Aller au contenu principal
Remplacement des vis Pentalobe de l'iPhone 8
Ce dont vous avez besoin
  1. Remplacement des vis Pentalobe de l'iPhone 8, Dévisser les vis Pentalobe: étape 1, image 1 de 1
    • Avant de commencer, déchargez la batterie de votre iPhone en dessous de 25 %. Une batterie lithium-ion chargée peut prendre feu et/ou exploser si elle est accidentellement percée.
    • Éteignez votre iPhone avant de commencer le démontage.
    • Dévissez les deux vis Pentalobe de 3,5 mm sur le bord inférieur de l'iPhone.
    • Ouvrir l'iPhone va endommager les joints étanches. Assurez-vous d'avoir du nouvel adhésif à portée de main avant de procéder à la prochaine étape. Si vous ne remplacez pas les joints, vous devrez prendre bien soin d'éviter d'exposer votre iPhone aux liquides.
    just how long are those screws- i turn and turn and turn and the lift off is soooo slight, seemingly insignificant…
    An. Jahnke - Réponse
    I would recommend, from the very beginning, dumping all tools out of the kit (if you got it) and using that white paper tool box as a tray to organize the screws and braces in. It’s nice to work over because it catches screws well and makes it easy to see them if you drop any.
    Johnny Emrica - Réponse
    That’s a great idea thank you
    Mohamed Dekkiche -
    Screw to the left of the charging port will not come out. Screw on the right came out no problem. Any ideas?
    Bill Maher - Réponse
    I already replaced my iPhone 8 battery with one from iFixit and honestly I wasn't impressed. It worked well for a few months, but then I started noticing the peak performance capability dropping significantly thereafter. I followed the initial charging instructions to a tee and only let it drop below 20% once a month. Normal everyday use for me... no intense apps like games, etc. I considered having Apple do it this time around, but for these older models they don't keep the batteries in-stock and you have to give them your phone for up to a week. So in the end, I opted to try another battery from iFixit instead. Hopefully this one will last longer.
    tripmusic - Réponse
    How with the gigantic kit do I not have a 3 1/2 pentalobe driver the very first screwdriver I reach for and that I need is not in any of these kits. What’s up with that?
    Michael Stephens - Réponse
    Same problem. The kit comes with a screw driver, but not for this pentalobe screw. This is a problem.
    Yuji Ishitsuka - Réponse
    I had to search what screwdriver bit I had to use from the ifixit toolkit; it's the P2 bit. (Maybe it's more obvious if you bought the battery kit, because it only has one type of pentalobe screwdriver.)
    Nathaniel Zielstra - Réponse
Pour remonter votre appareil, suivez ces instructions en sens inverse.
14 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Adam O'Camb
Membre depuis le 04/11/15
208 958 Réputation
416 tutoriels rédigés
2 commentaires
Why. Just why.
The Stuff - Réponse
This guide is used by many other guides as first step! Don´t laugh about it.
VauWeh - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 38
30 derniers jours : 128
Total : 15,554
