Introduction
Utilisez ce tutoriel pour remplacer la pile de la clé de la Honda Civic 2012-2016.
Outils
Pièces
Posez la clé sur une surface, de telle sorte que le symbole Honda soit vers le haut.
Utilisez un tournevis cruciforme #0 pour dévisser l'unique vis.
Pour réassembler les pièces de la clé, suivez les instructions du tutoriel en sens inverse.
16 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
22 commentaires
The original battery in my 2012 Honda Civic Key is a Panasonic CR1616, not a CR1620. I bought an Energizer CR1620, and it was too thick.
Thanks, Harry!
This isn't the same key remote that I have for my 2015 Civic Si (Sedan). Mine is more square shaped and the key is removable from the inside of the device. It also has no apparent opening-point anywhere around it. The only spot I would consider a possible entry point would be where the key is removed.
Robert;
Yes, once the key is removed it is just a matter prying it apart from between the two ears that stick up from the center. A fairly thick flat-bladed screw driver will do it (i used the handle end of a tweezer that was handy). This takes a CR2032 battery, (3) volt, very commonly found. There are two little tabs holding it in, plus (+) side up. Just snap it all back together. Voila.
arlen
Thank you very helpful!!!
