Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Ryobi P202 Trigger Assembly Replacement
Ce dont vous avez besoin
  1. Ryobi P202 Trigger Assembly Replacement, Battery: étape 1, image 1 de 3 Ryobi P202 Trigger Assembly Replacement, Battery: étape 1, image 2 de 3 Ryobi P202 Trigger Assembly Replacement, Battery: étape 1, image 3 de 3
    • The battery can shock you. Only touch plastic, non-conductive components.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
    Demander à FixBot
    Ajouter un commentaire
  2. Ryobi P202 Trigger Assembly Replacement, Right Side Case: étape 2, image 1 de 2 Ryobi P202 Trigger Assembly Replacement, Right Side Case: étape 2, image 2 de 2
    • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
    Demander à FixBot
  3. Ryobi P202 Trigger Assembly Replacement: étape 3, image 1 de 2 Ryobi P202 Trigger Assembly Replacement: étape 3, image 2 de 2
    • Gently lift the casing from the drill body.
    • Take the casing completely off the drill body to gain access to the interior of the drill.
    • The Ryobi P202 casing has Part #: 200690001
    Demander à FixBot
  4. Ryobi P202 Trigger Assembly Replacement, Battery Contacts: étape 4, image 1 de 2 Ryobi P202 Trigger Assembly Replacement, Battery Contacts: étape 4, image 2 de 2
    • Grip the battery clip and pull straight up to remove the metal battery contacts.
    • You can now clean the metal battery contacts with isopropyl alcohol.
    Demander à FixBot
  5. Ryobi P202 Trigger Assembly Replacement, Trigger Assembly: étape 5, image 1 de 2 Ryobi P202 Trigger Assembly Replacement, Trigger Assembly: étape 5, image 2 de 2
    • Holding the direction select switch in place, grip both sides of the trigger assembly and lift it up and towards the base of the drill.
    Demander à FixBot
  6. Ryobi P202 Trigger Assembly Replacement: étape 6, image 1 de 2 Ryobi P202 Trigger Assembly Replacement: étape 6, image 2 de 2
    • To separate the trigger assembly from the motor, use a soldering iron to melt the solder and pull gently on the red and black wires from the trigger.
    • Heating the solder may melt the plastic packaging. Prior experience with soldering is required.
    • The trigger assembly is Part #: 270001392
    Demander à FixBot
To reassemble your device, follow these instructions in reverse order. You will need solder to reattach the wires to the trigger assembly.
Joseph Eckstein
Membre depuis le 04/07/15
1 596 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 17-6, Forte Spring 2015 Membre de l'équipe Cal Poly, Team 17-6, Forte Spring 2015
CPSU-FORTE-S15S17G6
4 membres
10 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 19
30 derniers jours : 67
Total : 5,722
