Aller au contenu principal
Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011
Ce dont vous avez besoin
  1. Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011, Boîtier inférieur: étape 1, image 1 de 1
    • Retirez les dix vis suivantes :
    • Trois vis Phillips #00 14,4 mm
    • Trois vis Phillips #00 3,5 mm
    • Quatre vis à épaulement Phillips #00 3,5 mm
    • Quand vous replacerez les petites vis, alignez-les perpendiculairement à la légère courbe de la coque (elles ne se vissent pas à la verticale).
    How much weight can I save by removing the optical drive?
    gunes314 - Réponse
    You can save a lot of weight if lets say your installing a solid state drive or putting in a second hard drive but if you know that you use the CD/DVD disc drive a lot then you might just want to leave the drive alone.
    Marshall WahlstromHelgren -
    Tip: Use one of those weekday pill holders to have a cheep way to store screws you remove and each day of the week can be for different sizes or parts. It has been handy to have (much less expensive than the magnetic mat.
    Robert Wacker - Réponse
    Hello, where can I buy the screws I need in case I lose one of them?
    taylornya - Réponse
    I have one stripped screw... How opening without drill it?! Any suggestions please?
    rodrigosady - Réponse
    I also stripped a couple screws. I wasn’t able to open it up without drilling. After drilling the heads and removing the cover it was easy to hacksaw the tip and unscrew with a standard driver.
    Michael Wilkens -
    My top tip - make sure you buy good quality Phillips screwdrivers and a magnetic holder. Cheap screwdrivers won’t get the screws undone safely. Without a magnetic holder you have no chance of getting the tiny crews in and out safely.
    jeremyyoung - Réponse
    A good Phillips 00 is your friend here. Also, when reinserting the screws, gently start anticlockwise and you wil feel a click at the start of the thread. This tells you you’re in the right place and less likely to cross-thread through force in the wrong place.
    Iain Boyd - Réponse
    I feel like these are 000 screws. Amazon sales describe them as such and my 000 screwdriver fits better
    cam2000deluxe -
    Before ordering a new Trackpad remove the existing battery and try clicking the Trackpad. If it clicks OK with the battery out the source of problem is likely a swollen battery, which should to be replaced even if it still works to some degree. From the side of the battery you will likely see the soft part of the battery bulging beyond the hard case.
    Patrick Langvardt - Réponse
    That’s absolutely correct as I can testify. With the battery removed I also adjusted the T6 set screw that adjusts the sensitivity of the trackpad click, evidently someone had cranked mine down tighter than the factory setting.
    Gary Register -
    Le quatrième paragraphe dans les instructions en français n’est pas correct : ce ne sont pas les 2 petites vis, mais les 7 petites vis qui sont inclinées. Et les 3 grandes sont bien verticales.
    Degeorges - Réponse
    Bonjour ! Merci de votre observation. J’ai corrigé la traduction. iFixit étant un wiki, n’hésitez pas à modifiez si vous remarquez une erreur :) Encore merci de votre attention et à bientôt !
    Claire Miesch -
    Tip: if you have a magnetic screw mat or similar, lay the macbook over the mat to make sure it catches any screws that may decide to fall of and hide under your table
    Moritz - Réponse
    Funny, it's not her hands that are doing the close ups. :)
    Cinemated Man - Réponse
    What's the difference between the shouldered and non shouldered screws? They look exactly the same to me.
    MLNLRD - Réponse
  2. Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011: étape 2, image 1 de 2 Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011: étape 2, image 2 de 2
    • Faites levier avec vos doigts au niveau de la fente pour sortir le boîtier inférieur de la coque du MacBook.
    • Retirez le boîtier inférieur.
  3. Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011, Connexion de la batterie: étape 3, image 1 de 2 Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011, Connexion de la batterie: étape 3, image 2 de 2
    • À l'aide de l'extrémité d'une spatule (spudger), faites levier sur le connecteur de la batterie pour le débrancher de la prise sur la carte mère.
