Aller au contenu principal
Samsung Galaxy S22 Battery Disconnect
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. Samsung Galaxy S22 Battery Disconnect, Heat the bottom edge: étape 1, image 1 de 1
    • Let your phone's battery to drain below 25% before starting this repair. A charged lithium-ion battery may catch fire if damaged.
    • Heat an iOpener and apply it to the bottom edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  2. Samsung Galaxy S22 Battery Disconnect, Adhesive information: étape 2, image 1 de 2 Samsung Galaxy S22 Battery Disconnect, Adhesive information: étape 2, image 2 de 2
    • While you wait for the adhesive to soften, note the following:
    • There's adhesive securing the back cover around the perimeter of the frame.
    • The adhesive is strongest in the bottom right and top left corners.
  3. Samsung Galaxy S22 Battery Disconnect, Insert an opening pick: étape 3, image 1 de 3 Samsung Galaxy S22 Battery Disconnect, Insert an opening pick: étape 3, image 2 de 3 Samsung Galaxy S22 Battery Disconnect, Insert an opening pick: étape 3, image 3 de 3
    • Apply a suction handle to the back cover, as close to the bottom edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  4. Samsung Galaxy S22 Battery Disconnect, Slice the bottom adhesive: étape 4, image 1 de 3 Samsung Galaxy S22 Battery Disconnect, Slice the bottom adhesive: étape 4, image 2 de 3 Samsung Galaxy S22 Battery Disconnect, Slice the bottom adhesive: étape 4, image 3 de 3
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from resealing.
  5. Samsung Galaxy S22 Battery Disconnect, Heat the left edge: étape 5, image 1 de 1
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  6. Samsung Galaxy S22 Battery Disconnect, Slice the left adhesive: étape 6, image 1 de 3 Samsung Galaxy S22 Battery Disconnect, Slice the left adhesive: étape 6, image 2 de 3 Samsung Galaxy S22 Battery Disconnect, Slice the left adhesive: étape 6, image 3 de 3
    • Insert a second opening pick at the bottom left corner.
    • Slide the pick to the bottom of the camera bezel to slice the left adhesive.
    • Only insert the pick up to 5 mm, as you may damage the antenna flex cable or the power button cable.
    • Leave the pick in to prevent the adhesive from resealing.
  7. Samsung Galaxy S22 Battery Disconnect, Heat the right edge: étape 7, image 1 de 1
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
  8. Samsung Galaxy S22 Battery Disconnect, Slice the right adhesive: étape 8, image 1 de 3 Samsung Galaxy S22 Battery Disconnect, Slice the right adhesive: étape 8, image 2 de 3 Samsung Galaxy S22 Battery Disconnect, Slice the right adhesive: étape 8, image 3 de 3
    • Insert a third opening pick at the bottom right corner.
    • If the adhesive has resealed, insert the pick closer to the bottom edge.
    • Slide the pick to the top right corner to slice the adhesive.
    • Leave the pick in the top right corner to prevent the adhesive from resealing.
  9. Samsung Galaxy S22 Battery Disconnect, Heat the top edge: étape 9, image 1 de 1
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
  10. Samsung Galaxy S22 Battery Disconnect, Slice the remaining adhesive: étape 10, image 1 de 3 Samsung Galaxy S22 Battery Disconnect, Slice the remaining adhesive: étape 10, image 2 de 3 Samsung Galaxy S22 Battery Disconnect, Slice the remaining adhesive: étape 10, image 3 de 3
    • Insert an opening pick in the gap at the top right edge.
    • Slide the pick across the top edge and around the top left corner to slice the remaining adhesive.
    • Only insert the pick up to 4 mm, as you may damage the rear cameras or flash.
  11. Samsung Galaxy S22 Battery Disconnect, Remove the back cover: étape 11, image 1 de 3 Samsung Galaxy S22 Battery Disconnect, Remove the back cover: étape 11, image 2 de 3 Samsung Galaxy S22 Battery Disconnect, Remove the back cover: étape 11, image 3 de 3
    Outil utilisé dans cette étape :
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • To apply new adhesive, follow this guide.
  12. Samsung Galaxy S22 Battery Disconnect, Disconnect the wireless charging coil: étape 12, image 1 de 2 Samsung Galaxy S22 Battery Disconnect, Disconnect the wireless charging coil: étape 12, image 2 de 2
    • Use the pointed end of a spudger to pry and disconnect the wireless charging coil from the motherboard.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  13. Samsung Galaxy S22 Battery Disconnect, Unfasten the wireless charging coil: étape 13, image 1 de 1
    • Use your Phillips screwdriver to remove the six 3.5 mm-long screws securing the wireless charging coil.
  14. Samsung Galaxy S22 Battery Disconnect, Unfasten the loudspeaker: étape 14, image 1 de 1
    • Use your Phillips screwdriver to remove the seven 3.5 mm screws securing the loudspeaker.
  15. Samsung Galaxy S22 Battery Disconnect, Unclip the loudspeaker: étape 15, image 1 de 3 Samsung Galaxy S22 Battery Disconnect, Unclip the loudspeaker: étape 15, image 2 de 3 Samsung Galaxy S22 Battery Disconnect, Unclip the loudspeaker: étape 15, image 3 de 3
    • Insert the pointed end of your spudger between the upper left corner of the loudspeaker and the frame.
    • Pry up to unclip the loudspeaker from the frame.
    • During reassembly, press around the perimeter of the loudspeaker to engage the clips.
  16. Samsung Galaxy S22 Battery Disconnect, Remove the charging coil and loudspeaker assembly: étape 16, image 1 de 3 Samsung Galaxy S22 Battery Disconnect, Remove the charging coil and loudspeaker assembly: étape 16, image 2 de 3 Samsung Galaxy S22 Battery Disconnect, Remove the charging coil and loudspeaker assembly: étape 16, image 3 de 3
    • Grab and remove the wireless charging coil and loudspeaker from the frame.
    • Do not separate the charging coil from the loudspeaker.
  17. Samsung Galaxy S22 Battery Disconnect, Disconnect the battery: étape 17, image 1 de 2 Samsung Galaxy S22 Battery Disconnect, Disconnect the battery: étape 17, image 2 de 2
    • Use the pointed end of your spudger to pry up and disconnect the battery press connector.
Clay Eickemeyer
Membre depuis le 09/19/22
81 013 Réputation
455 tutoriels rédigés
Équipe
Guide Team Membre de l'équipe Guide Team
Staff
9 membres
11 332 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 3
30 derniers jours : 3
Total : 34
