Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Epix Keyboard Replacement
Ce dont vous avez besoin
  1. Samsung Epix Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Just below the phone's camera, press the button and hold it
    • While the button is held down, slide the back panel off to remove it completely.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Epix Keyboard Replacement: étape 2, image 1 de 1
    • Grasp the bottom corners of the battery with two fingers and gently lift.
    • Gently lift the battery and remove it from the phone.
    Demander à FixBot
  3. Samsung Epix Keyboard Replacement, Keyboard: étape 3, image 1 de 1
    • Using a plastic prying tool, remove the screw cover in the top left corner of the phone by lifting it up.
    • Be gentle
    Demander à FixBot
  4. Samsung Epix Keyboard Replacement: étape 4, image 1 de 1
    • Use the Phillips #00 screwdriver to remove the six screws on the back of the phone.
    • Three of the screws are evenly spaced on the left and right side on the back of the phone.
    • The upper right screw is 4.5mm while the rest are 6.5mm.
    Demander à FixBot
  5. Samsung Epix Keyboard Replacement: étape 5, image 1 de 2 Samsung Epix Keyboard Replacement: étape 5, image 2 de 2
    • Insert the prying tool into the seam on the side of the phone and turn it slightly. Do this for each of the eight clips to unhook them
    • There are three clips on each side and two at the bottom of the phone.
    Demander à FixBot
  6. Samsung Epix Keyboard Replacement: étape 6, image 1 de 1
    • Once all eight of the clips have been unhooked, lift the back panel gently off of the phone.
    • Be careful and do not attempt to remove the front panel. It is still connected to the phone's chassis by a ribbon cable which is located in the bottom right side of the motherboard.
    Demander à FixBot
  7. Samsung Epix Keyboard Replacement: étape 7, image 1 de 1
    • Using the plastic prying tool, unlatch the ribbon cable located in the lower right corner of the motherboard.
    • Carefully disconnect the ribbon cable.
    Demander à FixBot
  8. Samsung Epix Keyboard Replacement: étape 8, image 1 de 1
    • Gently lift and remove the front faceplate
    • Exercise caution
    Demander à FixBot
  9. Samsung Epix Keyboard Replacement: étape 9, image 1 de 1
    • Grasp the rubber keyboard in the corner with your fingers and lift to remove it.
    • Lift it and gently take it out the frame to remove it.
    Demander à FixBot
2 autres ont terminé cette réparation.
Chris
Membre depuis le 04/20/11
32 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 15-15, Regan Spring 2011 Membre de l'équipe Cal Poly, Team 15-15, Regan Spring 2011
CPSU-REGAN-S11S15G15
5 membres
10 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 40
Total : 2,036