    • Il convient d'appliquer l'effet de levier sur les deux côtés courts du connecteur. Faites attention aux coins des connecteurs, car ils se cassent facilement.
    Is this step of removing the battery connector required?
    manodh - Réponse
    yes - as with disassembly of any electronic component you have to remove any power source. You don't want to accidentally turn the Mac on
    khull -
    Prying the battery connector off does not take much force. I did exactly what the guide suggested (walked it off back and forth) with the spudger without any problems. Just be very gentle, much like with anything inside laptops, they are very fragile and need to be worked with carefully. A+ instructions, battery replacement was a success.
    aekinaka - Réponse
    Be patient on disconnecting this one. It worked for me step by step, little by little.
    Phil Wagner - Réponse
    I used the nails of thumb and pointer finger simultaneously - worked pretty fine
    Reinhard Kaune - Réponse
    I whittled down ends of two wooden strips to use, along with my fingernails to start with. I used halves of a wooden clothespin, but popsicle sticks should work too.
    Mike Baker - Réponse
  4. Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011: étape 4, image 1 de 1
    • Repliez légèrement le câble de la batterie vers l'arrière pour éviter qu'il ne se reconnecte accidentellement à la prise sur la carte mère pendant que vous travaillez.
    I put some tape between the connector and socket while working on the drive.
    Stephen Smith - Réponse
    That's a good tip
    Anrothan -
    Great tip, I did that too
    Ahmed Mahran -
    One other note: The screw heads fit flush with the curvature of the case -- which means that they aren't exactly horizontal. In other words, they aren't perpendicular to the table that the computer is resting on. Don't try to force them straight in vertically, because you'll risk cross-threading them. (nearly ruined one screw hole myself!)
    lelandjordon - Réponse
    On my MacBook Pro, the connector seems to be an integral part of the battery.
    Jerry South - Réponse
    I suspect it’s just like the special screwdriver required for seatbelts on cars – to discourage regular consumers from attempting repairs. Of course, this only encourages consumers to use the wrong tool to attempt to repairs
    colleenthompson - Réponse
    Dissambling my MacBookPro Premium Mid 2012 (i5-3210M 2.5Ghz) was easily, Careful with the screws, use screwdriver fitting exactly with the screws, you damage them very fast. Work very exactly, relaxed with time, consentration, good Tools and with feelings in your hands. Disconnect the Akku was easy if you take care, remove it to be safe, Two screws more, more space to work & haven`t to think about damaging someting. Apple use diffrent screws, you should have many difffrent scewdrivers. It is also good to clean everything inside, With time everything gets very dusty & dirty, don`t forget the sides and little fittings at the case. Use a pinsel, alcohol, soft peace stuff, it will look like new. If you have knowledge & experience, you can paint it in any colour or airbrushing for individualizing. You can also just polish it with a soft Politure (Sonax car Polish No1, NOT with wax or take an other light Politure you familiar & can do the job, A Laptop should serviced once a year, keeping it good working over years
    Stefan Lindner - Réponse
    First thing i do is open & cleanig everything inside,specially the cooling & fan, renew the thermal paste with an high quality product. Install the Nain System, clean up Bloatware and other unnecessary things, install standard software for daily use, additional change system components against better one (Edge to Firefox, Windows Media Player to VLC , an Office Suite and configuring everything for Data Protection, Privacy- & Indentety Protection, install Drivers from the component Manufactur (incedible effect, disable limitations, more functions, work better & faster, increasing performance, additional change the WiFi & Bluetooth Card to a better one a UMTS WWAN to an LTE Card, increase RAM with two Dual-Channel working SODIMMs, Use M2 or 2,5" SSD if no M2 Slot aviable) as System- and Software iDrive, a FAT32 formatted 32GB Partition to be safe of metaviruses comes with harmless downloads, and a big 2,5 HDD to store the user data. What does you guys think about this? Old Computer become a new life,
