Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Admire Camera Replacement
Ce dont vous avez besoin
    1. Samsung Admire Camera Replacement, Back Cover: étape 1, image 1 de 1
      • Use your fingernail or the plastic opening tool under the slit to pull the back cover off.
      Demander à FixBot
      Ajouter un commentaire
    2. Samsung Admire Camera Replacement, Remove the Battery: étape 2, image 1 de 1
      • Making sure your hands are dry, insert your fingernail beneath the battery and remove it.
      Demander à FixBot
    3. Samsung Admire Camera Replacement, Remove the screws: étape 3, image 1 de 3 Samsung Admire Camera Replacement, Remove the screws: étape 3, image 2 de 3 Samsung Admire Camera Replacement, Remove the screws: étape 3, image 3 de 3
      Outil utilisé dans cette étape :
      Magnetic Project Mat
      $19.95
      • Use a Phillips #00 Precision Screwdriver to remove the six screws in the back of the phone.
      • Place the screws on a magnetic mat to prevent losing them.
      Demander à FixBot
    4. Samsung Admire Camera Replacement, Inside back Cover: étape 4, image 1 de 3 Samsung Admire Camera Replacement, Inside back Cover: étape 4, image 2 de 3 Samsung Admire Camera Replacement, Inside back Cover: étape 4, image 3 de 3
      • Place the Plastic Opening tool on the outside rim of the back cover.
      • Carefully circle around the rim to open the inside back cover completely.
      • Disconnect the ribbon cables and remove the back cover.
      Demander à FixBot
    5. Samsung Admire Camera Replacement, Motherboard: étape 5, image 1 de 3 Samsung Admire Camera Replacement, Motherboard: étape 5, image 2 de 3 Samsung Admire Camera Replacement, Motherboard: étape 5, image 3 de 3
      • Carefully disconnect the volume button, the microphone connector, and the screen connector from the motherboard.
      • Pull back the side clips and lift the motherboard slowly.
      Demander à FixBot
    6. Samsung Admire Camera Replacement, Camera: étape 6, image 1 de 2 Samsung Admire Camera Replacement, Camera: étape 6, image 2 de 2
      • Use the plastic opening tool to disconnect the camera from the phone.
      • Connect the new camera into the motherboard.
      Demander à FixBot
12 autres ont terminé cette réparation.
Thao Uyen Do
Membre depuis le 01/20/15
944 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 7-5, Remmell Winter 2015 Membre de l'équipe USF Tampa, Team 7-5, Remmell Winter 2015
USFT-REMMELL-W15S7G5
4 membres
16 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 32
Total : 2,114
