Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Replacing Spring in Refrigerator Door
Ce dont vous avez besoin
    1. Replacing Spring in Refrigerator Door, Spring: étape 1, image 1 de 1
      • Turn off the refrigerator by unplugging it or turning the breaker off.
      • There are electrical cords attaching the assembly flap to the door, so it is better to be safe.
      Demander à FixBot
      Ajouter un commentaire
    2. Replacing Spring in Refrigerator Door: étape 2, image 1 de 2 Replacing Spring in Refrigerator Door: étape 2, image 2 de 2
      • With a Phillips screwdriver, unscrew and remove the two screws on the hinge located directly in the middle of the door, connecting the assembly flap to the door.
      Demander à FixBot
    3. Replacing Spring in Refrigerator Door: étape 3, image 1 de 2 Replacing Spring in Refrigerator Door: étape 3, image 2 de 2
      • Located at the bottom of the assembly flap, remove the bottom plastic piece by gently shimmying it out with a small flat head screwdriver.
      • This may be a bit difficult.
      Demander à FixBot
    4. Replacing Spring in Refrigerator Door: étape 4, image 1 de 2 Replacing Spring in Refrigerator Door: étape 4, image 2 de 2
      • Carefully lift the assembly flap upward guiding it along the top and bottom plastic hinge just before it comes off.
      Demander à FixBot
    5. Replacing Spring in Refrigerator Door: étape 5, image 1 de 3 Replacing Spring in Refrigerator Door: étape 5, image 2 de 3 Replacing Spring in Refrigerator Door: étape 5, image 3 de 3
      • On the bottom of the assembly flap, carefully insert the spring into the plastic holes. One is connected to the bottom plastic hinge and the other is attached to the assembly flap.
      • Slide the assembly flap down into place. Be sure the top and bottom plastic hinge slides into place. You’ll notice the spring securely sliding into the plastic holes.
      Demander à FixBot
    6. Replacing Spring in Refrigerator Door: étape 6, image 1 de 2 Replacing Spring in Refrigerator Door: étape 6, image 2 de 2
      • Re-insert the bottom plastic piece by pressing it in until it snaps.
      Demander à FixBot
    7. Replacing Spring in Refrigerator Door: étape 7, image 1 de 3 Replacing Spring in Refrigerator Door: étape 7, image 2 de 3 Replacing Spring in Refrigerator Door: étape 7, image 3 de 3
      • Replace the two screws on the middle, metal hinge.
      • Turn the power on. Fast Fix is complete.
      Demander à FixBot
5 autres ont terminé cette réparation.
Christine Meyers
Membre depuis le 01/15/18
298 Réputation
1 tutoriel rédigé
Équipe
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 Membre de l'équipe USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018
USFSM-STEWART-S18S1G1
15 membres
90 tutoriels rédigés
1 commentaire de tutoriel
Very helpful! Easily completed and solved my problem.
Stephen Joncus - Réponse Partager
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 41
30 derniers jours : 180
Total : 16,993