    I livein Austria, near Vienna, if someone needs help or anything else, i would be glad to help. I always searching old or broken devices to bring them to new live. I also searching for spare parts, specilly a Bottom & Side Case and a 256GB or higher NGFF Storage Card for a Sony Vaio Tab 11 SVT1144HE (2014), some 14,1" Displays for a HP Probook 440G5 (2016), Elitebook MT 43 Mobile Thin Client, (2011), Dell Vostro 3460 (2012) Lenovo Thinkpad T440s (2014), and a Logic Board for an Lenovo Ideapad 330-15ARR (2017, damaged by Water i think) and a Logic Bord for an Alienware 17R4 with i7-6870HX & Nvidia 1080 (2018, CPU dead, maybe there is a repair Guide or workaround to bring it back to Life). I need always 8GB or 16GB DDR3 and DDR4 RAM Storage (perfectly two ident one for Dual-Channel use for Laptops, M2 SATA 6GB/s and NVMe PCIe SSDs 500GB or more and 2,5"SSD or HDD with 1TB or more and 3,5" HDD with 4GB or above. If you have some of this or other useful parts and doesn`t need them, please make me an offer, maybe
    2
    an change something you need. This is not a Business what i do, it`s more a Hobby with challenging new Excercices.. Thats the best Point. Plase forgive me as a Newbie this very long Post in the wrong Section, but if you are start writing you cannot stop.... But now i have to come to an end and would be happy if someone wants to get in contact. My E-Mail is: udontknowme@gmx.at (the adress name is just a notice against Big Data and for Privacy Protection!
  5. Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011, Lecteur optique: étape 5, image 1 de 1
    • À l'aide de l'extrémité plate d'une spatule, faites levier sur le connecteur du câble-ruban AirPort/Bluetooth pour le débrancher de la prise sur la carte mère.
    N.B! Thank you very much all you here on iFixit! Some IMPORTANT notes. Be very careful BEFORE prying the connectors up and down. They are very fragile and the picture could actually be seen as showing a bending loading in their weakest direction, AROUND its slender axis. The connector is slender and inserted on the logic board, so the gentle "walking" up and down should be done ALONG their slender direction and WITHOUT touching the adjacent connectors. If bending is done around its axis the soldering comes apart and the cable is done and gone. Just happened. These flat cables are one of the weakest design spots in my experience. They are a major time, money and geist consuming reason for malfunction like Wi-Fi connection problems, HDD, SSD not found internally but externally from USB issues et al being found on different forums. Thanks again and again.
    Greg - Réponse
  6. Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011: étape 6, image 1 de 1
    • Avec précaution, débranchez le câble vidéo de sa prise sur la carte mère.
    • Même si l'équipe iFixit le déconseille, certains utilisateurs choisissent d'ignorer cette étape. Pour plus d'information, lisez les commentaires relatifs à cette étape.
    • Tirez le câble parallèlement à la surface de la carte mère. Si vous le tirez vers le haut, vous risquez d'endommager la carte mère ou le câble lui-même.
    I'd to disassemble my MBP two times because my SSD did not work properly in optibay. While doing it a second time, I omitted steps 6 and 8. It is really not necessary, but step 6 is really scary.
    nicholas - Réponse
    Do you even need to do this?? I've seen guides where they just leave those on and slide the superdrive out from underneath that module..??
    Philip - Réponse
    Yes, this is really no need. I left it there, and still can proceed.
    maiyawmh -
    I've replaced 4 dvd's with hdd's already, in different macbooks, so wasn't too fussed about #5. However; this time I broke the camera connector cable :(
    The connector is stil in it's socket, and I can't get it out no matter what I try. My guess is that some of the glue that connects the socket to the logic board, got into the socket as well. Prying with a small screwdriver, pulling with a pair of tweezers... nothing works. And this mbp belongs to a friend who uses his camera a lot for skyping...
    I hope we're still friends after I tell him.
