Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Retroid Pocket 3 Trigger Button Replacement
Ce dont vous avez besoin
  1. Retroid Pocket 3 Trigger Button Replacement, Battery: étape 1, image 1 de 1
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
    Demander à FixBot
    Ajouter un commentaire
  2. Retroid Pocket 3 Trigger Button Replacement: étape 2, image 1 de 3 Retroid Pocket 3 Trigger Button Replacement: étape 2, image 2 de 3 Retroid Pocket 3 Trigger Button Replacement: étape 2, image 3 de 3
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
    Demander à FixBot
  3. Retroid Pocket 3 Trigger Button Replacement: étape 3, image 1 de 2 Retroid Pocket 3 Trigger Button Replacement: étape 3, image 2 de 2
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
    Demander à FixBot
  4. Retroid Pocket 3 Trigger Button Replacement: étape 4, image 1 de 3 Retroid Pocket 3 Trigger Button Replacement: étape 4, image 2 de 3 Retroid Pocket 3 Trigger Button Replacement: étape 4, image 3 de 3
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
    Demander à FixBot
  5. Retroid Pocket 3 Trigger Button Replacement, Trigger Button: étape 5, image 1 de 3 Retroid Pocket 3 Trigger Button Replacement, Trigger Button: étape 5, image 2 de 3 Retroid Pocket 3 Trigger Button Replacement, Trigger Button: étape 5, image 3 de 3
    • Using the spudger, put the tip under the top round clip at the top.
    • Carefully start lifting the clip to slide it off the plastic pin on the case, tilting the trigger button as you lift it to remove.
    Demander à FixBot
  6. Retroid Pocket 3 Trigger Button Replacement: étape 6, image 1 de 3 Retroid Pocket 3 Trigger Button Replacement: étape 6, image 2 de 3 Retroid Pocket 3 Trigger Button Replacement: étape 6, image 3 de 3
    • Remove the six 4.4 mm screws on the trigger buttons with a Phillips #00 screwdriver.
    • Gently pull the trigger button through until it has come undone.
    Demander à FixBot
Max Briseno
Membre depuis le 02/08/24
88 Réputation
1 tutoriel rédigé
Équipe
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 69
Total : 1,563
