pour réassembler votre appareil, suivez ces instructions dans l'ordre inverse.
75 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Sam Goldheart
Membre depuis le 10/18/12
465 777 Réputation
538 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 817 tutoriels rédigés
12 commentaires
This guide helped me repair my MacBook Pro with no prior knowledge of working on computers. I purchased a new logic board after mine broke from eBay, from a seller named L2 Computer Inc. and followed this guide using the iFixit pro tech tool kit and their thermal compound application set to reinstall the heat sink, and my computer turned on right away. Everything was so easy using this guide. The pictures are so good at showing how to do the steps, and the tool kit had really nice tools which made the whole process very simple. I am so thankful that you all help people fix their computers. It could not have been easier with this guide. It’s very well-written.
COURTNEY DYE - Réponse
Help me fix my MacPro. You are so good, Showing step by step. Make it very simple. Very thankful helping other sharing your skill. Tony, October, 2018
smelltony - Réponse
Great guide. Had issues with my Late 2013 MBP and narrowed it down to the logic board. I replaced it with a Mid-2014 MBP logic board as they are interchangeable thanks to this detailed guide. Laptop now fixed and upgraded!
velocity211 - Réponse
I can’t say enough about how well done this guide is for replacing a late 2013 MacBook logic board. The step by step with pictures were professional and spot on. I had a 4GB, i5 that had got to the point where I had to keep using a memory app to free up memory every couple minutes. Not being able to upgrade memory I was left with little options other than to buy a new one. After finding this site, I got a new logic board with i7 and 16GB of memory, I was able to turn my crippling MacBook back into a robust laptop I can once again enjoy using hopefully for at least a few more years. Bought the tools on here to complete the replacement and everything went without a hitch.
So a BIG thank you, thank you, thank you.. Keep up the great work on this site.. I know I’ll be back to check in on what’s available and when I have something else that needs to be fixed/upgraded vs buying new. :)
Boston222
Ted - Réponse
@boston222 I am in a similar situation where my 4GB memory is killing me. Would you be able to let me know where you got your i7 with 16GB of memory? I have been looking but I cannot find an i7 .. all I find is i5 with 16GB of memory .. I would appreciate if you could provide a website or model number of the item you ordered so I could get the same one.
Thanks in advance!
Hari -
After replacing the Logic Board, is there any other steps afterwards with programing? After I replaced the board, the flashing question mark comes up. When I go into Disk Utility the HD is not showing up. If anyone has any input I would appreciate the help.
Subhi Saleh - Réponse
i have same problem did you solve it?
Itay Israeli -
After replacing my logic board, it worked for a while then I started getting crashes followed by three beeps on boot up. Anyone got any ideas? I want back over and checked that all connectors were ok. Have I purchased a dodgy logic board from eBay?
patrick houston - Réponse
i have not reassembled we will see what happens in any event - wow - may the heavens bless you
apple (un)believably glues the graphics card - mine is busted after many years - to the mothership
many thanks - beautiful precision
Zev Aaron - Réponse
Thank you. it is wonderfull work
Ghassan Haddad - Réponse
After I replaced the screen on my a1502, random keys on the keyboard stopped working even though I didn’t touch the keyboard cable. I tried pulling out and reseating the cable multiple times but the problem persists, and not the same keys malfunction each time I try adjusting the cable. Any ideas about how to fix this? No problems when I connect an external keyboard.
Ellis - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 56
30 derniers jours : 284
Total : 89,768
