Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Ryobi P517 Trigger Replacement
Ce dont vous avez besoin
  1. Ryobi P517 Trigger Replacement, Housing Assembly: étape 1, image 1 de 1
    • Lay the saw flat so the left side is facing up.
    • Remove the grey orbital button by twisting it counterclockwise.
    Demander à FixBot
    Ajouter un commentaire
  2. Ryobi P517 Trigger Replacement: étape 2, image 1 de 1
    • Remove the rubber boot from the device by peeling it from back to front.
    Demander à FixBot
  3. Ryobi P517 Trigger Replacement: étape 3, image 1 de 1
    • Flip the saw so its right side is facing up.
    • Remove the 10 mm screw using a Torx T27H screwdriver.
    Demander à FixBot
  4. Ryobi P517 Trigger Replacement: étape 4, image 1 de 1
    • Grab the black shoe assembly and pull it out from the front of the saw.
    Demander à FixBot
  5. Ryobi P517 Trigger Replacement: étape 5, image 1 de 2 Ryobi P517 Trigger Replacement: étape 5, image 2 de 2
    • Remove the two 12.5 mm screws from the front of the guide plate using the Torx T10H screwdriver.
    • Then remove the guide plate.
    Demander à FixBot
  6. Ryobi P517 Trigger Replacement: étape 6, image 1 de 1
    • Use the Torx T15H screwdriver to remove the eleven 18.1 mm screws from the housing assembly.
    Demander à FixBot
  7. Ryobi P517 Trigger Replacement: étape 7, image 1 de 2 Ryobi P517 Trigger Replacement: étape 7, image 2 de 2
    • Refer to the diagram provided to identify the gear case.
    • Use a Torx T15H screwdriver to remove the four 30.7 mm screws that are holding the housing assembly with the gear case assembly and gear case cover.
    Demander à FixBot
  8. Ryobi P517 Trigger Replacement: étape 8, image 1 de 2 Ryobi P517 Trigger Replacement: étape 8, image 2 de 2
    • Pull apart the two sides of the housing.
    • If the housing assembly does not come apart easily, do not try to force the pieces apart or else you may damage it. Ensure that all screws have been removed.
    Demander à FixBot
  9. Ryobi P517 Trigger Replacement: étape 9, image 1 de 2 Ryobi P517 Trigger Replacement: étape 9, image 2 de 2
    • Refer to the diagram on the device page to locate the trigger-switch, circuit board, and contact plate assembly. Each of these parts is connected by wires.
    • Remove the switch, circuit board, and contact plate holder assembly from the housing assembly.
    • Gently remove the switch by taking out the wiring from the assembly. Rough handling of the wiring could damage it and require it to be replaced.
    Demander à FixBot
  10. Ryobi P517 Trigger Replacement: étape 10, image 1 de 2 Ryobi P517 Trigger Replacement: étape 10, image 2 de 2
    • Lift and remove the gear case from the housing assembly and ensure that there are no parts remaining in housing assembly.
    • Ensuring the motor remains attached to the gear case to ease reassembly.
    Demander à FixBot
  11. Ryobi P517 Trigger Replacement, Trigger: étape 11, image 1 de 2 Ryobi P517 Trigger Replacement, Trigger: étape 11, image 2 de 2
    • Position the saw so the ports connecting the circuit board assembly to the motor are accessible.
    Demander à FixBot
  12. Ryobi P517 Trigger Replacement: étape 12, image 1 de 1
    • Use the soldering iron and desoldering pump to desolder the circuit board assembly from the motor.
    • Be extremely careful with soldering iron. Improper use of the iron could damage the device and could lead to bodily harm.
    Demander à FixBot
  13. Ryobi P517 Trigger Replacement: étape 13, image 1 de 2 Ryobi P517 Trigger Replacement: étape 13, image 2 de 2
    • Gently pull the thin red and white wire on opposite ends of its connector to disconnect the LED from the circuit board.
    Demander à FixBot
Abner Fernandez
Membre depuis le 02/15/24
445 Réputation
4 tutoriels rédigés
Équipe
University of Memphis, Team 4-4, Sneed Spring 2024 Membre de l'équipe University of Memphis, Team 4-4, Sneed Spring 2024
UM-SNEED-S24S4G4
4 membres
4 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 21
Total : 388
