Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Jack LCD Replacement
Ce dont vous avez besoin
  1. Samsung Jack LCD Replacement, Battery: étape 1, image 1 de 1
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Jack LCD Replacement: étape 2, image 1 de 1
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
    Demander à FixBot
  3. Samsung Jack LCD Replacement, Rear Case: étape 3, image 1 de 1
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
    Demander à FixBot
  4. Samsung Jack LCD Replacement: étape 4, image 1 de 3 Samsung Jack LCD Replacement: étape 4, image 2 de 3 Samsung Jack LCD Replacement: étape 4, image 3 de 3
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
    Demander à FixBot
  5. Samsung Jack LCD Replacement: étape 5, image 1 de 1
    • Lift the rear case off of the phone.
    Demander à FixBot
  6. Samsung Jack LCD Replacement, Antenna: étape 6, image 1 de 1
    • Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
    Demander à FixBot
  7. Samsung Jack LCD Replacement: étape 7, image 1 de 3 Samsung Jack LCD Replacement: étape 7, image 2 de 3 Samsung Jack LCD Replacement: étape 7, image 3 de 3
    • There is a wire under the antenna connecting it to the Motherboard. Do not pull off the antenna just yet.
    • Use a spudger to remove the wire connector under the antenna.
    Demander à FixBot
  8. Samsung Jack LCD Replacement, Speaker: étape 8, image 1 de 1
    • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
    • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
    Demander à FixBot
  9. Samsung Jack LCD Replacement: étape 9, image 1 de 2 Samsung Jack LCD Replacement: étape 9, image 2 de 2
    • Use the spudger to detach the speaker ribbon cable.
    Demander à FixBot
  10. Samsung Jack LCD Replacement: étape 10, image 1 de 1
    • Lift the speaker out of its compartment.
    Demander à FixBot
  11. Samsung Jack LCD Replacement, Motherboard: étape 11, image 1 de 1
    • Remove the power and volume buttons on the right side of the Motherboard.
    Demander à FixBot
  12. Samsung Jack LCD Replacement: étape 12, image 1 de 2 Samsung Jack LCD Replacement: étape 12, image 2 de 2
    • Use a spudger to detach the camera ribbon cable.
    • Lift the camera off of the Motherboard.
    Demander à FixBot
  13. Samsung Jack LCD Replacement: étape 13, image 1 de 2 Samsung Jack LCD Replacement: étape 13, image 2 de 2
    • Use a spudger to disconnect the white antenna wire on the bottom right corner of the Motherboard.
    Demander à FixBot
  14. Samsung Jack LCD Replacement: étape 14, image 1 de 3 Samsung Jack LCD Replacement: étape 14, image 2 de 3 Samsung Jack LCD Replacement: étape 14, image 3 de 3
    • Use a Plastic Opening Tool to lift the flaps of the ZIF connectors to release the ribbon cables near the bottom of the Motherboard.
    • Use a spudger to carefully pull the ribbon cables away from the ZIF connectors.
    Demander à FixBot
  15. Samsung Jack LCD Replacement: étape 15, image 1 de 2 Samsung Jack LCD Replacement: étape 15, image 2 de 2
    • There is a ribbon cable under the Motherboard connecting it to the LCD. Do not pull off the Motherboard just yet.
    • Insert the Plastic Opening Tool under the upper left corner of the Motherboard to help reveal the ribbon cable.
    • Use a spudger to disconnect the Motherboard ribbon cable.
    Demander à FixBot
  16. Samsung Jack LCD Replacement: étape 16, image 1 de 1
    • Lift the Motherboard off of the phone.
    Demander à FixBot
  17. Samsung Jack LCD Replacement, LCD: étape 17, image 1 de 3 Samsung Jack LCD Replacement, LCD: étape 17, image 2 de 3 Samsung Jack LCD Replacement, LCD: étape 17, image 3 de 3
    • The LCD frame is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool between the LCD frame and the front case of the phone.
    • Slide the Plastic Opening Tool around the LCD frame to detach all of the clips.
    Demander à FixBot
  18. Samsung Jack LCD Replacement: étape 18, image 1 de 2 Samsung Jack LCD Replacement: étape 18, image 2 de 2
    • Lift up the LCD frame.
    Demander à FixBot
  19. Samsung Jack LCD Replacement: étape 19, image 1 de 3 Samsung Jack LCD Replacement: étape 19, image 2 de 3 Samsung Jack LCD Replacement: étape 19, image 3 de 3
    • There is a hanging ribbon cable connected to the LCD screen that passes through the LCD frame.
    • Insert the spudger under the bottom left corner of the LCD screen.
    • Use the spudger to gently pry the LCD screen out of its frame.
    • Gently remove the screen from the frame.
    Demander à FixBot
Paul Piller
Membre depuis le 04/12/11
56 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 24-57, Amido Spring 2011 Membre de l'équipe Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 38
Total : 2,236
