Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy Note9 Iris Scanner Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Note9 Iris Scanner Replacement, Apply a heated iOpener: étape 1, image 1 de 1
    • Power off your phone before beginning disassembly.
    • Use a hairdryer, a heatgun, or prepare an iOpener and apply it to the right edge of the back of the phone for about a minute to soften the adhesive underneath.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy Note9 Iris Scanner Replacement, Insert an opening pick: étape 2, image 1 de 3 Samsung Galaxy Note9 Iris Scanner Replacement, Insert an opening pick: étape 2, image 2 de 3 Samsung Galaxy Note9 Iris Scanner Replacement, Insert an opening pick: étape 2, image 3 de 3
    • Apply a suction handle to the back cover.
    • Lift with a suction handle to create a gap between the back cover and the frame of the phone.
    • Insert an opening pick into the gap.
    • If the glass is badly cracked, cover it in packing tape to create a surface for the suction cup to adhere to.
    • If the adhesive won't budge, apply more heat, not excessive force. Too much force could break the glass.
    Demander à FixBot
  3. Samsung Galaxy Note9 Iris Scanner Replacement, Cut through the adhesive: étape 3, image 1 de 1
    • Note that there is more adhesive along the top edge and around the camera bezel than around the rest of the phone.
    • Cut carefully around the left edge near the fingerprint sensor or you risk damaging the ribbon cable inside.
    • If, at any point, the adhesive feels stubborn, apply more heat—not more force.
    Demander à FixBot
  4. Samsung Galaxy Note9 Iris Scanner Replacement, Slide the opening pick: étape 4, image 1 de 3 Samsung Galaxy Note9 Iris Scanner Replacement, Slide the opening pick: étape 4, image 2 de 3 Samsung Galaxy Note9 Iris Scanner Replacement, Slide the opening pick: étape 4, image 3 de 3
    • Starting from the center, cut the adhesive up and down the right side with an opening pick.
    • Do not insert the pick more than halfway into the phone when cutting near the fingerprint sensor or cameras, or you risk damaging internal components.
    Demander à FixBot
  5. Samsung Galaxy Note9 Iris Scanner Replacement: étape 5, image 1 de 3 Samsung Galaxy Note9 Iris Scanner Replacement: étape 5, image 2 de 3 Samsung Galaxy Note9 Iris Scanner Replacement: étape 5, image 3 de 3
    • Be careful near the corner, as the glass is very weak. Apply more heat at any time if the adhesive becomes stuck.
    • Leave an opening pick in the upper-right corner.
    • Use another opening pick to cut the adhesive around the bottom-right corner.
    • Leave that opening pick in the phone.
    Demander à FixBot
  6. Samsung Galaxy Note9 Iris Scanner Replacement: étape 6, image 1 de 1
    • Use a heat gun or hair dryer or apply a heated iOpener to the left side of the rear panel for at three minutes to soften the adhesive underneath.
    Demander à FixBot
  7. Samsung Galaxy Note9 Iris Scanner Replacement: étape 7, image 1 de 3 Samsung Galaxy Note9 Iris Scanner Replacement: étape 7, image 2 de 3 Samsung Galaxy Note9 Iris Scanner Replacement: étape 7, image 3 de 3
    • Be careful near the corners, as the glass is weakest there.
    • Insert an opening pick into the lower-left corner of the rear panel.
    • Using another opening pick, cut the adhesive along the left edge of the rear panel.
    • Don't insert an opening pick in more than halfway on the left edge near the fingerprint sensor or you may damage the ribbon cable inside.
    • It is fine if opening picks fall out as the back cover becomes separated.
    Demander à FixBot
  8. Samsung Galaxy Note9 Iris Scanner Replacement: étape 8, image 1 de 3 Samsung Galaxy Note9 Iris Scanner Replacement: étape 8, image 2 de 3 Samsung Galaxy Note9 Iris Scanner Replacement: étape 8, image 3 de 3
    • Using the inserted opening pick, carefully cut the adhesive around the upper-left corner of the rear panel.
