Aller au contenu principal
Samsung Galaxy Book Pro 15" Screen Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Book Pro 15" Screen Replacement, Remove the rubber feet: étape 1, image 1 de 3 Samsung Galaxy Book Pro 15" Screen Replacement, Remove the rubber feet: étape 1, image 2 de 3 Samsung Galaxy Book Pro 15" Screen Replacement, Remove the rubber feet: étape 1, image 3 de 3
    • Before you begin, power down your laptop and unplug it.
    • There are two kinds of rubber feet along the top and bottom of the rear case. Keep track of their position as you remove them.
    • Insert an opening pick between the rubber foot and the rear case.
    • Pry up with the opening pick to release the clips securing the foot.
    • Remove the foot.
    • Repeat this procedure for the three remaining feet.
    • During reassembly, press the feet into their correct slot to reinsert them. Mismatched feet won't fit correctly.
  2. Samsung Galaxy Book Pro 15" Screen Replacement, Unfasten the rear case: étape 2, image 1 de 2 Samsung Galaxy Book Pro 15" Screen Replacement, Unfasten the rear case: étape 2, image 2 de 2
    • Use a Phillips screwdriver to remove the four 4.5 mm-long screws securing the rear case.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screws with new ones labeled #3313.
  3. Samsung Galaxy Book Pro 15" Screen Replacement, Insert an opening pick: étape 3, image 1 de 3 Samsung Galaxy Book Pro 15" Screen Replacement, Insert an opening pick: étape 3, image 2 de 3 Samsung Galaxy Book Pro 15" Screen Replacement, Insert an opening pick: étape 3, image 3 de 3
    • Apply a suction cup to the rear case, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear case and the frame.
    • Insert an opening pick into the gap.
  4. Samsung Galaxy Book Pro 15" Screen Replacement, Release the clips: étape 4, image 1 de 3 Samsung Galaxy Book Pro 15" Screen Replacement, Release the clips: étape 4, image 2 de 3 Samsung Galaxy Book Pro 15" Screen Replacement, Release the clips: étape 4, image 3 de 3
    • Slide the pick along the bottom edge of the rear case to release its plastic clips.
    • Repeat this process for the left and right edges, but stop before reaching the top edge.
  5. Samsung Galaxy Book Pro 15" Screen Replacement, Remove the rear case: étape 5, image 1 de 3 Samsung Galaxy Book Pro 15" Screen Replacement, Remove the rear case: étape 5, image 2 de 3 Samsung Galaxy Book Pro 15" Screen Replacement, Remove the rear case: étape 5, image 3 de 3
    • The top edge of the rear case is lightly adhered to the frame.
    • Pull the top of the rear case away from the frame to separate the adhesive and release the remaining clips.
    • If you're having trouble separating the adhesive, use an iOpener, hair dryer, or heat gun to soften it.
    • Remove the rear case.
    • During reassembly, perform the following:
    • If you're using a using a genuine Samsung replacement rear case, be sure to peel off any adhesive liners from the rear case before securing the top edge's clips.
    • If you're reusing your rear case, you can use some pre-cut adhesive to re-adhere the top edge if your existing adhesive is no longer sticky.
    • This is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down completely before you continue working.
  6. Samsung Galaxy Book Pro 15" Screen Replacement, Disconnect the battery: étape 6, image 1 de 2 Samsung Galaxy Book Pro 15" Screen Replacement, Disconnect the battery: étape 6, image 2 de 2
    • Insert a spudger between the frame and the bottom of the battery cable connector.
    • Pry up and disconnect the battery cable connector.
  7. Samsung Galaxy Book Pro 15" Screen Replacement, Disconnect the display: étape 7, image 1 de 2 Samsung Galaxy Book Pro 15" Screen Replacement, Disconnect the display: étape 7, image 2 de 2
  8. Samsung Galaxy Book Pro 15" Screen Replacement: étape 8, image 1 de 2 Samsung Galaxy Book Pro 15" Screen Replacement: étape 8, image 2 de 2
    • Disconnect the display cable by sliding it out from its socket on the motherboard.
  9. Samsung Galaxy Book Pro 15" Screen Replacement, Disconnect the antenna: étape 9, image 1 de 3 Samsung Galaxy Book Pro 15" Screen Replacement, Disconnect the antenna: étape 9, image 2 de 3 Samsung Galaxy Book Pro 15" Screen Replacement, Disconnect the antenna: étape 9, image 3 de 3
    • Use the tip of a spudger to pry up and disconnect the two WLAN antenna cables.
    • Pry under the bottom of the cable's metal head and not the cable itself.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  10. Samsung Galaxy Book Pro 15" Screen Replacement, Unclip the antenna cables: étape 10, image 1 de 3 Samsung Galaxy Book Pro 15" Screen Replacement, Unclip the antenna cables: étape 10, image 2 de 3 Samsung Galaxy Book Pro 15" Screen Replacement, Unclip the antenna cables: étape 10, image 3 de 3
    • Use a spudger to pry up and unclip the antenna cables from their clips on the daughterboard.
  11. Samsung Galaxy Book Pro 15" Screen Replacement, Unfasten some of the hinge screws: étape 11, image 1 de 2 Samsung Galaxy Book Pro 15" Screen Replacement, Unfasten some of the hinge screws: étape 11, image 2 de 2
    • Use a Phillips screwdriver to remove one 4.5 mm-long screw securing each screen hinge (two screws total).
    • Each hinge has a second screw, which you should leave in place for now.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screws with new ones labeled #1650.
  12. Samsung Galaxy Book Pro 15" Screen Replacement: étape 12, image 1 de 1
    • Fully open the screen and stand your laptop up on one side.
  13. Samsung Galaxy Book Pro 15" Screen Replacement, Unfasten the remaining screws: étape 13, image 1 de 3 Samsung Galaxy Book Pro 15" Screen Replacement, Unfasten the remaining screws: étape 13, image 2 de 3 Samsung Galaxy Book Pro 15" Screen Replacement, Unfasten the remaining screws: étape 13, image 3 de 3
    • Use a Phillips screwdriver to remove the two remaining 4.5 mm screws (one from each hinge).
    • Remove the topmost screw last, using one hand to steady both halves of the laptop to make sure they don't separate and fall over unexpectedly.
  14. Samsung Galaxy Book Pro 15" Screen Replacement, Remove the screen: étape 14, image 1 de 3 Samsung Galaxy Book Pro 15" Screen Replacement, Remove the screen: étape 14, image 2 de 3 Samsung Galaxy Book Pro 15" Screen Replacement, Remove the screen: étape 14, image 3 de 3
    • Keep a firm grip on both the screen and frame of the laptop. Either half can fall unexpectedly during this step.
    • Push both halves of the laptop together so that the hinges can be lifted clear of their recesses in the frame.
    • Push the frame of the laptop away from you while pulling the screen toward you to separate it.
  15. Samsung Galaxy Book Pro 15" Screen Replacement: étape 15, image 1 de 1
    • Remove the screen.
    • During reassembly, first install the hinge screws without tightening them fully. Then adjust the screen until it's correctly centered and aligned on each side. Finally, tighten the screws.
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
2 autres ont terminé cette réparation.
Alex Diaz-Kokaisl
Membre depuis le 01/16/22
125 001 Réputation
582 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
17 420 tutoriels rédigés
Un commentaire
Will this screen work on the galaxy book 2 pro? Are they the same screens?
saad abdullah - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 32
30 derniers jours : 254
Total : 4,599