    The thing is; I think it might be possible to do the whole operation with that cable still in its sockets; if you pull the rest of the cable free of the fingers, you can probably fold it out of the way when you lift the dvd out.
    puchelaar - Réponse
    This is Sooo Unnecessary!! don't do it!
    grant reynolds - Réponse
    I actually found it necessary to do this step. If not done you can rip chord, if you read the wording carefully and do as it says it should not break.
    After having initially skipped this step, I finally followed it. I couldn't find a way to move the airport / bluetooth assembly away otherwise, and in the end it's a pain to put the small screws back in. Didn't have any trouble unplugging the camera cable, but it is indeed scary because it looks pretty fragile.
    I only skipped step 8, as it didn't seem necessary.
    JoGersen - Réponse
    I also broke my camera cable!!! And I just realized that removing that lovely cable was not necessary for the following steps!!! Thank you!
    I dont know how to fix this problem and I asked it in this question: How can I fix broken camera cable
    Please, help...
    Yusuf - Réponse
    I successfully skipped this step when removing the hard drive enclosure (I had already the dual drive running, but I needed to replace the drive in the optical enclosure. I also skipped steps 7, 8, and 11.
    pauloau - Réponse
    I have a blog post on my experience of performing the upgrade with a simple diagram showing how to skip step 6, 7, 8 and 11. (http://www.ocyedwin.com/?p=190)
    Aderic Adsisco - Réponse
    I tried to pull the cable, but it did not come off even with moderate force. So it stayed as it was, and I had no problems taking out the drive and putting in the new one.
    Probably its best to skip this step.
    cearnach - Réponse
    I can't remove this so I skip it. I also skip 7,8,11 with no problem, just do it slow and carefully remove any parts.
    Pat Ach - Réponse
    Just did this. I elected to actually do this step and I’m glad I did. It was no big deal. Just pull straight back from the socket (not up or angled!) and although it was a little tight, it came out. I think it’s worth it not to possibly mess that cable up when you extract the drive. The drive itself does not lift up straight out- you have to work it out as there a few minor obstructions. At that point, it would be very easy to damage the camera cable. I took all the antenna cables off even those this guide only recommended taking off the long cable. This was due to an Apple repair video I had seen. This proved to be unnecessary and I should just have stuck with this guide’s recommendation. I did skip taking the woofer cable off towards the end of this guide as that seemed to be, and subsequently proved to be, utterly unnecessary. All in all, just moving slowly and carefully I managed this in 30 mins though next time will be faster, no doubt.
    dave - Réponse
    I did not perform step 6, 7, 8, 10 and 11. Once I performed step 9, I was able move the speaker housing to the right enough to get a long screwdriver to get to the ‘hidden’ screw underneath the housing and just removed the other two main screws holding in the drive in step 14. I did remove the HDD and holding backet prior to starting so I could slip the superdrive out and place the caddy back in the opposite direction. You just have to careful not to snag the wires when trying to remove the superdrive and and when slipping in the caddy. My Macbook is a MacBook Pro (13-inch, Mid 2012) and I only needed a Philips 00 screwdriver, and did not need to use a Torx screwdriver during any part of the upgrade.
    Balvinder Gill - Réponse
    Did not have to do steps 6, 7, or 11 and I was pretty clumsy (highly recommend a magnetic screwdriver or you'll struggle like me using a Dollar Tree kit). For reference was replacing a superdrive in a Late 2011 13 inch MacBook Pro after also upgrading my RAM. Used a third party replacement from Amazon and I'm listening to a CD with the replacement right now :)
    Kyle Hoang - Réponse
  7. Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011: étape 7, image 1 de 2 Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011: étape 7, image 2 de 2
    • Dégagez avec précaution le câble-ruban AirPort/Bluetooth pour qu'il ne vous gêne pas lorsque vous décollez le câble vidéo de l'adhésif par lequel il est fixé au caisson de basses et au support AirPort/Bluetooth.
    • Libérez le câble vidéo qui passe sous la dent de retenue moulée dans le support AirPort/Bluetooth.