    • Finally, cut the last of the adhesive along the top of the phone.
    • Use an iOpener, hair dryer, or heat gun to apply more heat as needed where you are cutting the adhesive.
    Demander à FixBot
  9. Samsung Galaxy Note9 Iris Scanner Replacement: étape 9, image 1 de 2 Samsung Galaxy Note9 Iris Scanner Replacement: étape 9, image 2 de 2
    • Separate the right side of the rear cover first.
    • Tilt the cover up along the left edge to expose the fingerprint sensor ribbon cable.
    • Do not pull out the fingerprint sensor ribbon cable yet.
    • The fingerprint sensor cover might stay attached to the midframe.
    Demander à FixBot
  10. Samsung Galaxy Note9 Iris Scanner Replacement, Disconnect the fingerprint sensor: étape 10, image 1 de 2 Samsung Galaxy Note9 Iris Scanner Replacement, Disconnect the fingerprint sensor: étape 10, image 2 de 2
    • Use the tip of a spudger to pry the fingerprint sensor ribbon cable up and out of its socket.
    Demander à FixBot
  11. Samsung Galaxy Note9 Iris Scanner Replacement: étape 11, image 1 de 1
    Outil utilisé dans cette étape :
    • Remove the back cover.
    • To re-install the back cover:
    • Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive. You don't have to clear out adhesive down to the plastic but larger pieces should be removed.
    • Turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • Carefully apply the new adhesive to the back cover, then line up one edge of the glass against the phone chassis and firmly press the glass into the phone.
    Demander à FixBot
  12. Attention : les étapes 12 à 15 sont issues d'un tutoriel marqué comme étant en cours.
    Samsung Galaxy Note9 Iris Scanner Replacement, Remove the upper midframe: étape 12, image 1 de 2 Samsung Galaxy Note9 Iris Scanner Replacement, Remove the upper midframe: étape 12, image 2 de 2
    • Use a Phillips screwdriver to remove the nine 4 mm screws securing the upper midframe.
    Demander à FixBot
  13. Samsung Galaxy Note9 Iris Scanner Replacement: étape 13, image 1 de 2 Samsung Galaxy Note9 Iris Scanner Replacement: étape 13, image 2 de 2
    • Insert the tip of a spudger into the upper-left corner of the upper midframe.
    • Pry the upper midframe out of the phone.
    • The upper midframe snaps into and out of place.
    Demander à FixBot
  14. Samsung Galaxy Note9 Iris Scanner Replacement: étape 14, image 1 de 3 Samsung Galaxy Note9 Iris Scanner Replacement: étape 14, image 2 de 3 Samsung Galaxy Note9 Iris Scanner Replacement: étape 14, image 3 de 3
    • Peel the wireless charging coil off the battery starting with the left side.
    • The adhesive is weak but you can use an opening pick to cut it if necessary.
    • During reassembly start by snapping the midframe into place first before adhering the wireless charging coil.
    Demander à FixBot
  15. Samsung Galaxy Note9 Iris Scanner Replacement, Disconnect the battery: étape 15, image 1 de 2 Samsung Galaxy Note9 Iris Scanner Replacement, Disconnect the battery: étape 15, image 2 de 2
    • Use the tip of a spudger to disconnect the orange ribbon cable connecting the battery to the motherboard.
    Demander à FixBot
  16. Samsung Galaxy Note9 Iris Scanner Replacement, Remove the iris scanner: étape 16, image 1 de 3 Samsung Galaxy Note9 Iris Scanner Replacement, Remove the iris scanner: étape 16, image 2 de 3 Samsung Galaxy Note9 Iris Scanner Replacement, Remove the iris scanner: étape 16, image 3 de 3
    • Use the tip of a spudger to pry the iris scanner connector straight up and out of its socket.
    • Use a pair of tweezers to remove the iris scanner.
    Demander à FixBot
Sam Omiotek
Membre depuis le 02/25/19
99 272 Réputation
290 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 40
Total : 1,402
