Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy S20 Ultra Back Cover Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy S20 Ultra Back Cover Replacement, Heat the bottom edge: étape 1, image 1 de 1
    • Unplug and power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy S20 Ultra Back Cover Replacement, Separate the bottom edge adhesive: étape 2, image 1 de 3 Samsung Galaxy S20 Ultra Back Cover Replacement, Separate the bottom edge adhesive: étape 2, image 2 de 3 Samsung Galaxy S20 Ultra Back Cover Replacement, Separate the bottom edge adhesive: étape 2, image 3 de 3
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • If the back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
    • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert the point of an opening pick into the gap.
    • Due to tight tolerances, this may take multiple attempts of reheating with the iOpener and separating with the suction cup before you get it right.
    • If you are having trouble creating a gap, apply more heat to the edge and try again.
    • Do not apply excessive force with the pick, or you risk cracking the back cover glass.
    Demander à FixBot
  3. Samsung Galaxy S20 Ultra Back Cover Replacement, Slice the adhesive: étape 3, image 1 de 3 Samsung Galaxy S20 Ultra Back Cover Replacement, Slice the adhesive: étape 3, image 2 de 3 Samsung Galaxy S20 Ultra Back Cover Replacement, Slice the adhesive: étape 3, image 3 de 3
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Do not attempt to cut the adhesive near the corners of the phone where the glass is curved or you risk cracking the glass panel.
    • Leave your opening pick in the seam to prevent the adhesive from resealing.
    Demander à FixBot
  4. Samsung Galaxy S20 Ultra Back Cover Replacement, Heat the left edge: étape 4, image 1 de 1
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
    Demander à FixBot
  5. Samsung Galaxy S20 Ultra Back Cover Replacement, Separate the left edge adhesive: étape 5, image 1 de 3 Samsung Galaxy S20 Ultra Back Cover Replacement, Separate the left edge adhesive: étape 5, image 2 de 3 Samsung Galaxy S20 Ultra Back Cover Replacement, Separate the left edge adhesive: étape 5, image 3 de 3
    • Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
    • As the glass on this edge is curved, you won't be able to insert this pick very far. As long as the very tip of the pick is underneath the glass's edge, you will be able to proceed.
    • Due to tight tolerances, this may take multiple attempts.
    • You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
    Demander à FixBot
  6. Samsung Galaxy S20 Ultra Back Cover Replacement: étape 6, image 1 de 2 Samsung Galaxy S20 Ultra Back Cover Replacement: étape 6, image 2 de 2
    • Once the pick is underneath the glass's edge, tilt it downward and insert it further to fully separate the back cover's adhesive.
    Demander à FixBot
  7. Samsung Galaxy S20 Ultra Back Cover Replacement: étape 7, image 1 de 2 Samsung Galaxy S20 Ultra Back Cover Replacement: étape 7, image 2 de 2
    • Slide the pick towards the bottom edge of the phone to separate the back cover's adhesive.
    • Leave your pick under the left edge of the glass near the bottom of the device to prevent the adhesive from resealing.
    Demander à FixBot
  8. Samsung Galaxy S20 Ultra Back Cover Replacement: étape 8, image 1 de 2 Samsung Galaxy S20 Ultra Back Cover Replacement: étape 8, image 2 de 2
    • Insert another pick under the center of the left edge of the back cover.
    • Gradually slide the pick towards the top of the device to separate the back cover's adhesive.
    • Take care when sliding across the ridge in the frame surrounding the volume and power buttons—the cutout in the glass may make it more prone to cracking.
    • Leave your pick under the left edge of the glass near the top of the device to prevent the adhesive from resealing.
    Demander à FixBot
  9. Samsung Galaxy S20 Ultra Back Cover Replacement, Heat the right edge: étape 9, image 1 de 1
    • Apply a heated iOpener to the right edge of the back cover for two minutes.
    Demander à FixBot
  10. Samsung Galaxy S20 Ultra Back Cover Replacement, Separate the right edge adhesive: étape 10, image 1 de 3 Samsung Galaxy S20 Ultra Back Cover Replacement, Separate the right edge adhesive: étape 10, image 2 de 3 Samsung Galaxy S20 Ultra Back Cover Replacement, Separate the right edge adhesive: étape 10, image 3 de 3
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
    • Like with the previous edge, you will need to tilt the opening pick downward to fully insert it underneath the back cover.
    Demander à FixBot
  11. Samsung Galaxy S20 Ultra Back Cover Replacement: étape 11, image 1 de 2 Samsung Galaxy S20 Ultra Back Cover Replacement: étape 11, image 2 de 2
    • Leave your pick under the right edge of the glass near the bottom of the device to prevent the adhesive from resealing.
    Demander à FixBot
  12. Samsung Galaxy S20 Ultra Back Cover Replacement: étape 12, image 1 de 2 Samsung Galaxy S20 Ultra Back Cover Replacement: étape 12, image 2 de 2
    • Insert another pick underneath the center of the right edge of the back cover.
    • As you do this, the bottom edge of the back cover may release the three picks located there. If this occurs, set these picks aside as the bottom edge shouldn't reseal from this point onward.
    Demander à FixBot
  13. Samsung Galaxy S20 Ultra Back Cover Replacement, Heat the top edge: étape 13, image 1 de 1
    • Apply a heated iOpener to the top edge of the back cover for two minutes.
    Demander à FixBot
  14. Samsung Galaxy S20 Ultra Back Cover Replacement, Separate the top edge adhesive: étape 14, image 1 de 3 Samsung Galaxy S20 Ultra Back Cover Replacement, Separate the top edge adhesive: étape 14, image 2 de 3 Samsung Galaxy S20 Ultra Back Cover Replacement, Separate the top edge adhesive: étape 14, image 3 de 3
    • The glass near the corners of the back cover is curved and very susceptible to cracking. Be gentle during this step to prevent damaging your back cover.
    • Gradually slide the pick from the right edge of the device around the top right corner.
    • Continue slicing along the top edge to fully separate the back cover adhesive.
    • If the slicing becomes difficult at any point, stop and reapply heat before continuing.
    Demander à FixBot
  15. Samsung Galaxy S20 Ultra Back Cover Replacement, Remove the back cover: étape 15, image 1 de 2 Samsung Galaxy S20 Ultra Back Cover Replacement, Remove the back cover: étape 15, image 2 de 2
    Outil utilisé dans cette étape :
    • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using Samsung custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
    Demander à FixBot
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
12 autres ont terminé cette réparation.
Tarun Thiruma
Membre depuis le 11/20/19
40 423 Réputation
134 tutoriels rédigés
5 commentaires de tutoriel
Should I remove these black strips of adhesive inside?
joey - Réponse Partager
Very well written 👏 thank you for such a well written instruction sheet!! 🙏
Nick DiLello - Réponse Partager
Awesome, thank you Sir.
Andrew Stokes - Réponse Partager
I've read and watched a couple other guides; when replacing the back cover they mention that even replacing the back cover with the adhesive it comes with; the phone will not retain its IP68 rating and requires a rework with both back cover adhesive and screws to retain its water protection.
If I follow this guide exactly, will my S20 Ultra lose its IP68 rating?
Nick - Réponse Partager
A+ Thank you for a great tutorial! Well written and easy to follow. Thank You!
Carl Griffith - Réponse Partager
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 38
30 derniers jours : 212
Total : 40,477
