Aller au contenu principal
Remplacement du pavé tactile du MacBook Unibody modèle A1342
Ce dont vous avez besoin
  1. Remplacement du pavé tactile du MacBook Unibody modèle A1342, Boîtier inférieur: étape 1, image 1 de 1
    • Retirez les huit vis Phillips 4 mm par lesquelles le boîtier inférieur est fixé au MacBook.
    According to this page http://support.apple.com/kb/HT1651?viewl..., the 8 screws are not identical.
    Can anybody tell me where each kind of screw is supposed to go?
    Gregoire - Réponse
    They are all 100% Identical. You were probably looking at a different model, or Apple has entered the wrong information... Hey, It happens...
    Owen Davies -
    The screws on the Late 2009 are identical. The blue lock compound might make tightening some require a little more effort.
    svenaustx - Réponse
    Can I replace it with a SATA 3 cable?
    nm - Réponse
    A1342 macbook does not have the right controller to support sata III
    Owen Davies -
    hi, i just got back from the apple store and they are really keen for me to upgrade to a new laptop since my battery is old and the screen is cracked, so glad i found ifixit i would love to upgrade this puppy! gonna make it a real sleeper! styler hall wrote about sticking 16 gb of ram in his a 1342 ? is this a simply mather of ordering 3 4gb sticks ?aslo i currently have 4 gb and would like to upgrade to 8 ( or indeed 16) does that mean i need to buy all new sticks or can i continue to use the old one and stick a new one next to it ?
    thanks again mick van aar, perth western aus.
    michelvanaar - Réponse
    The A1342 will take up to 16 GB of RAM, however, there are only two RAM slots, so use two 8-GB RAM modules. Other World Computing (OWC) is a great reference source for info on exactly which RAM to use with which model; prices are usually much better on EBay though. Add an SSD from OWC and your machine will really scream!
    I hope that helps!
    gdesbrisay -
    Gregoire is right. The 8 screws are absolutely NOT identical, I’m looking at them right now, weeowey weeowey.
    John Guzman - Réponse
    I just wanted to say that, in 2020, i used these instructions to replace the magsafe socket on my A1286, mid-2012, pre-Retina MacBook Pro. The internal layout is not quite the same but close enough for me to do the job. I skipped the steps of fully disconnecting the fans and speakers because of what others had said about breaking the sockets. it just meant I had to be extremely careful when lifting up the main board so that I did not tear and break the connections. I was able to disconnect the old magsafe socket with the board flat and in situ, but there was no where near enough room to be able to aline and press home the new par home. Reluctantly i had to lever up the board. This was difficult as there is a tapped post that holds a screw in the way close to where the USB sockets are, that prevented the board lifting up and out. I had to be quite forceful to manouevre the sockets out from the edge of the case.
    Paul Burridge - Réponse
  2. Remplacement du pavé tactile du MacBook Unibody modèle A1342: étape 2, image 1 de 3 Remplacement du pavé tactile du MacBook Unibody modèle A1342: étape 2, image 2 de 3 Remplacement du pavé tactile du MacBook Unibody modèle A1342: étape 2, image 3 de 3
    • Le boîtier inférieur est construit en aluminium avec un revêtement en caoutchouc. Ne pliez pas trop l'aluminium lors du retrait, car une déformation permanente générerait des problèmes de tolérance après le remontage.
    • Soulevez légèrement le boîtier arrière au niveau de la fente.
    • Continuez à faire courir vos doigts entre les boîtiers inférieur et supérieur jusqu'à ce que le boîtier supérieur se dégage des clips de fixation.
    • La position de ces trois clips est indiquée dans la troisième photographie.
    Do the retaining clips have to be re-engaged when replacing the lower case?
    John Morley - Réponse
    Answering my own question, the clips re-engage when the lower case is correctly positioned. You can help them by gently pressing the lower case with your thumbs midway along the two short sides. When everything is correctly aligned the eight screw holes line up.
    John Morley -
    Rather than running your fingernail down the sides to free up the retaining clips, I found that using an old credit card, inserted about 1/4”, to run along the left and right side popped those end retaining clips right off with no problem. You may need to twist the card slightly when in the middle area to help pop those off.
    bdahl385 - Réponse
  3. Remplacement du pavé tactile du MacBook Unibody modèle A1342, Batterie: étape 3, image 1 de 1
    • À titre de précaution, nous vous conseillons de débrancher le connecteur de la batterie de la carte mère afin d'éviter les décharges électriques. Cette étape est facultative.
