Aller au contenu principal
Remplacement du SSD sur un Dell XPS 13
Ce dont vous avez besoin
  1. Remplacement du SSD sur un Dell XPS 13, Plaque arrière: étape 1, image 1 de 2 Remplacement du SSD sur un Dell XPS 13, Plaque arrière: étape 1, image 2 de 2
    • Retirer les huit vis T5 Torx de 4 mm de la plaque arrière.
    Missing a step about removing the tiny Phillips head screw under the XPS flip up cover in the middle. Also, there are hooks all the way around the cover so it doesn’t simply lift off.
    curtis_p_brown - Réponse
    What about step 3???
    Peter Hecht -
    Please dont hurry , take your Time to follow this procedure. It takes 20 min (not 5) and step 4 requires half of this Time. Good luck.
    Peter Hecht - Réponse
    +1 Peter Hecht is right - getting the little clips the back is snapped on with is time consuming and a bit fiddly for people not used to “spudging” off covers. Starting from the back is the key those come loose much easier and help with the rest
    Doug Steinschneider - Réponse
    Great guide. It took me 20 minutes and there were no surprises. Battery installed. :)
    dhenniga - Réponse
  2. Remplacement du SSD sur un Dell XPS 13: étape 2, image 1 de 2 Remplacement du SSD sur un Dell XPS 13: étape 2, image 2 de 2
    • Utilisez un outil d'ouverture plastique pour ouvrir la trappe 'XPS' au milieu.
    No flap or screw on the XPS 9370, just a press-fit latch at the centre of the cover. This can be gently prised off.
    Alan Thomas - Réponse
  3. Remplacement du SSD sur un Dell XPS 13: étape 3, image 1 de 1
    • Retirez l'unique vis cruciforme cachée derrière la trappe.
    XPS 13 9370 doesn't have it.
    Kes Bond - Réponse
  4. Remplacement du SSD sur un Dell XPS 13: étape 4, image 1 de 1
    • Utilisez des médiators ou un outil en plastique pour faire levier pour détacher les clips du boîtier en commençant par le bord arrière.
    It’s not that easy to lift actually, cause there are latches. Had t release them gently all around beforehand.
    Davit Barbakadze - Réponse
    Also there’s one additional screw under that plate on the bottom!
    Maybe the later models are different, since it should be from the front: https://www.youtube.com/watch?v=xFIE2SKs...
    shigmas - Réponse
    Very difficult step, Proceed very carefull
    If you are replacing the battery of a 9360 or latter (2016 onward) make sure to do the FRONT first. There are latches on the back that you may break if you try to force it open that way. After prying up the front and the sides, just lift up the front like you would open a hinged box. You shouldn’t feel that much resistance as the back hinges off towards you after you’ve lifted it around 30-40 degrees.
    Giacomo P - Réponse
    Very easy with XPS 13 9370 - just used my nails (rather short!)
    Kes Bond - Réponse
  5. Remplacement du SSD sur un Dell XPS 13: étape 5, image 1 de 1
    • Retirez le couvercle inférieur.
    good evening, is there a site that sells the back part because it's broken
    marios cocka - Réponse
  6. Remplacement du SSD sur un Dell XPS 13, Déconnexion de la batterie: étape 6, image 1 de 2 Remplacement du SSD sur un Dell XPS 13, Déconnexion de la batterie: étape 6, image 2 de 2
    • Tirer doucement le connecteur de la nappe de la batterie en direction de la batterie pour le débrancher de sa prise.
    • Si le connecteur est résiste, poussez-le d'un côté puis de l'autre pour le faire sortir de la prise.
    • Si vous rencontrez des difficultés pour faire sortir le connecteur de sa prise, utilisez la pointe d'une spatule (spudger) pour pousser délicatement sur l'encoche du connecteur afin de le faire glisser.
    • Ne tirez jamais vers le haut.
    • Dépliez l'écran et appuyez sur le bouton de marche pendant 5 secondes pour vider toute charge latente du système.
    DO NOT OPEN THE DISPLAY!!! When I did, on my Dell XPS 13 9360, I cracked something in the top right corner where the power button is, and the plastic part of the button came out. I can still press it, but there is now a gap there and dust can get it.
    Asher Grossman - Réponse
    I opened they display, very carefull. No problem. Open just enough to press they button.
    Take care on later models. This is not a breakdown for the 9360, I learned that the hard way.
    Giacomo P - Réponse
    Agree with Asher Grossman, open at your peril!
    James White - Réponse
    First put the bottom cover back, with 4 screws, one at each corner. Then you can safely open the display and press the button. Then close the display and take the bottom cover off again.
    Patrick Bower - Réponse
    I did not do the open display and drain the battery because I did not understand this part and I know my battery was essentially dead, hence why I ordered one. Did everything else and voila! Works perfectly!
