Aller au contenu principal
Remplacement de la manette de la Nintendo 2DS
Ce dont vous avez besoin
  1. Remplacement de la manette de la Nintendo 2DS, Batterie: étape 1, image 1 de 1
    • Retirez les 2 vis captives cruciformes qui fixent la coque arrière supérieure.
    • Les vis captives ne se détacheront pas complètement de la coque arrière.
  2. Remplacement de la manette de la Nintendo 2DS: étape 2, image 1 de 2 Remplacement de la manette de la Nintendo 2DS: étape 2, image 2 de 2
    • Enlevez la coque arrière supérieure en la soulevant vers le haut et l'extérieur.
  3. Remplacement de la manette de la Nintendo 2DS: étape 3, image 1 de 3 Remplacement de la manette de la Nintendo 2DS: étape 3, image 2 de 3 Remplacement de la manette de la Nintendo 2DS: étape 3, image 3 de 3
    • Retirez la batterie de son logement en la soulevant du côté le plus proche du bord extérieur.
  4. Remplacement de la manette de la Nintendo 2DS, Panneau arrière: étape 4, image 1 de 1
    • Retirez les dix vis cruciformes qui fixent le panneau arrière.
    Can't take off the screw top left next to the battery. What type of screwdriver do I use and where can I find some?
    Little Mac - Réponse
    I used a husky with changeable heads, you could probably find one on amazon
    Minecrafter Pig -
    These screws aren't Phillips, they're JIS, if you use a Phillips head you can and will strip the screws, please update this as it can cause more harm to people's systems than good if they get stripped.
    Sneakii - Réponse
    yep. i stripped my screws
    Persvicx -
    The screws are 6.2mm long
    Martin Samuelsson - Réponse
    god I thought it was because I was repairing a sibling's ds that had something spilled on it (idk maybe that they didn't clean it good when it happened) but continued to struggle even with screws that looked fine... wish I had checked the comments sooner :/ Please like the above, update this guide! It sucks knowing that someone like me is also gonna probably miss this. I didn't get super far but well. I already stripped down some which sucks either way. Ironically, I noticed that using a size slightly smaller gets the job done better. Ironic in that you'd normally avoid that because it's more likely to strip with small bits scrapping the inside. But if you are real careful it can hang on and twist. I'd recommend just getting the JIS but maybe this might work for some- I also want to emphasize SLIGHTLY smaller phillips.
    Alexandria.P - Réponse
  5. Remplacement de la manette de la Nintendo 2DS: étape 5, image 1 de 1
    • Le panneau arrière est connecté à la carte mère par une nappe, il faut donc veiller à ne pas soulever le panneau arrière trop loin de l'appareil pour ne pas l’abîmer.
    • Tirez délicatement le panneau arrière de l'appareil vers le haut.
    Y si se corta el cable que pasa?
    Laura Pernía López - Réponse
  6. Remplacement de la manette de la Nintendo 2DS: étape 6, image 1 de 1
    • Retournez soigneusement le panneau arrière pour repérer la nappe qui y est connectée.
    • Retirez les deux vis cruciformes qui fixent la nappe au panneau arrière.
    • Profitez de l'occasion pour retirer les gâchettes gauche et droite, elles ont des charnières qui peuvent se casser et des ressorts qui peuvent sauter.
    You can also detach the cable from the motherboard safely by flipping up the connector on the motherboard. Just don't forget to reattach. Some will find this tedious but may save time if you know what you're doing with said connectors.
    Blackbeard - Réponse
    I agree, this is what the guide i followed said to do and since I was disconnecting all the other ribbon cables it made perfect sense to do it that way.
    Lin -
    pay attention: my 2ds dropped it's lens covers at this step
    Jos van Reenen - Réponse
    Likewise, I used a tiny drop of glue to put the lens back in place. Take care not to dirty the lens.
    Elliot West -
    The picture you have there has the camera lens ribbon installed upside down. The ribbon needs to be pointing down when you re-attach it not up.