    This step is unnecessary, as is step 8. You can get the SuperDrive out and put the caddy in without pulling the cable out.
    Steve - Réponse
    I successfully skipped this step when removing the hard drive enclosure (I had already the dual drive running, but I needed to replace the drive in the optical enclosure. I also skipped steps 6, 8, and 11.
    pauloau - Réponse
    Confirmed for a second time: Steps 6, 7, 11 NOT NEEDED.
    Alvaro Paiva Bimbo - Réponse
  8. Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011: étape 8, image 1 de 2 Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011: étape 8, image 2 de 2
    • À l'aide de la pointe d'une spatule, faites levier sur le connecteur d'antenne le plus proche de la carte mère pour le débrancher de la prise sur la carte AirPort/Bluetooth.
    • Libérez le câble de l'antenne qui passe sous la dent de retenue moulée dans le support AirPort/Bluetooth.
    I successfully skipped this step when removing the hard drive enclosure (I had already the dual drive running, but I needed to replace the drive in the optical enclosure. I also skipped steps 6, 7, and 11.
    pauloau - Réponse
    Based on the advice above, I tried to skip this step. Unfortunately, the way the wire wraps around the plastic caused it to break underneath when I lifted the optical drive out, and now I have another broken part.
    lisaquatmann - Réponse
    Yu can easily skip the step, just make sure you take care when removing/put away the AirPort/BT assembly in the next step, be gentle.
    Lucian Onea - Réponse
    I skipped this step and disconnected (the end that was not mentioned) accidentally from the machine, what can I do to repair it?
    Ely - Réponse
    Ce connecteur est très fermement fixéà la carte. Lorsque j'ai procédé comme expliqué ici, il s'est brisé !!!!
    J'ai tenté de le recoller. Pour l'instant il semblerait que j'ai toujours du wifi. Ouf.
    Je pense donc qu'il faut éviter cette étape si possible.
    Pat Microbiom - Réponse
  9. Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011: étape 9, image 1 de 1
    • Retirez les cinq vis suivantes :
    • Deux vis Phillips 10,3 mm.
    • Deux vis Phillips 3,1 mm.
    • Une vis Phillips 5 mm.
    Note the position of the little grounding rings when removing the red (10mm) screws. You'll have to make sure to re-seat them when reassembling!
    James - Réponse
    You are so right about making sure to put back the two metal rings when you screw back the two (red) 10.3mm screws. I missed putting back one of the rings and read your comment after I had installed the drive and closed the macbook. Everything was working fine, but I went back to open it an leave it just as it was, with both metal (one with a plastic/cloth material around it) plates/rings attached properly. So it is very important to make sure you put those two 10.3 mm screws back with the plates/rings that they hold, exactly as they were before you put it apart.
    pachis2 -
    I think you should remark when re-assembling the machine, you should pay attention to the metal clip in Step 9, the upper left screw position, it's easy to miss when assembling, because there are so many wires, and it may be very easy forgetting putting the metal clip back in place.
    Fisher - Réponse
    As far as the grounding ring goes, it slips back over the screw hole, be patient and gentle. You may have to finagle the airport board under it first and then lay the board flat and reattach the subwoofer. I will see if I can add a pic in the near future. But that the best way to describe it.
    FYI: These are #00 Phillips screws!
    Rossi Macri - Réponse
    Help! I think i stripped the screw head of the one encircled in yellow. What to do?
    BJC - Réponse
    Be weary of the cable when screwing in the Orange screw closest to the clutch cover. I pinched that cable and had to replace it.
    Duck - Réponse
    I have removed the screws circled in red but when I try to remove the board, it seems there is something else that's holding down the piece. It seems to pivot around the spot in between the 2 screws circled in red. I'm hesitant to use too much force to pull it out and therefore stuck. Can anyone help me out?