    Terri DiChito - Réponse
    Opening the display worked fine for me, but when I closed it again, something definitely didn’t quite go right – I think it was trying to push against the missing back cover. I managed to carefully close the display by pushing against the metal corner thingy that was meant to push against the cover, and so far the laptop still seems to work, but I concur with Asher and James, be careful at least. Patrick’s suggestion sounds great if I’d seen it in time :)
    Lucas Werkmeister - Réponse
    Ich konnte den Stecker schliesslich mit Hilfe einer Plektren sehr gut entfernen. Das Display habe ich nicht geöffnet.
    Ursulina Kölbener - Réponse
    Much better to ensure the old battery is fully depleted (unplug from mains & switch on & let it expire) before you begin replacement.
    This allows you to leave the unit face down whilst you work on replacing the battery.
    duncan cresswell - Réponse
    NO PROBLEMS with lifting the main body while the laptop is upside down, to reach the power button (XPS 13 9370). Also no problems with closing.
    Kes Bond - Réponse
    I confirm Duncan Cresswell's method. Let your old battery discharge completely until your laptop turns off by itself. This does require some patience. It took longer than expected to use up the last procent of the battery but it worked.
    NeoK - Réponse
  7. Remplacement du SSD sur un Dell XPS 13, SSD: étape 7, image 1 de 1
    • Retirez la vis Phillips de 4 mm qui maintient le SSD.
  8. Remplacement du SSD sur un Dell XPS 13: étape 8, image 1 de 1
    • Faites glisser le SSD hors de sa prise.
    • Ne soulevez pas le SSD plus que nécessaire.
    • Pendant le remontage, assurez-vous que la fente dans le SSD s'aligne avec la fente dans sa prise. Ne touchez pas les contacts dorés avec vos doigts.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
28 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
The Raptor
Membre depuis le 11/27/16
6 276 Réputation
6 tutoriels rédigés
14 commentaires
I’m kinda new on pc upgrading. So once I install a new m.2 I’ll need to install a new window 10 right
burin.int - Réponse
Yes, you have to install windows again. or you can clone your existing ssd onto the new one using some adapters easily found online
Anirban Mukherjee -
You will have to reinstall unless you are buying a samsung m.2 which comes with a disk duplicator utility. The xps 13 cames with a samsung early life evo disk (128GB) and transferring from 1 evo to another is very easy with the app. I believe its the same with every disk though I havent tried the latter.
kamathmanoj - Réponse
Dell has some nice recovery tools:
https://www.dell.com/support/kbdoc/en-us...
I downloaded a recovery image to use from a USB drive. I am using it to reinstall the Windows that came with the PC. You don't have to be the original owner but you do need to have the Dell asset number usually stored in the bios
Justin Vander Ziel -
My screws were a T6 not T5 and it took about 20 minutes not 15. I suspect different versions of the XPS 13 have different screws etc. mines a 9370.
it would have been helpful if the guide title or preamble mentioned the specific model these instructions were written against.
The process was the same though and the guide helpful, thanks!
Laurence Hurst - Réponse
I viewed another video before this one and was surprised to learn how easily the back snapped off after removing all of the screws and following the instructions to start near the back. Nice
Justin Vander Ziel - Réponse
Back up your data: Before you begin, make sure you have backed up all your important data to an external hard drive or cloud storage.
Shut down your laptop and unplug it from the power source.
Open the laptop: Use a Torx screwdriver to remove the screws on the bottom of the laptop. You may need to use a plastic spudger tool to pry open the bottom cover.
Locate the SSD: The SSD is a small rectangular chip connected to the motherboard. It may be covered by a metal shield or tape.
Remove the SSD: Unscrew any screws holding the metal shield or tape in place. Gently lift the SSD out of its socket, being careful not to bend any pins.
Install the new SSD: Carefully insert the new SSD into the socket, making sure it's properly aligned. Tighten any screws or clips to secure the SSD in place.
Close the laptop: Replace the bottom cover and secure it with screws.
Power on the laptop: Plug in the power source and turn on the laptop. Check to make sure the new SSD is detected in the BIOS.
AJEFFERY95 - Réponse
check this here: Back up your data: Before you begin, make sure you have backed up all your important data to an external hard drive or cloud storage.
Hey, thanks for the help. What's the max SSD capacity allowed on this XPS model ?
Pascal Pascal - Réponse
Is it true this doesn't work for the 9315 because the SSD is soldered to the motherboard?
XPSERIC - Réponse
I heard about that too. I opened mine (ie.9315) but the SSD seems to be covered by a "black part". I was too frightened to go on.
Romain Caruso -
Can I put in a larger NVME? 1tb -4tb?
Guy Johnson - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 26
7 derniers jours : 181
30 derniers jours : 633
Total : 81,380
