Aller au contenu principal
Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement
Ce dont vous avez besoin
  1. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Unplug your refrigerator: étape 1, image 1 de 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Open the freezer drawer: étape 2, image 1 de 2 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Open the freezer drawer: étape 2, image 2 de 2
    • Slide the freezer drawer fully open.
  3. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the freezer bins: étape 3, image 1 de 3 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the freezer bins: étape 3, image 2 de 3 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the freezer bins: étape 3, image 3 de 3
    • Lift and remove all the freezer bins from the drawer.
    • You may need to open the refrigerator doors in order to remove the large bin.
  4. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the freezer door: étape 4, image 1 de 3 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the freezer door: étape 4, image 2 de 3 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the freezer door: étape 4, image 3 de 3
    • A plastic tab locks each drawer rail in place.
    • Use a flathead screwdriver or your fingers to press in the plastic tab near the inner end of the drawer rail.
    • While pressing the plastic tab, grasp the rail with your free hand and slide it towards you slightly to unlock the rail.
  5. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: étape 5, image 1 de 1
    • Repeat the rail unlock procedure on the other drawer rail.
  6. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: étape 6, image 1 de 1
    • Once both rails are unlocked, firmly pull both rails to slide them out of the refrigerator wall guides.
    • Remove the freezer drawer.
    • To reinstall the freezer drawer:
    • Push the geared torsion bar until it rests at the very end of the rails.
    • Align the drawer rails to the refrigerator wall guides.
    • Close the freezer drawer until the rails lock back in place.
    • If you don't hear a click, visually check if the plastic tabs have locked in place. You may need to push the rails in a little further with your fingers to set the tabs.
  7. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: étape 7, image 1 de 1
    • Use a Phillips screwdriver to remove the two 18.5 mm‑long screws securing the evaporator cover to the refrigerator.
  8. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: étape 8, image 1 de 2 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: étape 8, image 2 de 2
    • Lift the bottom edge of the evaporator cover away from the refrigerator to release the bottom clips.
    • Don't try to fully remove the cover. It's still connected by a few wires.
    • Shift the evaporator cover downwards to access the connectors in the top right corner of the freezer compartment.
  9. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Disconnect the fan connector: étape 9, image 1 de 3 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Disconnect the fan connector: étape 9, image 2 de 3 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Disconnect the fan connector: étape 9, image 3 de 3
    • Squeeze the bottom edge of the fan connector to unlock it from the freezer wall.
    • Pull and disconnect the fan connector.
  10. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: étape 10, image 1 de 1
    • Remove the evaporator cover.
  11. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Loosen the fan cable: étape 11, image 1 de 3 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Loosen the fan cable: étape 11, image 2 de 3 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Loosen the fan cable: étape 11, image 3 de 3
    • Guide the fan cable out of the evaporator cover clips.
    • If you have trouble getting the cable out of the clips, squeeze the clips with pliers to create a wider gap.
  12. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the evaporator back panel: étape 12, image 1 de 1
    • Use a Phillips screwdriver to remove the five 14.5 mm‑long screws securing the back panel to the evaporator cover.
  13. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: étape 13, image 1 de 3 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: étape 13, image 2 de 3 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: étape 13, image 3 de 3
    • Use your fingers to pry and release the clips along the short edge of the evaporator cover.
    • If the perimeter foam insulation prevents you from releasing the clips, cut the foam with scissors.
  14. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: étape 14, image 1 de 3 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: étape 14, image 2 de 3 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: étape 14, image 3 de 3
    • Lift and separate the back panel from the evaporator cover.
  15. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the evaporator fan: étape 15, image 1 de 1
    • Use a Phillips screwdriver to remove the three 14.2 mm‑long screws securing the evaporator fan.
  16. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: étape 16, image 1 de 2 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: étape 16, image 2 de 2
    • Lift and remove the evaporator fan.
    • During reassembly, be sure to install the fan in the right orientation: the side with the center label should face down towards the evaporator cover.
Arthur Shi
Membre depuis le 01/03/18
258 910 Réputation
531 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
140 membres
18 069 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 46
30 derniers jours : 183
Total : 1,356