    • À l'aide de l'extrémité plate d'un spudger, faites levier sur le connecteur de la batterie pour le débrancher de sa prise sur la carte mère.
    • Vous pouvez également, si cela est plus facile, vous servir de vos ongles pour soulever les deux extrémités du connecteur.
    Hi,
    for error I did step 3 as last one. The battery now is no more recognized by my macbook.
    Did I make such a tremendous mistake that cause the battery to fail ??
    Enrico D - Réponse
  4. Remplacement du pavé tactile du MacBook Unibody modèle A1342: étape 4, image 1 de 1
    • Retirez les deux vis Tri-point 5 mm qui fixent la batterie au boîtier supérieur.
    "Tri-Wing Screws"? I don't see a "Tri-Wing Screwdriver" listed in the "Tools" section.
    barryjaylevine - Réponse
    See here: Tri-point Y1 Screwdriver
    All tools required are included here: [produit lié absent ou désactivé : IF145-022]
    Just did it myself ;)
    Hannes -
    5mm tri-wing screw??
    Its hardly that big. It certainly requires a tri-wing screwdriver much smaller than a 5mm tri-wing screwdriver - "Y1" is probably 1mm. The smallest I had was a 2mm tri-wing screwdriver and it just worked ok.
    I think this and step 5 should be edited with better information.
    yy yy - Réponse
    The original iFixit guide described the step 4 screws as "tri-wing" but that is incorrect, it should say "tri-point" or "Y", and the required screwdriver diameter is 2 mm, not 5 mm. See this image:
    http://en.wikipedia.org/wiki/List_of_scr...
    The top row is tri-wing, the bottom row is tri-point, as found in this MacBook.
    irvbromberg - Réponse
    My tri-wing screws were black, 2mm and totally seized up. I had to break the plastic around the screw holes in the battery, remove it and then un screw them with long nose pliers. Needless to say they are now replaced with Philips screws.
    Al Livesey - Réponse
    A Y1 screwdriver emphatically did not fit mine - so in case it saves others buying a useless set of security bits like I did, you need a Y0, like this one: https://www.ebay.co.uk/p/tri-wing-y0-tri...
    Jo Wilson - Réponse
    A small ~2mm flat-head screwdriver will fit across two of the points and have enough leverage to do the trick as well.
    Edward Price - Réponse
    In my case a Y1 Tri-point driver loosened the silvery screws of 5 mm length.
    channy8 - Réponse
    Here’s a trick you can use if your black tri-wing screws would rather than strip than come out: the reason they’re stuck is that Apple put adhesive on the threads, and if you apply heat you can defeat the adhesive. Once I stripped the first one I realized what was going on, and I put the tip of a soldering iron on the remaining screws for two minutes. Presto, they came out easily. If you strip one like I did you can either break the plastic like Al did above, or you can use a Dremel tool with a cutting disk to cut a slot in the head of the screw, converting it into a slotted screw head. You have to judge it carefully: deep enough to get a bite on it, not so deep that you destroy the integrity of the screw. Also, you have to mask off the surgery site: I put down paper everywhere except where the screw was, then covered the paper with aluminum foil. The foil protects against the sparks created by the cutting wheel, the paper insulates the circuit board against shorting by the foil. Not for faint of heart.
    Klieb - Réponse
  5. Remplacement du pavé tactile du MacBook Unibody modèle A1342: étape 5, image 1 de 1
    • Utilisez la pointe d'un spudger pour soulever délicatement l'étiquette de sécurité. Vous trouverez dessous une vis Tri-point.
    • Retirez la vis Tri-point de 5 mm qui fixe la batterie au boîtier supérieur.
  6. Remplacement du pavé tactile du MacBook Unibody modèle A1342: étape 6, image 1 de 1
    • Retirez les trois vis Phillips de 3.1 mm positionnées près du bord du boîtier supérieur.
    • Lors de la réinstallation de la batterie, pensez à remettre ces trois vis avant de fixer les vis Tri-point.
    When I re-installed the battery, I inadvertently ripped the ribbon between the Trackad ribbon and the battery ribbon. Be Careful!
    Joel Gilbert - Réponse
    "Remove three 3.1 mm Phillips screws securing the battery near the edge of the upper case".
