Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung SmartThings Hub USB Port Replacement
Ce dont vous avez besoin
    1. Samsung SmartThings Hub USB Port Replacement, USB Port: étape 1, image 1 de 1
      • To open your device, gently slide the grey bottom cover in the direction of the arrow as shown.
      Demander à FixBot
      Ajouter un commentaire
    2. Samsung SmartThings Hub USB Port Replacement: étape 2, image 1 de 3 Samsung SmartThings Hub USB Port Replacement: étape 2, image 2 de 3 Samsung SmartThings Hub USB Port Replacement: étape 2, image 3 de 3
      • Make sure the batteries are removed before attempting disassembly.
      • Using your Phillips #1 screwdriver, remove the four visible 12.5mm screws.
      • Next, either peel up the longer of the two stickers or punch a hole with the tip of your screwdriver to access the fifth 12.5mm screw.
      Demander à FixBot
    3. Samsung SmartThings Hub USB Port Replacement: étape 3, image 1 de 3 Samsung SmartThings Hub USB Port Replacement: étape 3, image 2 de 3 Samsung SmartThings Hub USB Port Replacement: étape 3, image 3 de 3
      • Once all five screws are removed, split the casing apart by applying gentle upwards pressure against the positive terminals in the battery compartment.
      Demander à FixBot
    4. Samsung SmartThings Hub USB Port Replacement: étape 4, image 1 de 2 Samsung SmartThings Hub USB Port Replacement: étape 4, image 2 de 2
      • To remove the motherboard, grip the USB port and the Ethernet port. Lift up, then slide towards the front of the device to release the motherboard from the black retaining clip shown on the right.
      Demander à FixBot
    5. Samsung SmartThings Hub USB Port Replacement: étape 5, image 1 de 3 Samsung SmartThings Hub USB Port Replacement: étape 5, image 2 de 3 Samsung SmartThings Hub USB Port Replacement: étape 5, image 3 de 3
      • Place the motherboard on a clean, flat surface.
      • Preheat your soldering iron. Each USB port has eight points of connection to the motherboard (pictured above). Using your soldering iron, apply heat to each solder joint in turn while pulling the USB port away from the board.
      • Soldering irons can reach temperatures of over 500 degrees. Watch your fingers!
      • For more information on soldering refer to How To Solder and Desolder Connections.
      Demander à FixBot
2 autres ont terminé cette réparation.
Erin
Membre depuis le 09/28/17
494 Réputation
4 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 25
Total : 1,074
