Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sansa e260R Memory Board Replacement
Ce dont vous avez besoin
  1. Sansa e260R Memory Board Replacement, Rear Case: étape 1, image 1 de 1
    • Before disassembling the device, make sure it is powered off.
    • Remove the four 1.5mm screws on the back of the device.
    Demander à FixBot
    Ajouter un commentaire
  2. Sansa e260R Memory Board Replacement: étape 2, image 1 de 1
    • Using a plastic opening tool, lift the metal backing from the front of the device.
    Demander à FixBot
  3. Sansa e260R Memory Board Replacement: étape 3, image 1 de 1
    • Pull the rear panel off of the Sansa e260R.
    Demander à FixBot
  4. Sansa e260R Memory Board Replacement, Battery: étape 4, image 1 de 1
    • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
    Demander à FixBot
  5. Sansa e260R Memory Board Replacement, Front Panel: étape 5, image 1 de 1
    • Remove the four 1.5mm screws on the inner casing of the device.
    • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
    Demander à FixBot
  6. Sansa e260R Memory Board Replacement: étape 6, image 1 de 1
    • Flip the device so that the front is facing you.
    • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
    Demander à FixBot
  7. Sansa e260R Memory Board Replacement: étape 7, image 1 de 2 Sansa e260R Memory Board Replacement: étape 7, image 2 de 2
    • Pull the front cover away from the rest of the device.
    Demander à FixBot
  8. Sansa e260R Memory Board Replacement, Memory Board: étape 8, image 1 de 2 Sansa e260R Memory Board Replacement, Memory Board: étape 8, image 2 de 2
    • Near the charging port, pull the case away from the motherboard to create clearance to remove the motherboard.
    • Use the spudger to push the motherboard in and pop the metal edge of the charging port up and inside the plastic case.
    Demander à FixBot
  9. Sansa e260R Memory Board Replacement: étape 9, image 1 de 1
    • Pull the bottom of the motherboard up and then out.
    Demander à FixBot
  10. Sansa e260R Memory Board Replacement: étape 10, image 1 de 1
    • On the back of the motherboard, there is a rectangle of rubber.
    • Peel the rectangle off slowly.
    Demander à FixBot
  11. Sansa e260R Memory Board Replacement: étape 11, image 1 de 1
    • Under the rubber rectangle, there is a strip of black tape.
    • Peel the tape off about halfway so that it is no longer attached to the memory board.
    Demander à FixBot
  12. Sansa e260R Memory Board Replacement: étape 12, image 1 de 1
    • Carefully peel the memory board away from the rest of the motherboard
    Demander à FixBot
6 autres ont terminé cette réparation.
JenniferW
Membre depuis le 01/31/12
194 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 8-15, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 8-15, Maness Winter 2012
CPSU-MANESS-W12S8G15
5 membres
5 tutoriels rédigés
1 commentaire de tutoriel
thanks a million for this. i accidentally erased the boot partition, bought another one on eBay with a defective audio channel and switched the memory board: eureka! i’m happy listening to my tunes again!
Admin User - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 35
Total : 3,083