    Using the tools I bought from iFixit, I have got this far, no worries :)
    The channels underneath/around these screws appear damaged and will not allow the screw to unwind and come out, therefore, the screws are "stuck". (This is by no means an indictment of the mini screwdrivers.) Any suggestions to help, because the replacement battery will not fit with these screws in place. Thanks.
    jane - Réponse
    These last 3 screws were a bit** to get off. One of them actually would not come out but I managed to slip the battery out anyways. Maybe it nudged just enough. Getting it back in was okay, just slid it under. Fit was snug, had to be careful not to break or crimp the ribbon in front of the battery connector, as Joel stated. Simply snipped a piece of the plastic tab from the old battery and stood it up in this spot and slid the battery down, this kept the ribbon from crimping. Only one of these last 3 screws that I did get out, did I put back in. Not sure why they are there as the tabs that hold them are enough to hold the battery. All other screws and battery connector worked like a charm. Replaced the cover, turn it on and Whala!!! Only got a message that said I needed to reset the Date & Time. Got it on the charger now, as new battery only had 75% charge, so fingers crossed it will recharge at a 100% and last longer than the old battery before it's next charge. Good luck everyone!!
    Terri C - Réponse
  7. Remplacement du pavé tactile du MacBook Unibody modèle A1342: étape 7, image 1 de 1
    • Utilisez la languette de la batterie pour la sortir du boîtier supérieur.
    • Si vous installez une nouvelle batterie, on vous recommande de la calibrer avant de l'utiliser :
    • Chargez-la à 100%, puis laissez-la charger encore au moins deux heures. Utilisez votre appareil normalement. Lors de l'avertissement de batterie faible, enregistrez votre travail et laisser votre ordinateur allumé jusqu'à ce qu'il s'éteint à cause d'une batterie vide. Attendez au moins 5 heures, puis rechargez la batterie à 100% sans interruption.
    • Si vous remarquez quelques chose d'inhabituel ou si vous avez des problèmes après l'installation de la nouvelle batterie, il se peut que vous deviez peut-être réinitialiser le SMC de votre MacBook.
  8. Remplacement du pavé tactile du MacBook Unibody modèle A1342, Pavé tactile: étape 8, image 1 de 1
    • Avec l'extrémité plate d'une spatule (spudger), faites levier sur le connecteur de la nappe du pavé tactile pour le débrancher de la carte mère.
  9. Remplacement du pavé tactile du MacBook Unibody modèle A1342: étape 9, image 1 de 1
    • Dévissez les quatre vis cruciformes de 1,3 mm fixant le bord supérieur du pavé tactile au boîtier supérieur.
    I did this a while ago and I just wanted to add that my trackpad wouldn't click. As soon as I had the battery out I was stuck by how loose the set screw was (big flat torx head screw at the bottom center of the track pad). I had to play with the tension a little bit to get it an acceptable level of play but now my track pad works like new. Thanks iFixit and everyone who contributes to these guides!
    John Tipton - Réponse
    My 00 Phillips head is doing nothing to remove the 1.3 mm screws that hold the trackpad in. Any suggestions? I also tried a 0 and a 000. Don't want to keep playing around in case it strips the screws, but they are really stuck in there...
    Amity Higgins - Réponse
    Use a longer, sturdier screw driver. Either that or the screws have been thread locked in too tight at the factory. Apply more pressure. I mean, way more like, medium-hard pressure. if you don't care that much, apply hard pressure (If you're desperate apply even harder, just not so much it cracks the glass). Pressure is what holds the screwdriver in the screw, prevents it from slipping and stripping the screw! This is probably bad advice... I know.
    Owen Davies -
    Can Absolutely confirm weeowey weeowey's comment. Put your hand under the trackpad and really give the screwdriver some pressure. You might end up damaging a screw, but every replacement trackpad I've ever bought has come with replacement screws.
    jbartlet - Réponse
  10. Remplacement du pavé tactile du MacBook Unibody modèle A1342: étape 10, image 1 de 1
    • Inclinez soigneusement le pavé tactile en l'éloignant du côté clavier du boîtier supérieur.
    • Enlevez le pavé tactile de son emplacement dans le boîtier supérieur pour dégager les deux languettes d'attache sur le bord inférieur.
    When remounting the trackpad, ensure you support it from the keyboard side when tightening the screws to ensure it's not crooked.
