Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung WB1100F Camera Flash Replacement
Ce dont vous avez besoin
  1. Samsung WB1100F Camera Flash Replacement, LCD Screen Cover: étape 1, image 1 de 2 Samsung WB1100F Camera Flash Replacement, LCD Screen Cover: étape 1, image 2 de 2
    • Remove six 1.2 mm Phillips #00 screws connected to the tripod dock and adjacent screws.
    • Remove six 1.2 mm Phillips #00 screws from the side of the camera.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung WB1100F Camera Flash Replacement: étape 2, image 1 de 2 Samsung WB1100F Camera Flash Replacement: étape 2, image 2 de 2
    • Use a plastic opening tool or spudger if available.
    • Using the flat end of a spudger, loosen the connection between the back panel and the device. Remove the back panel using your hands.
    Demander à FixBot
  3. Samsung WB1100F Camera Flash Replacement, Camera Flash: étape 3, image 1 de 3 Samsung WB1100F Camera Flash Replacement, Camera Flash: étape 3, image 2 de 3 Samsung WB1100F Camera Flash Replacement, Camera Flash: étape 3, image 3 de 3
    • Remove four 1.2 mm Phillips #00 screws from the top panel.
    Demander à FixBot
  4. Samsung WB1100F Camera Flash Replacement: étape 4, image 1 de 1
    • Using the flat end of a spudger, loosen the connection between the top panel and the device. Remove the top panel using your hands.
    Demander à FixBot
  5. Samsung WB1100F Camera Flash Replacement: étape 5, image 1 de 1
    • Remove four 1.2 mm Phillips #00 screws from the flash assembly
    Demander à FixBot
  6. Samsung WB1100F Camera Flash Replacement: étape 6, image 1 de 1
    • Using your hands, remove the flash assembly. This should not require much force.
    Demander à FixBot
  7. Samsung WB1100F Camera Flash Replacement: étape 7, image 1 de 2 Samsung WB1100F Camera Flash Replacement: étape 7, image 2 de 2
    • Using your hands, remove the top flash panel by pressuring down on the back to release a locking tab.
    Demander à FixBot
  8. Samsung WB1100F Camera Flash Replacement: étape 8, image 1 de 1
    • Desolder three wires on the flash assembly.
    Demander à FixBot
  9. Samsung WB1100F Camera Flash Replacement: étape 9, image 1 de 1
    • Gently remove the flash assembly from the body.
    Demander à FixBot
Jesse Lindsey
Membre depuis le 05/13/16
581 Réputation
5 tutoriels rédigés
Équipe
Metro State, Team 1-1, Carpenter SU 2016 Membre de l'équipe Metro State, Team 1-1, Carpenter SU 2016
MSU-CARPENTER-SU16S1G1
3 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 37
Total : 925
