Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Roku 4 Remote Control Motherboard Replacement
Ce dont vous avez besoin
    1. Roku 4 Remote Control Motherboard Replacement, Remote Control Motherboard: étape 1, image 1 de 1
      • Place the remote control facing down on the table, so that the buttons are facing downwards.
      Demander à FixBot
      Ajouter un commentaire
    2. Roku 4 Remote Control Motherboard Replacement: étape 2, image 1 de 2 Roku 4 Remote Control Motherboard Replacement: étape 2, image 2 de 2
      • Remove the battery compartment cover from the back of the remote by sliding it outwards. This should reveal the batteries.
      Demander à FixBot
    3. Roku 4 Remote Control Motherboard Replacement: étape 3, image 1 de 2 Roku 4 Remote Control Motherboard Replacement: étape 3, image 2 de 2
      • Remove the batteries from the battery compartment.
      Demander à FixBot
    4. Roku 4 Remote Control Motherboard Replacement: étape 4, image 1 de 1
      • Turn the Phillips PH0 screwdriver counterclockwise to carefully remove the 6.9 mm screw located between both battery compartments .
      Demander à FixBot
    5. Roku 4 Remote Control Motherboard Replacement: étape 5, image 1 de 1
      • Wedge a plastic opening tool into the seam between the top cover and bottom casing of the device to create a gap.
      • Prying open the remote is quite difficult and requires a large amount of force. Use caution to avoid breaking the device or hurting yourself.
      • Once you have created a gap large enough for your fingers to fit between, separate the top cover from the bottom plastic casing by pulling them apart gently.
      Demander à FixBot
    6. Roku 4 Remote Control Motherboard Replacement: étape 6, image 1 de 3 Roku 4 Remote Control Motherboard Replacement: étape 6, image 2 de 3 Roku 4 Remote Control Motherboard Replacement: étape 6, image 3 de 3
      • Using your right thumb, lift up on the left side of the motherboard to remove it from the bottom plastic casing.
      Demander à FixBot
2 autres ont terminé cette réparation.
Hank Harrison
Membre depuis le 03/26/17
476 Réputation
3 tutoriels rédigés
Équipe
Baylor, Team S5-G4, Williams Spring 2017 Membre de l'équipe Baylor, Team S5-G4, Williams Spring 2017
BU-WILLIAMS-S17S5G4
3 membres
12 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 48
Total : 2,134