    Stephanie Donley - Réponse
    Highly recommend adjusting the T6 torx screw to ensure correct operation of the trackpad. Have the battery connected but not installed (so as to have access to the screw). Start up the computer. Test the click function at any time. Using very minor adjustments, turn the screw until you can see that the computer responds to clicks. When you are satisfied that it is working correctly, go ahead and shut down the computer and proceed with reassembly. It doesn’t hurt to give the unit a good clean while you are in there as this will avoid problems later, eg overheating due to dust blocking airflow etc. use an artists paintbrush and a vacuum cleaner or (gently) blow it away with (clean) compressed air. Some compressors have oil spray or water from condensation in the air, so use a filter in the line to avoid contamination.
    Stephen Keyte - Réponse
Ligne d'arrivée
137 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
19 commentaires
Guide is very helpful...makes the replacement of this part easy. Thanks.
nih4ever7 - Réponse
My track pad was working intermittently and having a mind of it's own. Instead of going to a repair shop for a pricey fix, I followed this guide and removed the track pad, cleaned it up and hey presto it's fine now! Thanks for the guide, very easy to follow!!
Andrew von Moeller - Réponse
How did you clean the track pad? Did you just clean the connector. I'm also having similar issues, my tack pad starts having a mind of its on randomly after few minutes/hours.
Sapeksh Madan -
dirt can get trapped around or under the trackpad, causing touch malfunctions. removing this dirt usually fixes touch issues and maybe sometimes a click issue if dirt is under the trackpad
Owen Davies -
Does anyone have anymore information on the adjustment screw mentioned by John Tipton on Nov 6? I have made some adjustments to it and found tightening it actually locks out the ability of a USB external mouse from operating, and does not correct the problem of the internal track pad click function failing to operate. I suspect adjusting it properly may fix some of our track pad issues, but I have not discovered the proper way of making this adjustment.
paulhjacobs - Réponse
Some models (2009) don’t have inertial scrolling. What model do you have?
cris burns -
My trackpad has stopped working, took the machine apart using above and there was some sticky mess that had been stopping the click from resetting.
Brilliant and much cheaper than the genius bar by using my 99p tri wing screwdriver!
James Pearce - Réponse
Thank you. This guide is helpful, thank you for posting. Also thanks for selling the tools that let me do the replacement, I was able to replace the part with no hassle and the laptop is working fine again.
Raymond Santos - Réponse
These instructions worked perfectly - took less than an hour to replace the trackpad on our MacBook.
alleno - Réponse
This guide is about the 5th or 6th guide I have used and every one of them is very well constructed and documented, I haven't been disappointed with any of them.
Up until this one I had made do with my own miscellaneous tool assortment, making do when I didn't have the exact driver bit or tool. The tri-wing screws in this one encouraged me to get the Pro Tech ToolKit [produit lié absent ou désactivé : IF145-072-1] and now I kick myself for not getting the proper tools sooner. All through my career as a Remodeling Contractor I maintained the attitude of using the 'right tool for the job'. Well, same holds true here.
Looking forward to my next iFixit job. Thank you iFixit.
buz - Réponse
Worked perfectly! Thanks much.
marshmcjunkin - Réponse
Great Step by Step easy to Follow Guide I am truly impressed.
I believe I might need special iTools for some of the screws ??
Unitel Design - Réponse
So I get a replacement trackpad, it was easy to replace however now I have to push really hard to get an active click (for some reason the right side works better than the left). I have taken the battery out to see if that was the issue (it was not, still didn't register a click with the battery out). What is the easiest way to remove the "setter screw", the T6 screw that adjusts the depth of the click. I need to replace it but I cannot for the life of me get it out of the casing.
Joshua Dodge - Réponse
It works great!!! i clean the trackpad!!!
xbox360vs720 - Réponse
my track pad was acting ups I pulled it to clean it. works great now.
pjschmitt - Réponse
How did you clean..? just clean the connectors..?
wunna -
Had an erratic pad on a users machine - looked like liquid ingress (coffee stains in bottom of case) Used 99% isopropyl alcohol, in a ziplock bag to soak the trackpad (without the cable) Worked the alcohol into the pad for a minute or two, removed, air dried for 15/20 mins followed by a quick blow with a hot air gun. Cleaned around the top of the case where the trackpad recess is too. Refitted trackpad, connector and battery and tested - trackpad is as good as new. Please follow precautions when using isopropyl alcohol, it is very flammable.
Jim Clews - Réponse
Really clear guidance, thank you.
Paul Traynor - Réponse
Great instructions….new track pad works like a charm. Thanks!
Glenn - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 16
30 derniers jours : 85
Total : 170,648
