Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Retroid Pocket 3 Button Pad Replacement
Ce dont vous avez besoin
  1. Retroid Pocket 3 Button Pad Replacement, Battery: étape 1, image 1 de 1
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
    Demander à FixBot
    Ajouter un commentaire
  2. Retroid Pocket 3 Button Pad Replacement: étape 2, image 1 de 3 Retroid Pocket 3 Button Pad Replacement: étape 2, image 2 de 3 Retroid Pocket 3 Button Pad Replacement: étape 2, image 3 de 3
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
    Demander à FixBot
  3. Retroid Pocket 3 Button Pad Replacement: étape 3, image 1 de 2 Retroid Pocket 3 Button Pad Replacement: étape 3, image 2 de 2
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
    Demander à FixBot
  4. Retroid Pocket 3 Button Pad Replacement: étape 4, image 1 de 3 Retroid Pocket 3 Button Pad Replacement: étape 4, image 2 de 3 Retroid Pocket 3 Button Pad Replacement: étape 4, image 3 de 3
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
    Demander à FixBot
  5. Retroid Pocket 3 Button Pad Replacement, Button Pad: étape 5, image 1 de 3 Retroid Pocket 3 Button Pad Replacement, Button Pad: étape 5, image 2 de 3 Retroid Pocket 3 Button Pad Replacement, Button Pad: étape 5, image 3 de 3
    • Undo the ribbon cable clips using the Spudger tool.
    • Unclip the cable on the left side of the board.
    • Carefully lift the ribbon cable to the right to remove it from the clip.
    Demander à FixBot
  6. Retroid Pocket 3 Button Pad Replacement: étape 6, image 1 de 2 Retroid Pocket 3 Button Pad Replacement: étape 6, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the three 5.9 mm screws from the controller board.
    • Carefully lift the board out of the device.
    Demander à FixBot
  7. Retroid Pocket 3 Button Pad Replacement: étape 7, image 1 de 2 Retroid Pocket 3 Button Pad Replacement: étape 7, image 2 de 2
    • Using the Spudger tool, put the tip under the edge of the rubber button pad to start lifting it.
    • Button pad will loosen and lift straight out of the casing.
    Demander à FixBot
  8. Retroid Pocket 3 Button Pad Replacement: étape 8, image 1 de 1
    • Move to the right side of the device.
    • Using a spudger, undo the ribbon cable clip connected to the main PCB along with the joystick ribbon cable.
    Demander à FixBot
  9. Retroid Pocket 3 Button Pad Replacement: étape 9, image 1 de 3 Retroid Pocket 3 Button Pad Replacement: étape 9, image 2 de 3 Retroid Pocket 3 Button Pad Replacement: étape 9, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the two 5.9 mm screws.
    Demander à FixBot
  10. Retroid Pocket 3 Button Pad Replacement: étape 10, image 1 de 3 Retroid Pocket 3 Button Pad Replacement: étape 10, image 2 de 3 Retroid Pocket 3 Button Pad Replacement: étape 10, image 3 de 3
    • Carefully pry up the silicone button pad with a Spudger tool.
    Demander à FixBot
Cassidy Anderson
Membre depuis le 02/08/24
271 Réputation
2 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 68
Total : 1,221