    Edit: For clarity, I have removed the screw circled in yellow, but not those circled in orange as I understand you can remove the the board in 1 whole piece.
    lambing_drape - Réponse
  10. Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011: étape 10, image 1 de 2 Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011: étape 10, image 2 de 2
    • Tirez l'ensemble AirPort/Bluetooth et le caisson de basses vers le haut, près du centre du côté du lecteur optique, jusqu'à ce qu'ils s'écartent l'un de l'autre.
    • Éloignez l'ensemble AirPort/Bluetooth et le caisson de basses du dessus du lecteur optique.
    The left part in the picture (the AirPort/Bluetooth assembly) is held down under a plastic tab that sticks out a tiny amount. Thus, it needs to be pulled very slightly towards the camera module in order to be able to lift out.
    Darren - Réponse
  11. Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011: étape 11, image 1 de 2 Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011: étape 11, image 2 de 2
    • Dégagez le câble du haut-parleur droit/caisson de basses coincé sous la dent de retenue près du côté du lecteur optique.
    • Tirez le câble du haut-parleur droit/caisson de basses vers le haut pour le débrancher de la carte mère.
    I will confirm for a third time, having just done this replacement yesterday morning: Steps 6, 7, 11 NOT NEEDED.
    cjdow - Réponse
    When I attempted to lift this cable out of the connector, the connector broke and separated from the board. I suggest not to do this step.
    car rider - Réponse
    Agreed. I skipped this step. No need to risk breaking a cable or connector if you don't have to disconnect it to get the optical drive out.
    Alan Grassia - Réponse
    Three things:
    1. Thanks for this guide!
    2. I don't understand the comments that this step (#11, disconnect the speaker cable from the logic board) can be skipped, given this guide is all about replacing a failed right speaker/subwoofer. Maybe this step was re-titled from its original post?
    3. My (used) replacement part from iFixit (part IF163-029-1) for my mid-2012 Macbook Pro 13" was different than the OEM part in that the replacement part's cable exited the subwoofer enclosure from the "northeast" corner of the package, rather than the "southeast" corner of the package. This required a rerouting of the cable to a route *on top" of the subwoofer rather than below it, as a nearby boss prevented the original route. Also, I needed to completely remove the heat shrink that joined the subwoofer and right speaker cables together near the connector, as it prevented the radius necessary to route that portion of the wire. I have pics but I don't see how one can provide them in the comments.
    ROBERT ANTHONY PASSARO - Réponse
    I agree, I found the instructions to not be clear about the care necessary in removing the cable from the logic board, and I also pulled the receptacle off of the logic board. And now I do not have right/woofer speaker sound, and no way to correct it. I can see that there are two small thumbnail size photos above the main photo, and these give a bit more instructional information. These photos should be bigger so that you will notice them, and the extreme care needed to remove the cable should be prominently noted. At this point in time, my 2012 computer is eleven years old, so extreme care is needed in removing this cable.
    bobboross - Réponse
    Adding on to my previous comment, if you check the replacement guide for the logic board, you will see that it is recommended that you remove the cable by using the spudger to gently pry up the cable. Whereas here, in this guide, it tells you to just "pull up" the cable using your fingers. Using the spudger would help in not pulling the receptacle off of the logic board. See here - https://guide-images.cdn.ifixit.com/igi/...
    bobboross - Réponse
  12. Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011: étape 12, image 1 de 1
    • À l'aide de l'extrémité plate d'un spudger, faites levier sur le connecteur du câble du disque dur pour le débrancher de la prise sur la carte mère.
    • Repliez le câble du lecteur optique pour le dégager du lecteur optique.
    Greg - Réponse
  13. Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011: étape 13, image 1 de 1
    • À l'aide de l'extrémité plate d'une spatule, faites levier sur le connecteur du lecteur optique pour le débrancher de la prise sur la carte mère.