    Rick Parrish - Réponse
    Agreed, ribbon cable looks upside down in picture
    Elliot West -
  7. Remplacement de la manette de la Nintendo 2DS, Manette: étape 7, image 1 de 2 Remplacement de la manette de la Nintendo 2DS, Manette: étape 7, image 2 de 2
    • Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
    • Retirez le panneau latéral rouge droit en le tirant vers l'extérieur.
    I recommend not removing the right trigger. I didn’t find it necessary and I hard a hard time getting the spring lined up again.
    Tyler Schommer - Réponse
  8. Remplacement de la manette de la Nintendo 2DS: étape 8, image 1 de 1
    • A l'aide d'une spatule, soulevez le levier de verrouillage gris du connecteur ZIF de la nappe du joystick. Soulever directement de la carte mère sur le côté du connecteur opposé au câble.
    • Faites glisser doucement le câble tout droit hors du connecteur.
  9. Remplacement de la manette de la Nintendo 2DS: étape 9, image 1 de 1
    • Retirez les deux vis d'angle Phillips de 2,7 mm qui maintiennent le couvercle blanc du joystick.
    These screws are 7.8mm tall
  10. Remplacement de la manette de la Nintendo 2DS: étape 10, image 1 de 2 Remplacement de la manette de la Nintendo 2DS: étape 10, image 2 de 2
    • Retirez le couvercle du joystick. Il doit se détacher avec peu de force.
    • Retirez la rondelle du joystick sous le couvercle du joystick.
    I completed the tutorial but my stick is now drifting by itself and I’m afraid to open it up again and try because the screws, it seems, are damaged from scratching it too much. It’s been like that for at least a year
    ImTHATGuy 500 - Réponse
25 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Fina Beauchamp
Membre depuis le 01/12/15
3 150 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 70-1, Forte Winter 2015 Membre de l'équipe Cal Poly, Team 70-1, Forte Winter 2015
CPSU-FORTE-W15S70G1
4 membres
35 tutoriels rédigés
12 Guide Comments
My ribbon cable is broke, Is there a way to fix it?Thanks.
Deez Smith - Réponse
When I put the circle pad back in, my 2DS thinks that I am holding up and right on it, when in reality it is in the neutral position. Please help.
CraftedGamer 1170 - Réponse
Use the calibrate option in system settings. Also make sure the cable is connected nicely.
Jilvenhong Dickinson -
Recalibrate it in system settings.
Artemy Matveev - Réponse
The guide fails to mention that the joystick ribbon cable is locked into the motherboard. You can use a spudger to lift the grey tab, leveraging upwards on the side opposite of the ribbon cable. The tab will pop up and should make getting the ribbon cable out (and back in) easier.
I followed this guide and ripped the ribbon cable while attempting to get it connected back to the system. If I had known the grey tab unlocks, I might not have ripped the cable by trying to force it back under the pins. My iFixit tweezers were also very sharp, and may have cut the ribbon cable. Would anyone be able to recommend something gentler for the ribbon cable?
Ryan G - Réponse
@ryango This looks like an oversight on the part of the guide author. I’ve updated the text with (hopefully) better instructions. Sorry it led to tearing your cable. :( That looks like a pretty standard ZIF connector, and once unlocked, it should disconnect and reconnect with minimal force. Personally when working with ribbon cables I prefer blunt-nose tweezers, but it sounds like your tweezers weren’t at fault here. Thanks for the heads-up, and better luck with your next repair.
Jeff Suovanen -
I replaced my analog stick, but it has the same problem, when i turn on the system, the cursor go crazy and then stops, i can move only left and right, no up and down with two different analog sticks…so, it’s not a analog problem, do u have any idea on how to fix it? thank you
Emiliano Tricase - Réponse
Try recalibrating it, I guess. After that, let me know how it is? I might find another possible solution.
INFJ Blog -
A bit nervous to try this, do I have to detach the ribbon cables?
INFJ Blog - Réponse
So mine doesn't have the gray tab. Any help with that?
jeff why not? - Réponse
I've found that a Phillips #000 Screwdriver works better.
Raymond Trinh - Réponse
Will iFixit be selling the parts for this repair ever again?
Noboru Garcia - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 25
7 derniers jours : 133
30 derniers jours : 644
Total : 35,686
