Introduction
Use this guide to replace a cracked or malfunctioning display on your Samsung Galaxy Tab S3 tablet (identified with model number SM-T820).
The display assembly is the output component to present information and is made up of the glass panel, digitizer, and AMOLED display sandwiched together. Your display may need to be replaced if the glass cracks or is broken because this will affect its touch screen capabilities. It could also experience something called “screen burn-in” that happens on AMOLED displays. “Screen burn-in” is when some of the individual light-emitting pixels powering the display will dim the more they are used, causing uneven lighting and colors.
In step 1 of this guide, you will need to use the iOpener, which is a microwavable heating tool used to loosen adhesive attached to the display. Carefully follow the iOpener heating instructions to avoid burning yourself. If your display is shattered, follow this guide to reinforce your screen to avoid injury until you replace the display. Make sure to power off your laptop completely and disconnect from any external power source prior to beginning this guide.
Ce dont vous avez besoin
To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
Leave the iOpener on edge for two minutes.
As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
To reassemble your device, follow these instructions in reverse order. If you have removed too much adhesive, you may need to apply more during the reassembly process.
7 autres ont terminé cette réparation.
5 commentaires
What if the digitizer is ok and only the glass cover is cracked
If my screen freezing exactly half, can that be the connection cable damaged.? It's look like it happens every time I touch or hold the corner where the volume and power buttons are. Never dropped it.
I also have the same issue
How your issue was resolved.
Ashwin -