  14. Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011: étape 14, image 1 de 1
    • Retirez les trois vis Phillips 2,7 mm par lesquelles le lecteur optique est fixé au boîtier supérieur.
    can i reuse this optical drive again
    justcause3 - Réponse
    Sure you can. Use it in anything. Stick it in a USB enclosure and carry it.
    scottmilliken -
    iFixit has a guide on How to Remove a Stripped Screw: Comment enlever une vis cassée
    Stripped Screw - Réponse
    I stripped the top left screw and lost a few others, where can I buy replacements?
    Ely - Réponse
    I got the same problem, did you ever find any source for replacement screws?
    Nikki -
    top left screw is a nightmare
    Fabian Cadiz - Réponse
  15. Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011: étape 15, image 1 de 1
    • Tirez le disque dur vers le haut en le tenant par le côté le plus proche de l'écran et retirez-le du boîtier extérieur.
    Because I skipped steps 6, 7, 8, and 11. when removing the hard drive enclosure (I had already the dual drive running, but I needed to replace the drive in the optical enclosure, I found it easier to remove the enclosure by lift the side close to the battery and main HD and pulling it towards myself (towards main HD and battery).
    pauloau - Réponse
    Did the same, also because i skipped those steps. It worked, you just have to remove it gently.
    Lucian Onea -
  16. Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011, Haut-parleur droit/subwoofer: étape 16, image 1 de 2 Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011, Haut-parleur droit/subwoofer: étape 16, image 2 de 2
    • Utilisez un outil d'ouverture ou un autre objet fin pour séparer délicatement le haut-parleur droit de l’adhésif qui le fixe au boîtier supérieur.
    • Commencez par faire levier sur le bord du haut-parleur droit le plus près de l’écran. Commencer de l'autre côté risque endommager une des antennes.
    • Faites levier le long du bord du haut-parleur droit jusqu’à ce qu'il soit séparé du boîtier supérieur.
  17. Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011: étape 17, image 1 de 1
    • Sortez le haut-parleur droit de l'ouverture du lecteur optique.
  18. Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011: étape 18, image 1 de 2 Remplacement du haut-parleur droit/subwoofer du MacBook Pro 13" Unibody de début 2011: étape 18, image 2 de 2
    • Décollez le câble du haut-parleur droit le long du bord de l'ouverture de lecteur optique.
    • Sortez le câble des clips près du bord de la carte mère.
    • Retirez l'ensemble haut-parleur droit/subwoofer de la coque supérieure.
Pour remonter votre appareil, suivez les étapes dans l'ordre inverse.
42 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
4 commentaires
General - the reason you are reading this guide may well be that you blew you speakers after installing 'Boom' from the App Store.
All I can say is, don't install it a second time!
Others, be warned! If you use Boom, just use it at the lowest volume you can. Looks like they don't replace speakers.
Or better, don't install it at all.
Stuart.
Stuart - Réponse
i did it!! what i can say is the details of the step will bring no mistake even for a beginner to change the spare part!
thank IFIXIT!!
johnlee_1984 - Réponse
I intend to use this guide to actually modify the subwoffer portion of my old 2011 MBP- I’ve removed the ODD and have oh so much more room inside now for a much better acoustic chamber and potentially small amplifier! Stay tuned :)
Jordan - Réponse
Completed! Things to watch out for.
- Make sure you take note of how the cables are organised in their holders and along the chassis. Once you take them out it’s hard to get them to align back to the factory setting.
- The speaker attached to the antenna assembly has a slot that it falls into which puts the whole unit down lower. I had it sitting in a position that seemed right, but a little bit high. I gave it a slight wiggle and it fell into place, which also brings the antenna cables down lower and away from the case cover.
- The glue on the speaker was hard to release. Had to use a hair dryer & heat up the speaker. Def try & find a very thin spudger or this part is complicated. There seems to be less system wires to damage on the end closer to the hard drive. The antenna wire is too close to the other.
- The screws for the optical drive are tiny and can be pretty hard to drop into place once the drive is in position. I used a bit of blu tac on the end of a screwdriver to lower them down before tightening.
Max - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 44
30 derniers jours : 188
Total : 48,037
