Aller au contenu principal
Remplacement du boitier externe du Super Nintendo
Ce dont vous avez besoin
  1. Remplacement du boitier externe du Super Nintendo, Boitier externe: étape 1, image 1 de 1
    • Retirez les six vis situées sous le système à l'aide du tournevis Gamebit 4,5 mm.
    In order to prevent damage to the fuse, make sure that you always cycle the power before doing so with the power supply disconnected.
    Raucedine - Réponse
    There is a step missing from these instructions. There are two philips head screws where the AV/Power ports are on the back of the motherboard that need to be removed before you can remove the motherboard itself.
    phoenixknight8082 - Réponse
    I replaced my controller port, thinking that it was the culprit, but my SNES is still having issues. Nothing works for controller port 1 and only a few buttons work for controller port 2. I tried switching out the controllers and the issue seems to be isolated to the SNES itself. Does anyone have any other suggestions for fixing my issue?
    Thanks in advance.
    Mike Watts - Réponse
    For those facing a black screen on startup (after having cleaned pins on cartridges and cartridge slot) WITH power light coming on, turn off console, remove power, and try shorting out the capacitor leads. My SNES stopped working suddenly after a single power cycle, and shorting out the leads (while UNPOWERED) revived it.
    Austin Barnett - Réponse
    Could you further explain how to short the capacitor leads?
    Will Pulman -
  2. Remplacement du boitier externe du Super Nintendo: étape 2, image 1 de 3 Remplacement du boitier externe du Super Nintendo: étape 2, image 2 de 3 Remplacement du boitier externe du Super Nintendo: étape 2, image 3 de 3
    • Retournez soigneusement l'appareil.
    • Localisez la couture. Soulevez et séparez la moitié supérieure du boîtier de la moitié inférieure du boîtier.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
21 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
[deleted] nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Cameron Deines
Membre depuis le 10/05/10
712 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 4-47, Amido Fall 2010 Membre de l'équipe Cal Poly, Team 4-47, Amido Fall 2010
CPSU-AMIDO-F10S4G47
4 membres
25 tutoriels rédigés
Un commentaire
Hi, my name is Orlando, I'm writting of Perú, I have a question:
I can´t put the hinge of the top of that above part.
Please, can you help me, my mail is orla.davila12@gmail.com
Orlando Dávila Vizconde - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 23
30 derniers jours : 143
Total : 29,880
