Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement
Ce dont vous avez besoin
    1. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement, How to Open the Rocketfish RF-WHTIB-A Receiver: étape 1, image 1 de 1
      • Remove the 4 rubber tabs on the bottom side of the receiver.
      Demander à FixBot
      Ajouter un commentaire
    2. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: étape 2, image 1 de 1
      • Unscrew the four 12 mm screws on the bottom side of the receiver.
      • Use a Phillips #1 screwdriver for this step.
      Demander à FixBot
    3. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: étape 3, image 1 de 2 Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: étape 3, image 2 de 2
      • Remove top casing from the receiver.
      • The receiver top casing is difficult to remove. Internal clasps may have to be broken in order to remove the top casing (this will not effect the device's function)
      Demander à FixBot
    1. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement, Receiver Wireless Audio Module Chip: étape 4, image 1 de 1
      • Unscrew the 10 mm screw holding the wireless audio module.
      Demander à FixBot
    2. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: étape 5, image 1 de 2 Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: étape 5, image 2 de 2
      Outil utilisé dans cette étape :
      • Slide the black retaining flap securing the ribbon cable away from the white bar.
      • There should be only a small space between the white bar and black retaining flap.
      • You may want to use tweezers for this step.
      Demander à FixBot
    3. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: étape 6, image 1 de 1
      • Using your fingers, slide the ribbon cable out from the under the black retaining flap to completely disconnect it from the device.
      Demander à FixBot
To install the new wireless audio module chip, follow these instructions in reverse order.
Caitlin Charlton
Membre depuis le 03/22/15
756 Réputation
6 tutoriels rédigés
Équipe
Baylor, Team 4-2, Williams Spring 2015 Membre de l'équipe Baylor, Team 4-2, Williams Spring 2015
BU-WILLIAMS-S15S4G2
3 membres
12 tutoriels rédigés
1 commentaire de tutoriel
This is a very long time later, but where do you get the receiver chip??? Rocket fish doesn't support the product anymore
Michael Jay - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 24
Total : 2,552
