Introduction
If the trackpad on your Samsung Gear VR headset is not responding to touch, use this guide to replace the faulty trackpad. For this guide, you will need a Phillips #000 screwdriver, iFixit opening tool, and metal spudger.
Ce dont vous avez besoin
Push the switch on the right-hand side of the device to separate the cover from the main body.
Pull the cover away from the main device.
Remove the one 5mm Phillips #000 screw to detach the trackpad from the headset.
Pry the trackpad loose from the headset using the spudger.
